Caulk At Tubline... ...or Grout?
Old 10-16-2008, 06:41 PM   #1
Bazooka Joe's Avatar
Trade: Drywall
Hi folks,
..everything ive read has said to caulk between new tile and a tub after a shower/bath tile job, instead of grouting along the upper edge of the tub. Im wondering if thats the best thing to do. Ive always wondered if that grungy silicone thats always found in that location on older installations is because water has found its way to the caulk line from the back.
Opinions?
thanks very much
Mike
Bazooka Joe is offline
Old 10-16-2008, 06:48 PM   #2
bathroom guru
jarvis design's Avatar
Re: Caulk At Tubline... ...or Grout?
The reason caulking is recommended is because of the movement between the tub and the surround. Unless you are installing a cast-iron tub with mud walls, steel enamel and acrylic tubs, no matter how well they are installed, will move somewhat. Personally, I agree with you that grout would be a lot better, however, I have seen the result of not applying caulking - cracked grout which lets moisture in behind. What I normally do is buy a tube of colour matched caulking when I am getting grout for the job - and simply caulk with it.
As always, I always recommend using concrete board behind your tile, Kerdi waterproof membrane, plus epoxy grout.
Cheers!!
jarvis design is offline
Old 10-16-2008, 07:25 PM   #3
K-C Contracting Services
tommymcollins's Avatar
Trade: contracting
ditto, colored caulk
tommymcollins is offline
Old 10-16-2008, 07:36 PM   #4
Mellison's Avatar
Trade: Home Improvement General Contractor
The seam in question should be quite tight. Add grout then follow up with a skinny bead of caulk.
Mellison is offline
Old 10-16-2008, 07:42 PM   #5
Money Changer
bert0168's Avatar
Trade: Residential Remodeling
These guys are right, caulk the tub/wall joint.
I have seen tile guys do this to exactly match caulk to grout:
Take a tube of silicone or siliconized latex caulk and dump the whole thing onto a piece of plywood.
Remove the plunger cap or get these http://buy.epoxyheads.com/emcatu.html
Using the caulk you dumped out, mix in the dry grout powder you used on the tile until the color matches that of the dried grout (applied to the tile)
Put the "custom colored " grout into the tube and caulk away.
bert0168 is offline
Old 10-16-2008, 07:58 PM   #6
Tile Contractor
Bud Cline's Avatar
That advice right there is just so wrong.
Bud Cline is offline
Old 10-16-2008, 07:59 PM   #7
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Yow.
Or just spend $3.75 and buy a tube of the grout manufactuers color matched caulk when you buy your grout. (Sorry, wise ass alert)
Mike Finley is offline
Old 10-16-2008, 08:06 PM   #8
Alwaysconfusd11's Avatar
Uhh $8.75! And thats just to much IMO.
Just do it right and caulk it.
Alwaysconfusd11 is online now
Old 10-16-2008, 08:16 PM   #9
"da Whale don't hesitate"
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
All plane changes should be caulked, period. Caulking over grout is a horrible idea.
Precision Flooring
(772) 237-9900
PrecisionFloors is offline
Old 10-16-2008, 08:17 PM   #10
What about back splashes? Do any of you grout then clear silicone over it where the tile meets the CT?
Old 10-16-2008, 08:23 PM   #11
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
Indeed. Lots of bad advice floating around.
There'd better be a gap for the caulk or it's going to start peeling in no time.
As Mike said--why not just pick a grout manuf. that has matched caulks for their colors.?
Sealant joints are control joints--for all plane or material changes.
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 10-16-2008, 08:26 PM   #12
Builder/Remodeler
ChrWright's Avatar
Caulks on the surface of anything aren't going to do any good. It's not meant to be a coating--It's meant to create a flexible fill for a gap.
No gap... no good.
Old 10-18-2008, 02:28 AM   #13
Trade: Drywall
thanks for the insight guys. ...will caulk it.
Old 10-18-2008, 03:15 AM   #14
Brock's Avatar
Trade: Residential Remodeler
1. Fill tub with water.
2. Silicone (pick your color)
3. Tell home owner to wait 24 hours and empty tub.
4. Don't go back because you wont get a call back.
Brock is offline
Old 10-22-2008, 02:32 PM   #15
I builds'em
Winchester's Avatar
Trade: Renovations & Decks
I like this advice.
Winchester is offline
Old 11-07-2008, 11:29 PM   #16
AbsoluteBaumer
AbsoluteBaumer's Avatar
Trade: Tile Setter
it is definitely the proper procedure to silicone that transition from tile to tub. Also, watch out for the qualtiy of tile when doing this. If the tile is cheap and really thin, some thinner gauge tubs might flex when filled for a bath. This weight in the future could cause a "pull" on the cheap tile and crack it. Fill tub before siliconing to avoid this.
AbsoluteBaumer is offline
Old 11-08-2008, 12:07 AM   #17
AbsoluteBaumer
Trade: Tile Setter
Since the kitchen backsplash is a very visual location, i prefer to include that joint when i grout and silicone it once it has cured with clear.
Old 11-08-2008, 01:07 AM   #18
I builds'em
Winchester's Avatar
The reason the caulk gets so grungy that has been explained to me in the past (and makes sense) is that when the moisture behind the tiles gets down to the caulk it has nowhere to go and that breeds bad stuff. Ideally grout would be the better choice because it would let out the moisture. However, like everyone has said, grout will crack because tubs can move.
Something like this schluter product would probably be better, but obviously more expensive:
However, unlike caulk it is maintenance free
Old 12-11-2008, 07:34 PM   #19
forsmant's Avatar
Trade: General Contracting, Remodeling
Do you suggest caulking the vertical corners of a shower with matching grout caulk or to fill them with grout?
forsmant is offline
Old 12-11-2008, 08:50 PM   #20
Tile Contractor
Bud Cline's Avatar
ALL changes in plane or when meeting dissimilar materials should be caulked.
Grout Vs. Caulk? Liquid Force Ceramic & Stone Tile 28 06-22-2011 10:57 PM
Packing grout behind caulk Mike Finley Ceramic & Stone Tile 24 07-11-2009 02:18 AM
Tile & Grout work Paddy General Discussion 2 10-14-2008 09:17 AM
Grout Width and sealing. jritkes Flooring 6 09-28-2008 08:23 PM
Stone dust for grout MinConst Kitchens & Baths 6 08-17-2008 05:17 PM
