Trade: construction
Building A Shower Bench When Using Backer Board On Walls?
do you guys hot mop the bench when using backer board on the walls instead of floating the walls?
should i just hot mop the floor only and use densShield on the bench? if i do hot mop bench and lath and mud it i cant picture in my head how to transition from lath/mud to backer board. any help would be awesome hot mop guy comes tomorrow 11am and i need to still build the dang bench. thanks fellas |
Remodeling GC
Re: Building A Shower Bench When Using Backer Board On Walls?
try www.betterbench.com easy to attach and you can kerdi along with the walls.
Kevin Basement Finishing Highlands Ranch Colorado Littleton Colorado, Basement Remodeling Kitchen Remodeling Denver |
Sean
Check out Schluter they have some of the best tile shower systems around - is hot mopping even allowed still?
Tile Contractor
Re: Building A Shower Bench When Using Backer Board On Walls? |
bathroom guru
Heres a bench for you to look at. Framed with 2x4's, top of bench has 3/4" plywood, 1/2" concrete board - then Schluter Kerdi.
At this stage, the shower is 100% waterproof. No other better system out there!! |
bathroom guru
Heres the final product
Commercial Tile setters
Trade: tile and stone
Hot Mopping? I have never seen any tile man waterproof a shower using this method.
Why? Why would anyone do this with all the products and methods available on the market. I'd love someone to come on here and explain. I wouldn't even use it on a roof anymore. This thread has to be a joke. No serious tradesman would go this route. Whatever!!! |
Chief Toilet Mover
Trade: Bathroom Remodeling
Jarvis - you water proof all your showers like that or just the steamers like that one?
Nice job, I always like bond on bond patterns, they always look elegant. |
Tile Contractor
"Hot mopping" of showers is something that has existed for a long long time in some areas of the country and installers in those areas would have it no other way. California followed by Arizona leads the pack in hot-mopping showers - most all showers, steam or not.
Personally I wouldn't follow the California methods, never have, but many do. There is nothing wrong with hot mopping a shower but I agree: "Why would anyone do this with all the other great products and methods available on the market"? I would be curious to know what the cost is to hot mop a shower. Care to share that info chopper?
#10 | |
bathroom guru
Re: Building A Shower Bench When Using Backer Board On Walls?Quote:
Waterproofing with Kerdi is the only way I will construct a tile shower. I probably go a little overboard - walls/ceiling are concrete board - then Kerdi. Thanks by the way! Mike Jarvis |
Trade: construction
would love to try a kerdi shower one day. but yeah here in cali hot mop showers pans is just what we do. cost 325...this is an upstairs apt which added to cost. they come in and float a pitch with mortar...then hop mop.
so anyone have advice on how to float the bench. i know its not the best way but im going to use densShield and redgaurd on the walls...i dont have the skills to float walls and too late to buy and use kerdi. p.s. im water testing the hot mop and used 80grit on the wall paint so i can primer the glossy surface...thats why you see white dust in the water. |
Remodeling GC
I only do kerdi showers now with easyboard behind it.
bathroom guru
Re: Building A Shower Bench When Using Backer Board On Walls?I was wondering about that product. Do you find it works well? I now use concrete board behind Kerdi but have seen the Easy Board and thought about trying it. Any pros or cons?? thanks Mike Jarvis |
Its all ball bearings
Trade: Tile
Mike, I'm with ya (and kevjob) and Kerdi everything. However, I've been using DensShield instead of CBU. I like it. SO much lighter and I haven't found any cons.
Convenience factor for me since I get it at the same place as DensArmor, which I use in all non wet location bathroom remodels as well.
Angus L+M+O+P=C ![]() "Promise only what you can deliver. Then deliver more than you promise" |
Remodeling GC
Jarvis, easyboard by itself flexes too much for my liking but after it gets kerdi it becomes rigid. No down side yet especially carrying all 6 sheets with one hand.
![]() only thing that bugs me about denshield is 32 inches wide where alot of showers I do are 36 inches.
Builder/Remodeler
Re: Building A Shower Bench When Using Backer Board On Walls?Beautiful craftsmanship Jarvis. Very well done.
![]() Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50 www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here |
"da Whale don't hesitate"
Trade: Hard Surface Flooring
Nice looking job Jarvis!
I still don't get behind using just drywall though...I've done it and had no problems but it just don't sit right for some reason I've been wanting to try out the easy board also.
Precision Flooring (772) 237-9900 Tile, Hardwood, Laminate, and Resilient Installation, Sales & Repair - "We do it right the FIRST time" |
#18 |
Trade: Tile
It's also available in 4'x5' and 4'x8' sheets.
#19 |
Trade: construction
man lots of talented people here wish someone could help with da bench....i just keep reading "i only kerdi". next bath i will try that too but could really use advice on the bench
down here in cali Lowes sells densGuard in 32" wide and its blue. tile store sells densShield in 48" wide and its grey. can anyone give advice on how to float this bench? should i not even staple the lath? cx on john forum said i could bend the lath up above the bench and staple it there....but then i will have to shim out the densShield over the lath. that wont work for me cause i need to be at the same distance out from the wall as the drywall still on the wall. thanks for any help guys...peace |
#20 |
Tile Contractor
I don't think anyone (including me) understands what the hell your talking about: "float out the bench".
What is it you want to do? Is that the bench you are talking about in the picture above? Why does that bench need to be "floated out"? Why would it need lath?
| What are they doing using my pictures and linking to my site? | Mark Daniels | Technology | 19 | 08-04-2011 07:39 PM |
| collated screw guns for backer | platinumLLC | Flooring | 3 | 12-01-2008 07:11 PM |
| Shower pan | Bill | Plumbing | 20 | 09-29-2008 08:40 PM |
| Floating Basement Walls | McMasters | Framing | 15 | 08-26-2008 11:43 PM |
| ??? Whats the best way to spread the news about your company? | jmgrahamjr | Marketing & Sales | 21 | 06-24-2008 04:46 AM |
