Breaking Tile Edges When Cutting
Old 03-07-2008, 09:48 AM   #1
Ponsse's Avatar
Trade: Electrical
Hey Guys, I'm an electrician by trade but my wife wanted ceramic tile in our bathroom. I bought one of those cheap plastic tile cutters with about a 4 inch diamond blade (it's a wet saw). My problem is that when I get to the end of my cut, the last 1/8 inch or so seems to break off no matter how slow I'm pushing it. It's not a big problem cause it's usually under the mopboard anyways, but I need a perfect edge in the doorways. I started cutting in about 1/4 inch from the other side first and then reversing it and cutting from the other way. It works but I was wondering if there was a right way to do it, or if it's just because of my crappy saw?
Ponsse is offline
Old 03-07-2008, 10:14 AM   #2
Dustball's Avatar
Re: Breaking Tile Edges When Cutting
Is your guide exactly parallel with the blade?
Dustball is offline
Old 03-07-2008, 10:31 AM   #3
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
It's the saw.... Those little throw away saws don't have the a## to make cuts on thicker material without chipping out.
They're okay for thinner wall tile, usually.
Small blade, weak motor.
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 03-07-2008, 12:08 PM   #4
Professional Remodeler
firemike's Avatar
Sometimes you can get away with cutting a 1/4" to 3/8" into the tile, flip it around, and cut the rest of the way from the other side. Sometimes it works, sometimes it doesn't, depends on the saw and tile. If the fence/table/sawblade isn't perfecetly square you may have problems.
-Mike-
Falcon Contracting
Residential - Commercial
firemike is offline
Old 03-07-2008, 12:26 PM   #5
Its all ball bearings
angus242's Avatar
Trade: Tile
You can always rent one from HD. If you only have a few critical cuts to do, I think you can even rent for 4 hours. I believe it's around $50 for 24 hours.
angus242 is online now
Old 03-07-2008, 04:54 PM   #6
Knowledge Factory
Floordude's Avatar
Dress the blade, by dry cutting a brick.
My MK will start that, and I grab a brick and turn the water off, and I'm back in business. I will also squeaze the tile from the sides, at the end.
http://www.AustinFloorguy.com
Floordude is offline
Old 03-07-2008, 06:08 PM   #7
Tile Contractor
Bud Cline's Avatar
On that type saw the last 1/8" (or so) is chipping because the saw blade is cutting from below and before it can get to that last little edge the vibration breaks the tile at the surface. Try turning the piece over and see if that produces chips on the top edge that are too bad to live with. If so then it's a bad idea. If not, then you can make those cuts you need up-side-down.
Bud Cline is offline
Old 03-07-2008, 08:36 PM   #8
Ponsse's Avatar
Trade: Electrical
Thanks Guys, I'll try all your tricks and see what will work for me.
Thanks Again!!!
Ponsse is offline
Old 03-08-2008, 08:11 AM   #9
orson's Avatar
Trade: Kitchen & Bath
It may not be the blade at all, I have an MK 370 that does the same thing because the tray is not flat. never really found a good solution other than cutting halfway through a tile and flipping it around since the depression was at the back of the tray.
orson is offline
Old 03-12-2008, 05:29 PM   #10
Jay22's Avatar
Trade: Tilesetter
I didn't know that there was a cure for that until now.
Thanks guys
Jay22 is offline
Old 03-12-2008, 09:55 PM   #11
JazMan's Avatar
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
In addition to all the good tips above, including the cheap saw, check to see if the blade has a slight warp to it. Look at it straight on as it comes to a stop.
Jaz
Tile 4 You llc
KERDI Shower
specialist...DITRA Installs...
www.tile4you.com
JazMan is offline
Old 03-12-2008, 10:36 PM   #12
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
I was setting some 5/4 13x13 today and was having the chipping problem also. I notices the blade had a warp/wobble to it. The tiles broke at the end..doh! Is the blade beat or is there a fix for this dilemma?
Norman Sharp
http://www.sharpimprovements.com
Norrrrrrrrrrrrm is offline
Old 03-13-2008, 01:10 AM   #13
Tile & Marble Contractor
Ceramictec's Avatar
Trade: Tampa Tile Contractor
this will usually do the trick I agree.
-Brian-
Brandon Lutz Bradenton Tampa Oldsmar Westchase New Port Richey Seminole St. Pete Wesley Chapel Sarasota
website: www.ceramictec.com
Ceramictec is offline
cutting porcelain tile tomcutt Ceramic & Stone Tile 6 10-31-2007 06:53 PM
Cutting ceramic tile? Rugger Electrical 12 02-24-2007 01:13 AM
Determining Manhours for rolling vs. cutting - your suggestions would be helpful Zeebo Painting & Finish Work 9 06-02-2006 06:12 PM
Cutting in curved drywall edges aoc Painting & Finish Work 4 02-20-2006 07:55 AM
Cutting Existing Tile. kpikul Remodeling 16 02-05-2006 12:30 AM
