Best Way To Get Dirt Out Of Grout Lines Without Scraping It Out?
Old 01-10-2012, 12:57 PM   #1
kilani's Avatar
Trade: painting, flooring, plumbing,framer, carpenter
I have had dirt build up in my grout lines for a bout a yr, used a steamer, scrub brush, and a mop, came out pretty good but doesn't match up exactly with my wall grout, not really wanting to scrape this whole floor cuz its a lot of tile. Is the any suggestions?
kilani is offline
Old 01-10-2012, 01:07 PM   #2
Remodeling GC
kevjob's Avatar
Rewards Points: 6
Re: Best Way To Get Dirt Out Of Grout Lines Without Scraping It Out?
You could use a grout stain/sealer like this one: http://www.custombuildingproducts.co...er=pro&lang=en
Make sure to read instructions may have to use sulfamic acid cleaner 1st.
I had to use this when about 2 years ago I had issues with Customs grout colors being splotchy, works like a charm.
Kevin
www.ObrienConstructionDenver.com
kevjob is offline
The Following User Says Thank You to kevjob For This Useful Post:
Old 01-10-2012, 01:29 PM   #3
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Welcome to the adverse affects of cementitious grout.
Try some hot water with OxyClean and a scrub brush. That should get it topically as clean as it can be. The rest of the grime remaining has already embedded itself into the grout. I never suggest using acid unless you are familiar with what you're doing. The experienced person might have success without issue but the inexperienced person can not only mess up the grout, they can affect the thinset, possibly tile and can be harmful to the user.
Skip the acid and go straight to the grout sealant. It will solve the grout color issue, seal the existing grout and be more stain resistant than the original installation.
http://www.mapei.com/us-en/product-d...62&IDLinea=102
Angus
angus242 is offline
Old 07-05-2012, 01:00 PM   #4
SaniGLAZE's Avatar
Trade: Tile and Grout Restoration
Your best option would be to restore the grout with a non porous grout overlay so that you would have uniformity with the wall grout less of a a maintenance hassle in the future by eliminating the groutís porosity.
SaniGLAZE - Tile and Grout Restoration Services
SaniGLAZE is offline
Old 11-15-2012, 09:43 PM   #5
plazaman's Avatar
Rewards Points: 1,202
what do you mean by overlay? right on top of it ?
plazaman is online now
Old 11-15-2012, 09:49 PM   #6
CO762's Avatar
Trade: Organic Mold Farmer
Rewards Points: 4,534
Break out some sooper troopers from benning, give them tooth brushes and any variant of oxyclean and a case of beer later, you'll be OK.
CO762 is offline
Old 11-19-2012, 09:15 AM   #7
SCOTT@SCRSLLC's Avatar
Trade: Tile/Grout & Hard Surface Cleaning
It would also depend on how deep the grout line is saturated. If the stain is all the way through, there's not much that you can do to "lift" it out. If that's the case, the grout will probably need to be removed and the joint re-grouted.
It also depends on what the stain is. Mineral: Use a mild acidic, then neutralize with an alkaline and remove with pressure wash/vacuum. (Never use acidic cleaner on natural stone though!) Grease, dirt, oil, etc: A good alkaline based emulsifier and possibly some citric solution to loosen the stain before pressure washing.
Once removed, you may want to consider some kind of sealant, especially if there is a chance of this happening again.
There are some companies out there who use green solutions combined with high pressure and vacuum to remove stains like these.
SCOTT@SCRSLLC is offline
Old 11-19-2012, 09:21 AM   #8
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 12,510
It's like cleaning a carpet...not so much lifting it out as it is driving it further in.
Inner10 is online now
Old 11-19-2012, 09:27 AM   #9
Meaning what?
Old 11-19-2012, 09:55 AM   #10
Tool Guy To The Stars!
Sprung831's Avatar
Trade: Tile Tools
Rewards Points: 103
In some cases I've been able to use a stone poultice. Spread the poultice and cover it with plastic wrap. Make sure it's tested in an inconspicuous area, just in case it pulls pigment as well.
Or, the trust ol' Magic Eraser???
Sprung831 is offline
Old 11-19-2012, 09:13 PM   #11
Orlando Car
Floormasta78's Avatar
Trade: certified floor covering installer.
Rewards Points: 1,154
I recommend miracle Mira soap.. it's really good and easy on the hands of gentle men like us..
http://www.facebook.com/#!/certifiedfloorcovering
Certified Floor Covering
Serving All California
( 510 ) 760 - 6810
Floormasta78 is offline
epoxy grout bluebird5 Tiling 17 03-31-2011 05:30 AM
Grout seperation on 2nd floor deck tile9 Tiling 4 08-23-2010 05:57 AM
question on non shrinking grout stacker Masonry 2 09-10-2009 07:14 PM
grout removal and replacement EricTheHandyman Tiling 16 03-25-2009 07:13 AM
Grout Width and sealing. jritkes Flooring 6 09-28-2008 07:23 PM
