Best Caulk For Showers???
Old 11-16-2010, 12:02 AM   #1
loumatt's Avatar
Trade: Tile setter
I was interested in possibly getting opinions on what caulks work the best in tub and shower areas?
Seems like the 'water clean up' ones always seem to crack or attract mold. They're are all big on guarantees but its a major pain to r&r once they fail.
Any brand recommendations that are fairly easy to work with?
Thanks
loumatt is offline
Old 11-16-2010, 12:21 AM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Best Caulk For Showers???
Only use 100% silicone. I use Laticrete Latasil colored to match the grout.
Angus
angus242 is offline
Old 11-16-2010, 12:45 AM   #3
Educated Guesser
tile9's Avatar
Trade: Tile and Carpentry
Rewards Points: 25
Most, if not all, nowadays, grout manufacturers provide color matching caulk. And all the ones I've used in the past 2 years or so have been siliconized. They may not be 100% silicone as angus prefers, but they are superior to any acrylic or latex caulking in wet areas.
To be specific, the grout manufacturers that I refer to are Lacticrete, Mapei, and Custom.
If you are just worried about the horizontal line between the tub and tile, or a prefab shower pan and tile, any silicone caulking that matches the color of the tub/pan will work. Ask the HO if they prefer caulk that matches the tub/pan or the grout. Easier to ask than assume and having to remove later.
tile9 is offline
Old 11-16-2010, 01:21 AM   #4
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Acrylic caulks will fail much sooner than 100% silicone.
For the added piece of mind and longevity, 100% silicone is the only way to go.
Well, that is, unless you eliminate the caulk joint altogether.
Angus
angus242 is offline
Old 11-16-2010, 01:36 AM   #5
loumatt's Avatar
Trade: Tile setter
Thanks for the useful info.
loumatt is offline
Old 11-16-2010, 01:37 AM   #6
Educated Guesser
tile9's Avatar
Rewards Points: 25
Go on, angus, insert your Schluter plug. We know you want to...
tile9 is offline
The Following User Says Thank You to tile9 For This Useful Post:
ApgarNJ (11-16-2010)
Old 11-16-2010, 06:31 AM   #7
Tile Contractor
HS345's Avatar
Trade: Ceramic and Natural Stone Tile Contractor
Rewards Points: 886
Another vote for 100% silicone. I like Color Sil by Color Rite.
Custom Building Prods is supposed to have come out with a color matched 100% silicone that is not as shiny as other silicones, and is rated for traffic. Making it perfect for expansion joints. Haven't tried, or seen it yet.
It is on their website: http://custombuildingproducts.com/Pr...er=pro&lang=en
Greg
HS345 is offline
Old 11-16-2010, 06:37 AM   #8
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
I assume you order Color Sil direct. What do they charge per tube with shipping?
Angus
angus242 is offline
Old 11-16-2010, 06:50 AM   #9
Tile Contractor
HS345's Avatar
Rewards Points: 886
Yep, you call them direct. Shipping on one tube is kinda steep, I think about 12 bucks. Best if you order a few tubes at a time, I have ordered six tubes at a time, and if memory serves, shipping was the same as one tube.
They have color charts on hand for major grout manufacturers, and will color match over the phone. They will also send you a color chart for their silicones which is actual dabs of silicone for each of the forty four colors.
Greg
HS345 is offline
Old 11-16-2010, 06:56 AM   #10
General Contractor
greg24k's Avatar
Rewards Points: 7,256
I been using CRL Caulking by C.R Laurence Co. I think it's best caulking on the market for glass and shower applications.
greg24k is offline
Old 11-16-2010, 12:07 PM   #11
astor's Avatar
Trade: FI
Rewards Points: 704
Not that I use a lot of %100 silicone, but occasionally I have used Kampel Axiom 25 and got great results. Limited of colors though.$12+S&H per tube
astor is offline
Old 11-16-2010, 04:19 PM   #12
jackman's Avatar
Trade: Remodeling Specialist
I think the absolut best silicone caulk is "LEXEL" , it costs around eight dollars a tube.
jackman is offline
Old 11-17-2010, 05:56 AM   #13
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
Rewards Points: 1,135
Lexel isn't silicone last I checked. It also stays tacky.
I usually use NP1 if I have the time to let it cure. Moisture cured urethane products are great. It'll far outlast silicone, but you do have a pretty lengthy cure time before putting a shower into use. I'm talking at least 3 days. I've got NP1 sealing cast iron tub to ceramic walls and the corners of those walls in a few tubs. I have Latisil in a couple more. The Latisil is starting to peel in spots on the tub top after only a year of use. The NP1 is virtually indestructible.
gideond is offline
Old 11-17-2010, 06:19 AM   #14
Tile Contractor
HS345's Avatar
Rewards Points: 886
Latisil peeling after one year? Sounds like installer error. I've seen properly applied silicone last for years.
The key to a durable silicone joint is to not tool it down to a feather edge, i.e. don't simply smear it with your finger.
Greg
HS345 is offline
Old 11-17-2010, 07:14 AM   #15
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
I agree with Greg. Actually, if any well known product fails, chances are pretty high that the installer didn't bother following the installation instructions.
Angus
angus242 is offline
The Following User Says Thank You to angus242 For This Useful Post:
Frankwhoa (11-19-2010)
Old 11-17-2010, 08:38 AM   #16
duburban's Avatar
Trade: building
Rewards Points: 1,294
i always tool with my finger, what are you proposing? leaving the bead as if it just came out of the tube? or tool with less feathering profile?
duburban is offline
Old 11-17-2010, 08:44 AM   #17
Tile Contractor
HS345's Avatar
Rewards Points: 886
If you can run a good bead right out of the tube, that is the best way. If not, a non feathering tooling device and solution is the way to go.
Greg
HS345 is offline
Old 11-17-2010, 10:33 AM   #18
covaltleveling's Avatar
Trade: floor leveling
Rewards Points: 150
100% sil., Custom Building Products possibly....
covaltleveling is offline
Old 11-17-2010, 08:38 PM   #19
Paul
PrecisionFloors's Avatar
Trade: Hard Surface Flooring
Rewards Points: 1,004
Denatured alcohol and my finger is all I tool silicone with. Works like a champ.
Precision Floors
(772) 237-9900
PrecisionFloors is offline
Old 11-18-2010, 05:58 AM   #20
gideond's Avatar
Nope used the product just as directions say to. Even used the primer for it to be sure on the last one. All those tubes were from the same case though so I'm starting to wonder if maybe it was a bad batch of product. Daltile seems to be keeping this stuff on the shelf for years before selling it. I'm not saying the whole seal has failed in either case, just that the outside edge has lost adhesion. The seal all the way back into the wall is still intact.
gideond is offline
The Following User Says Thank You to gideond For This Useful Post:
jackman (11-18-2010)
Whats a good caulk gun for concrete epoxy? Project_Pat Tools & Equipment 18 01-02-2012 06:42 PM
Primer Cracking over Caulk go_hercules Painting & Finish Work 11 01-19-2011 07:39 PM
Tiled Shower - Caulk roofny Kitchens & Baths 19 10-17-2010 04:21 PM
Best tub & tile caulk Jer Flooring 7 04-08-2010 11:24 AM
Caulk quality Ralph6 Windows, Siding and Doors 5 09-04-2008 05:33 PM
