Bathroom Tile Layout
Old 09-05-2017, 01:48 PM   #1
RookiePlumber's Avatar
Trade: HVAC install and repair
Rewards Points: 260
I'm tiling my bathroom walls with 12x24 Home Depot porcelain tile.
I've created a layout with a 25% offset to create that "subway tile" look.
My layout attempts to do the following:
1. Maximize the number of full tiles
2. Eliminate small tile cuts wherever possible (the smallest tile cuts end up being like 9.5".)
3. All spacing is taken into account - both tile spacers and tile and grout thickness for corners
I move the center of the wall by 5-10% to accomplish the above. By center I mean where the center tile sits.
Any other things I should be thinking about? This is more complicated than I initially thought it would be.
If my question should be in another sub forum please let me know.
Thanks
RookiePlumber is offline
Old 09-05-2017, 02:01 PM   #2
Rewards Points: 260
Re: Bathroom Tile Layout
Also would a smaller offset help with the doming issue?
Old 09-05-2017, 05:49 PM   #3
avenge's Avatar
Rewards Points: 2,712
If the tile has any bow you should be doing 1/3 not 1/4.
avenge is online now
The Following User Says Thank You to avenge For This Useful Post:
TNTSERVICES (09-07-2017)
Old 09-05-2017, 08:29 PM   #4
Rewards Points: 260
Why is that? I thought the lower the offset the further the center would be from the edges of the adjacent tile.
Old 09-05-2017, 11:55 PM   #5
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
You are over thinking it. go 1/3 offset coming off the primary sight line (what you see when you open the door and look in.)
Lay it out so you are about even at the back wall and the doorway. If you are doing 12x24 they are usually somewhere around 23 13/16" so cut at 7 15/16 for your 1/3 tile the other will end up 15 7/8 use a: 1/3, 2/3, Full, from the primary sight line. what ever it happens to be along toilet/vanity wet wall is fine. This will give you the best look. if you have a vanity, base your patern on what ever is the most manageable "L" cut at that corner to determine which tile you need to start with.
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
The Following 3 Users Say Thank You to charimon For This Useful Post:
RookiePlumber (09-06-2017), TNTSERVICES (09-07-2017), Wile E Coyote (09-06-2017)
Old 09-06-2017, 07:31 AM   #6
Rewards Points: 260
Originally Posted by charimon View Post
. If you are doing 12x24 they are usually somewhere around 23 13/16" sl
You are right - 11 3/4" x 23 1/2".
Thanks for pointing out the size inconsistency!!!
Old 09-06-2017, 04:02 PM   #7
Rewards Points: 260
Started tiling using a 1/3 running bond pattern.
Seems pretty level throughout.
Some corners have ridges, I think that's because I back buttered some corners better than others.
I wiped off most of thinset from the tile with a warm wet sponge. I used a taping knife to clean the thinset from the grout joints. Is a more thorough cleaning required?
My plan is to layout all the whole pieces first then come back to install the cut pieces. I've got a 10" tilesaw.
Old 09-06-2017, 05:39 PM   #8
Talking Head
EthanB's Avatar
Rewards Points: 28
12x24 I'd be using a leveling system, but it might not help much if they're bowed(which most HD crap is). You should also get some good shims, those look like the cheap QEP shims that aren't consistent and will actually crush a fair bit. Look into something like the Barwalt horseshoe shims. They are so much easier to work with.
Planer.....
EthanB is offline
The Following 2 Users Say Thank You to EthanB For This Useful Post:
overanalyze (09-13-2017), RookiePlumber (09-06-2017)
Old 09-06-2017, 07:20 PM   #9
Tom M's Avatar
Rewards Points: 6,034
Should have primed before tiling.....
Tom M is online now
Old 09-06-2017, 07:59 PM   #10
Rewards Points: 260
Tom, by prime do you mean paint? I've already primed and painted the walls where paint is going.
Old 09-06-2017, 08:02 PM   #11
avenge's Avatar
sent from my iPhone using Tapatalk
Seems pretty level? It either is or isn't.
Old 09-06-2017, 08:04 PM   #12
Rewards Points: 260
Yeah they are qep shims. I found some horseshoe shims on Amazon. Ordered em.
What kind of leveling system do you recommend?
Thx!!
Old 09-06-2017, 08:22 PM   #13
Xtrememtnbiker's Avatar
Trade: General Remodeling
Rewards Points: 614
Thx!!
RLS
http://www.contractorsdirect.com/Raimondi-RLS-Clips-Red
Xtrememtnbiker is offline
The Following 4 Users Say Thank You to Xtrememtnbiker For This Useful Post:
AustinDB (09-13-2017), overanalyze (09-13-2017), RookiePlumber (09-07-2017), TNTSERVICES (09-07-2017)
Old 09-06-2017, 08:34 PM   #14
Rewards Points: 260
It's definitely not perfect. There are some ridges in certain spots.
Old 09-06-2017, 09:18 PM   #15
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,130
When ever I do large format we do 1/3rd 2/3rd full tile seems you only have 1/3rd then full tile. if that makes sense.
Anderson is offline
The Following User Says Thank You to Anderson For This Useful Post:
Old 09-06-2017, 09:22 PM   #16
Anderson's Avatar
like this
Anderson is offline
The Following 2 Users Say Thank You to Anderson For This Useful Post:
overanalyze (09-13-2017), sparehair (09-07-2017)
Old 09-06-2017, 09:39 PM   #17
Rewards Points: 260
This is what I thought a 1/3 offset was - this is my first tile job so I don't know jack and I'm happy to take advice...
Old 09-06-2017, 10:16 PM   #18
avenge's Avatar
He was referring to the drywall under the tile.
When you said level I assume you meant horizontaly, what you mean is flat which is impossible to be level.
The pic Anderson posted is the same method I use. Every 4th row is a repeat.
Old 09-06-2017, 10:53 PM   #19
Rewards Points: 260
Can I prime with regular primer? Is the purpose to provide a moisture "shield"?
It's not flat.
Is there an advantage Anderson's layout? More appealing to the eye?
Thx
Old 09-06-2017, 11:24 PM   #20
Rewards Points: 260
Can I switch to your 1/3, 2/3,
full tile layout on the other three walls and not look weird? I'm not going to undo what I've done already.
beadboard wainscotting for bathroom MarkJames Finish Carpentry 10 05-26-2013 06:21 PM
Ready for Tile Bob. Tiling 1 11-18-2012 05:30 PM
Feedback on 1st bathroom tile job danny7633 Tiling 37 08-14-2010 08:54 AM
Putting Tile in My Bathroom SHAWNPAINTS Flooring 24 01-11-2009 12:52 AM
