Back Butter? - Tiling - Contractor Talk
Back Butter?
Old 08-16-2018, 02:58 PM   #1
Radical Basement Dweller
Robie's Avatar
Rewards Points: 6,390
Back Butter?
Doing a 28 sq.ft half bath. The tile they chose for the floor is similar in size to subway tile but has a brick look to it and irregular sides/ends.
What size trowel do you like for this and would you back butter?
Thanks.
Democrats are doing more to undermine our country than Russians could ever hope to.
Robie is online now
Old 08-16-2018, 04:30 PM   #2
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 2,348
Re: Back Butter?
I would probably just use my 1/4" trowel as you can angle it to change depth, and always back butter if even lightly. Just feel like back buttering creates a better bond. If ceramic it gets a quick sponge to add water into the tile, before back buttering.
There are folks with far more experience tiling than myself though...like Angus.
Peter_C is online now
The Following 2 Users Say Thank You to Peter_C For This Useful Post:
Robie (08-16-2018), Snobnd (08-18-2018)
Old 08-16-2018, 05:53 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,751
Re: Back Butter?
Back buttered tile sucks when doing demo.
Tinstaafl is online now
B.D.R. (09-19-2018)
Old 08-16-2018, 06:24 PM   #4
Peter_C's Avatar
Re: Back Butter?
I can only hope someone says that about my work
The Following User Says Thank You to Peter_C For This Useful Post:
Tinstaafl (08-16-2018)
Old 08-16-2018, 06:28 PM   #5
tjbnwi's Avatar
Rewards Points: 5,400
Re: Back Butter?
If it is ceramic quick wipe with a damp sponge, tight back butter.
Porcelain, dry wipe, back butter. Wet cuts, you need to dry porcelain tile.
1/4” trowel should be fine. Make sure the floor is flat.
tjbnwi is online now
Robie (08-16-2018)
Old 08-16-2018, 08:02 PM   #6
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,287
Re: Back Butter?
What size tile? If they're 3x6 or something similar, forget the backbuttering and just get to it. Mix your thinset on the creamier side and work fast. Trowel size depends partly on how flat the floor is.
MarkJames is online now
The Following 4 Users Say Thank You to MarkJames For This Useful Post:
overanalyze (08-16-2018), Robie (08-16-2018), rustyjames (08-16-2018), Tom M (08-17-2018)
Old 08-16-2018, 09:09 PM   #7
tjbnwi's Avatar
Re: Back Butter?
Porcelain per the TCNA requires back buttering no matter the size.
The Following 4 Users Say Thank You to tjbnwi For This Useful Post:
Jaws (08-17-2018), Peter_C (08-17-2018), Robie (08-16-2018), TNTSERVICES (09-19-2018)
Old 08-16-2018, 09:24 PM   #8
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 5,284
Re: Back Butter?
Is this the tile?
https://www.tileandstoneexpress.com/...uthside48.html
Big Johnson is offline
Old 08-16-2018, 09:42 PM   #9
Robie's Avatar
Re: Back Butter?
Originally Posted by Big Johnson View Post
Almost. I think these are 3" x 9".
They look similar though
Robie is online now
Old 08-17-2018, 08:33 AM   #10
AustinDB's Avatar
Rewards Points: 876
Re: Back Butter?
Are you using clips?
AustinDB is offline
Old 08-17-2018, 01:20 PM   #11
MarkJames's Avatar
Re: Back Butter?
Sometimes I think they require it because so many folks can't mix or apply thinset worth a ch..
Old 08-17-2018, 03:47 PM   #12
Peter_C's Avatar
Re: Back Butter?
Skip to the 4:00 minute mark and it is clear back buttering is worth it.
mike d. (08-18-2018), Robie (08-17-2018)
Old 08-17-2018, 04:38 PM   #13
Robie's Avatar
Re: Back Butter?
Clips?
I have only tiled 10-12 times. Not sure I know what a clip is.
Robie is online now
Old 08-17-2018, 04:39 PM   #14
Robie's Avatar
Re: Back Butter?
https://www.youtube.com/watch?v=bF2SgLBF6qI
Yeah, watched that yesterday.
Robie is online now
Old 08-17-2018, 05:09 PM   #15
tjbnwi's Avatar
Re: Back Butter?
Originally Posted by Robie View Post
Clips?
Clips
That size tile you should not need them.
Robie (08-17-2018)
Old 08-17-2018, 05:17 PM   #16
Robie's Avatar
Re: Back Butter?
I always called them spacers. Yeah, have used them every time I've tiled...
Robie is online now
Old 08-17-2018, 05:35 PM   #17
Capra aegagrus
Tinstaafl's Avatar
Re: Back Butter?
Those aren't spacers, Rob. They're clips that grab the tile from both top and bottom so the faces are perfectly aligned with no "lippage". An Italian artisan might sneer at them, but they're a gift from heaven for us amateurs.
The Following 9 Users Say Thank You to Tinstaafl For This Useful Post:
asevereid (08-18-2018), AustinDB (08-22-2018), B.D.R. (09-19-2018), Bedfordboy116 (08-21-2018), onmywayup (08-18-2018), Rio (08-18-2018), Robie (08-17-2018), SouthonBeach (08-22-2018), Wile E Coyote (08-22-2018)
Old 08-17-2018, 05:45 PM   #18
Re: Back Butter?
All the non bbed tile clearly had coverage issues.
So my takeaway from that vid is: If you use ditra bbing doesn’t do much.
Old 08-17-2018, 06:44 PM   #19
avenge's Avatar
Rewards Points: 3,218
Re: Back Butter?
My takeaway is if I anticipate having to demo my own tile job don't back butter.
avenge is offline
The Following User Says Thank You to avenge For This Useful Post:
hdavis (08-17-2018)
Old 08-17-2018, 06:58 PM   #20
Peter_C's Avatar
Re: Back Butter?
I have a tile job coming up that has cracked grout and tiles. Chances are when I demo I will find there are coverage issues, and they are probably set on the plywood directly. I insist on using Ditra, and going below to shore up the flooring with blocking. Quality of work counts! For others there are hotel and chain restaurant tile jobs.
can i put 2 shower valves back to back in a 2x6 wall mthorp2112 Plumbing 3 03-09-2016 08:37 PM
need some ideas on what to do with the back of a kitchen island nickko Remodeling 4 07-27-2015 08:13 PM
Back braces anyone? VinylHanger Health & Safety 33 05-24-2013 01:21 AM
A look back at Fay & Scott.... PrestigeR&D Tools & Equipment 4 07-28-2012 06:44 PM
