Anybody Put Glass Tile In A Steam Shower?
Old 10-04-2009, 05:15 PM   #21
R&D Tile's Avatar
Trade: Tile installations
Re: Anybody Put Glass Tile In A Steam Shower?
With Hydroban forming a waterproof membrane under the thinset, how do you avoid the thinset showing darkening patches when the moisture gets behind the grout and into the thinset behind the glass tile?
Beats me.
Guess that could happen no matter what's behind it eh.
R&D Tile is offline
Old 10-04-2009, 06:20 PM   #22
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Welp, in my world that is considered a defect.
Mike Finley is offline
Old 10-04-2009, 06:21 PM   #23
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
Are you tearing things out to start over Mike?
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 10-04-2009, 06:26 PM   #24
Chief Toilet Mover
Yeah, we will be down to the studs.
Old 10-04-2009, 06:29 PM   #25
Builder/Remodeler
ChrWright's Avatar
Whose glass tile is it? Completely clear I take it?
I can't say I've ever done anything in a shower that was completely clear... and after this post I can see the potential problems.
I'd say the only guarantee would be epoxy grout--and even then I probably wouldn't risk it. Any chance they'd re-select?
Old 10-04-2009, 06:40 PM   #26
Chief Toilet Mover
I don't think epoxy grout would save you.
It's a no-no by almost all glass tile manufacturers. (warranty gone)
It's a steam shower so it's vapor not just surface moisture.
Old 10-04-2009, 06:50 PM   #27
Its all ball bearings
angus242's Avatar
Trade: Tile
I'd call first but perhaps consider urethane grout. Here are some advantages:
• Chemical, Stain and Mildew Resistant
• Pre-mixed, single-part product provides:
- Absolute consistency every time
- No field mixing mistakes
• Pigment-free formulation provides:
- Absolute color uniformity every time
- No batch control problems
- No fading, streaking or shading
• Provides fast and easy clean-up when compared to epoxy and cement grouts
• Excess product can be saved and used later (unless curing additive used)
• UV stable, non yellowing
• Semi flexible, low shrinkage and high crack resistant
• Self sealing
• Non-sag formulation for vertical surfaces
• No allergic reaction like epoxy grout
• One-way breathable grout can be used in areas exposed to hydrostatic pressures
• Ceramic, Porcelain, Glass tile and stone applications
• Indoor and Outdoor
• High moisture areas, swimming pool environments
• Commercial or residential
• Horizontal or vertical surfaces including floors, walls and countertops
• New grouting or renovation regrouting
• Wet or dry area applications
With specifically StarQuartz, they are about to release a formula that doesn't need an additive to speed the curing process (as currently does) and a line of grout specifically made for use with glass. I have a sample of the glass grout I am using over iridescent (clear) glass next week. Of course, I'm just doing a backsplash in a powder room so no moisture/vapor issues there.
Angus
L+M+O+P=Chttp://www.millan.net/minimations/smileys/einstein3.gif
"Promise only what you can deliver. Then deliver more than you promise"
angus242 is online now
Tile over existing shower surface SK Builders Ceramic & Stone Tile 16 07-06-2009 01:42 AM
how many courses for ceramic tile shower walls? Bazooka Joe Ceramic & Stone Tile 19 02-14-2009 11:06 PM
Frameless glass shower build, ideas please rotarex General Discussion 23 12-29-2008 09:57 AM
Window insida Tile Shower orson Remodeling 13 12-24-2008 10:45 PM
glass block entry to shower Mr. D Masonry 10 12-04-2006 02:14 PM
