Any Ideas On How To Light Glass Tile From Behind? IE Does Translucent Thinset Exist?
Old 06-18-2008, 03:55 AM   #1
mizzles's Avatar
Trade: tile
Hello
Turning to you guys for help, as I have been unsuccessful elsewhere!
I am lining the face of a bar with glass tile, and would like ideas on how to be able to have the entire surface of the tile "glow."
Undercabinet/countertop lighting would only light up the upper inches of the tile, so I am trying to figure out if it would be possible to light it from behind....
The tile could be attached to clear acrylic; however is there thinset available which is translucent? Does the traditional white thinset used for glass tile allow light to pass through?
Thanks, any help is appreciated.
Miz
mizzles is offline
Old 06-18-2008, 06:29 AM   #2
genecarp's Avatar
Re: Any Ideas On How To Light Glass Tile From Behind? IE Does Translucent Thinset Exist?
miz, you are going about this the wrong way, there are other ways to get the desired effect, glass tile is not the best approach for what you are trying to do, one option would be to use glass block, backlighting would then be easy, thats one of many ways.
genecarp is offline
Old 06-18-2008, 06:55 AM   #3
tileguy51's Avatar
Trade: TILE AND HARD SURFACE FLOORING
what about using plexi glass and clear silicone, try a little piece of it to see how well it will hold
Pain is temporary, pride is forever
www.mccowinflooring.com
tileguy51 is offline
Old 06-18-2008, 07:21 AM   #4
genecarp's Avatar
plexi will flex, alot, especially if someone leans into it. if you frame to stiffen it, you will see the framing.
genecarp is offline
Old 06-18-2008, 08:36 PM   #5
mizzles's Avatar
Trade: tile
Thanks for the replies!
The bar is going to be 8 feet long, in an 'S' or serpentine shape
A few more questions...
1- Could I use silicone instead of white thinset so the light would shine thru from behind, will it hold?
2- What about using lexan instead of plexi?
-- better for this purpose? (stronger)
-- can be done without framing from behind to avoid shadows?
-- strong enough to support a granite countertop?
-- can adhere tile to it?
3- type of light -- LED vs. fiber optics
4- creating a uniform glow instead of visible "strips" of lighting
Thanks!
mizzles is offline
Old 06-18-2008, 09:13 PM   #6
genecarp's Avatar
no no no no no no etc...
genecarp is offline
Old 06-18-2008, 09:14 PM   #7
genecarp's Avatar
my head is exploding, HELP
genecarp is offline
Old 06-18-2008, 09:24 PM   #8
Dan_Watson's Avatar
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Dan_Watson is offline
Old 06-18-2008, 09:29 PM   #9
genecarp's Avatar
thankyou ac
genecarp is offline
Old 06-18-2008, 09:34 PM   #10
Dan_Watson's Avatar
Well this was just scary
Old 06-18-2008, 09:36 PM   #11
...with naked dancing girls....?
neolitic is offline
Old 06-18-2008, 09:38 PM   #12
mizzles's Avatar
Trade: tile
I'm sorry guys
I've spoke to several local carpenters / cabinet makers and was getting no where so i thought I might find some help here.
Would someone be kind enough to explain what I said wrong and I will be more than happy to take the discussion elsewhere.
I am not doing this myself but in fact trying to figure out what needs to be done so I can speak to these guys more intilligently. I have in fact been told "it can't be done" by one guy so I thought I would do some due diligence to see if that is the case.
I guess the most important thing I need to know is if I can use silicone instead of thinset to adhere the glass tile onto the face of the bar and if using lexan would be appropriate (instead of plexi, which someone above said will flex if someone leans into it)
Sorry for the ignorance
mizzles is offline
Old 06-18-2008, 09:41 PM   #13
Dan_Watson's Avatar
Why do you want to backlight tile?
Old 06-18-2008, 09:45 PM   #14
genecarp's Avatar
mizz, sorry if we came off a little rude, its just that the job that you are describing is the type of job that any qualified pro could design and build for you, your questions indicate that you have know idea how to proceed with this project, therefore you are not representing yourself as a proffessional, which is what this site is for, PROFFESIONALS. diy site may be a better fit for you, good luck G
genecarp is offline
Old 06-18-2008, 09:56 PM   #15
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
The original question said the face of the bar, I would take that to not mean the bar top but the face.
How much of the face surface needs to light up? If it's just a small area relative to the rest, you can use white plexi-glass, 1/4" thick. Light it behind with a flourescent fixture or whatever you want. The white plexi will spread the light pretty evenly. Silicone will yellow over time. You might instead apply the glass tile with non-yellowing varnish instead. Pour it on the plexi and put the tile in place, let it harden. You can buy 4'x8' sheets of plexiglas from a good glass company in any color you want.
Mike Finley is offline
Old 06-19-2008, 02:31 AM   #16
mizzles's Avatar
Trade: tile
Mike Finley - thank you, your advice is helpful. To answer your question, I would like the entire face of the bar to light up. Not brightly, but a soft uniform glow. I noticed you said "if it's just a small area" - would your suggestions not work for the entire face of the bar? Is there any advantage to using plexiglass (acrylic) over polycarbonate sheets?
Alwaysconfusd11 - I want to backlight the tile so I can create a uniform glow on all the glass tile on the face of the bar - I think it would be a superb and unique effect.
genecarp - when you say "any qualified pro could design and build for you" that is not the case. I have met 3 professionals & called several more and gotten nowhere with them. One in fact told me it couldn't be done. Perhaps your expertise level and experience is more.
Miz
mizzles is offline
Old 06-19-2008, 07:31 AM   #17
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
The application you describe will be very expensive, FWIW.
I've done a lot of custom appplications with tile, but I can't think of any method of construction to back light tile on a radius that I would be confident a client would be happy with.
My guess is lucite panels, custom made to follow your radius, with a custom LED gun from either the base or top of the panel.
Here's a flat panel application from a basement we did 5 years ago:
Each of these columns has two clear panels with a computer controlled panel of LEDs at the base. (They could be made any color, pulse, flash, fade in/out, etc.)
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 06-19-2008, 08:46 AM   #18
mizzles's Avatar
Trade: tile
ChrWright - do you remember what adhesive you used for the tiles?
mizzles is offline
Old 06-19-2008, 09:51 AM   #19
Builder/Remodeler
ChrWright's Avatar
Which tiles?
Old 06-19-2008, 09:56 AM   #20
mizzles's Avatar
Trade: tile
What's on the face of the bar in the picture? Hard to tell
mizzles is offline
Backer material for curved ceiling & glass tile Syborg_97 Ceramic & Stone Tile 12 12-22-2008 04:06 PM
Glass tile installation ? ruskent Ceramic & Stone Tile 19 04-21-2008 06:04 PM
How many members of CT does it take to change a light bulb? Bill Off Topic (Non Trade) 19 01-05-2008 01:13 PM
1x1 glass tile ??'s vaultf600 Ceramic & Stone Tile 7 05-12-2007 09:22 AM
Got some design ideas for tile wainscoting? Mike Finley Ceramic & Stone Tile 2 05-09-2006 10:05 AM
