8 X 24 Plank, Spacing
Old 11-20-2017, 05:13 PM   #1
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,219
I'm laying down 500 sf of 8x24 ceramic "wood" plank on a basement floor with 1/3 offset. Floor and Decor cheap stuff, and it seems fairly flat. Silvered wood, with gray/silver grout (similar)
This is intended to be a quick, fast, cheap install for a home sale. No leveling system, just comb and go. What grout size would you go with? I was going to do 3/16", but I'm having second thoughts that I should tighten it up a bit (1/8").
Thoughts?
MarkJames is online now
Old 11-20-2017, 05:24 PM   #2
tjbnwi's Avatar
Rewards Points: 3,626
Re: 8 X 24 Plank, Spacing
Measure the tile. If it's 1/8" short of the whole number go with 1/8.
You'll regret not using a lippage system with these tiles.
tjbnwi is offline
overanalyze (11-20-2017)
Old 11-20-2017, 05:32 PM   #3
MarkJames's Avatar
It's a bit larger than 8x24, like an 1/8" wider and 1/4" longer.
Old 11-20-2017, 05:42 PM   #4
tjbnwi's Avatar
Go with an 1/8. Most are smaller.
tjbnwi is offline
MarkJames (11-20-2017), overanalyze (11-20-2017)
Old 11-20-2017, 06:10 PM   #5
AustinDB's Avatar
Rewards Points: 678
I'll never lay tile without using a leveling system (clip), it's too darn hard and I can't lay a tile and know that it badly out of level and leave it. it feel it makes me faster b/c I'm not messing with spacers. The red clips in the Riamondi system are 1/8" wide, which is a great width for that type of flooring.
If you don't use a leveling system then by using a wider grout joint you can hide the uneven tiles.
AustinDB is offline
The Following User Says Thank You to AustinDB For This Useful Post:
Old 11-20-2017, 08:58 PM   #6
MarkJames's Avatar
Alright, you smacked some sense into me. Much obliged.
I decided to get the Goldblatt version of the Lash clips, since the levelers are softer, less brittle plastic. Good enough for now. 1/16" spacing
Old 11-20-2017, 10:30 PM   #7
Hair Splitter
TNTSERVICES's Avatar
Trade: General
Rewards Points: 3,778
IMO, wood planks should never be further than 1/8". And I am glad you decided to use a lippage system. I would say that it will save you a ton on labor so well worth the small cost.
Tried & True on Facebook
Tried & True Website
TNTSERVICES is offline
The Following User Says Thank You to TNTSERVICES For This Useful Post:
MarkJames (11-21-2017)
Old 11-20-2017, 10:31 PM   #8
Hair Splitter
Trade: General
FYI:
https://www.tcnatile.com/faqs/40-grout-joint-size.html
Old 11-20-2017, 10:41 PM   #9
tjbnwi's Avatar
Check a few tiles side by side. The 1/16" might be to tight. You can use 1/8" spacers with the 1/16" clips if need be.
tjbnwi is offline
Old 11-20-2017, 10:51 PM   #10
MeanWeen's Avatar
Trade: City worker
Rewards Points: 24
Well you learn something everyday. I have never seen these used before. They look really handy, are they used just on larger tiles with small grout Lines? When the thinset is dry do they just break off?
MeanWeen is offline
Old 11-20-2017, 11:15 PM   #11
tjbnwi's Avatar
I use the RLS lippage system. I think the minimum tile size is 8x8, thickness from 1/8" to 3/4", minimum joint width is 1/16", max width is not listed, my guess 3/4".
Yes, they break off.
The first photo incorporates a protection plate that TNT recommend.
tjbnwi is offline
Rio (11-21-2017)
Old 11-21-2017, 12:07 AM   #12
Hair Splitter
Trade: General
They come in 1/32" as well. Not sure the widest. I have only ever used the 1/8" clip.
Old 11-21-2017, 01:22 AM   #13
MeanWeen's Avatar
Trade: City worker
Rewards Points: 24
Ive never seen any of my tile guys use these at all, they do seem pretty handy though. Just trying to understand a bit more. So I guy would probably use these more when they were placing a 24x12 tile with a tight grout line rather than a 12x12 with a large grout line? Seem like a no brainer for walls as would be placing the spacer in there anyways. Any drawbacks to these. Cost, Speed? For some reason I cant see a guy using these in a large office entry. These targeted more towards residential work? Also just realized Im butting right into the middle of your post MarkJames, sorry about that.
MeanWeen is offline
Old 11-21-2017, 06:26 AM   #14
MarkJames's Avatar
No problem. There's room for everybody.
Old 11-21-2017, 06:49 AM   #15
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,570
Interesting timing on this thread.
I am looking at a 8x24 wood look as an option for a room that may have a higher than optimal deflection.
The spacing is of high interest, and I agree that finer lines lend it to a better look as it's a wood imitation. Could someone comment on possible grout issues and what type of grout might mitigate potential pops?
Apologies to the OP if it's off topic
Above all, a good roof
Mr Latone is offline
Old 11-21-2017, 07:11 AM   #16
Hair Splitter
Trade: General
I use them on every job, but yes, large format tiles are where they shine. Planks are rarely flat and most have a bow. You can eliminate the bow with the clips. But the real function is to eliminate lippage.
And they are used in commercial all of the time. You can step (lightly) right after laying tile and in a commercial environment where others ignore your fresh tile signs and walk all over them, this will, at least, Hold the tiles together and not allow them to shift.
The Following 2 Users Say Thank You to TNTSERVICES For This Useful Post:
overanalyze (11-21-2017), Xtrememtnbiker (11-21-2017)
Old 11-21-2017, 07:13 AM   #17
Hair Splitter
Trade: General
Grout fails for a few reasons.
1. substrate/structure movement.
2. improper mix
3. wrong grout for application
If you go with an 1/8" joint or larger you can use pretty much any grout. Larger than 1/8" I would not use unsanded. Smaller than an 1/8" I would use unsanded.
Mr Latone (11-21-2017), overanalyze (11-21-2017)
Old 11-21-2017, 07:18 AM   #18
MarkJames's Avatar
Mapei flexcolor cq would be less likely to crack.
The Following 2 Users Say Thank You to MarkJames For This Useful Post:
Mr Latone (11-21-2017), TNTSERVICES (11-21-2017)
Old 11-21-2017, 07:32 AM   #19
Been around
Mr Latone's Avatar
Trade: Roofing
2. improper mix
This a personal project under consideration. I just know the that I can make things on shelves rattle slightly if I bounce a little mid-span. Gypcrete over subfloor over properly sized I-joist.
Having a crack form in the floor after install (eventually) wouldn't be the worst thing. Having grout chunks popping out over the years would be far worse.
Old 11-21-2017, 08:38 AM   #20
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,796
I guess I'm gettting old but I just dont like the look of those big tiles..or the popular subway "ugly as sh-it "tiles anywhere. Too commercial looking for my taste...plus those big honkers are heavy and bulky to work with. And heck, I don't even like the look of them in commercial settings either.
It looks like you did a good job though.
kirkdc is offline
Quick Plank Replacement Tip PrecisionFloors Flooring 5 05-23-2013 07:20 PM
seem treatment for 5/8" plywood and vinyl plank flooring GO Remodeling Flooring 5 01-11-2013 09:51 PM
Strange smell from old plank subfloors bob_cntrctr Flooring 9 09-09-2012 06:49 PM
Post spacing Wheel chart? Sprtman Decks & Fencing 3 08-25-2012 11:30 AM
Hidfast Gun redwood Decks & Fencing 28 06-08-2012 06:43 PM
