20x20 Tile
Old 02-08-2008, 10:50 PM   #1
Sharp Improvements
Norrrrrrrrrrrrm's Avatar
Question
20x20 Tile
Hey guys/gals,
I am about to put 20x20 ceramic down and I wanted to make sure I am right or wrong on my trowel notch. I pretty sure I need to use a 5/16 deep trowel, am I right? Thanks.
Norman Sharp
http://www.sharpimprovements.com
Norrrrrrrrrrrrm is offline
Old 02-08-2008, 10:53 PM   #2
General Contractor
hatchet's Avatar
Re: 20x20 Tile
The bigger the tile the bigger the notch is what I've always done. I wouldn't do less than 3/8" deep with 1/4" spacing.
Rich
WIT Construction Co.
Superior MT Contractor
hatchet is offline
Old 02-08-2008, 11:20 PM   #3
cleveman's Avatar
Trade: custom home building
Re: 20x20 Tile
Read your sack of mortar. I think they'll recommend a 3/8 x 1/4 on even 12x12 and up, maybe a 1/2 x 1/2 on 20x20's.
The tile guys must be off tonight. I'm surprised this hasn't started WWIII.
Post a thread on how to do a balcony or something and we'll see the fur fly.
cleveman is offline
Old 02-08-2008, 11:21 PM   #4
Sharp Improvements
Re: 20x20 Tile
Yeah I have do have a 3/8 x 1/4. I thought it was a 5/16., I was wrong...boo hoo.
Norman Sharp
Old 02-08-2008, 11:27 PM   #5
JazMan's Avatar
Trade: Tile Contractor-Manufacturers rep. Tile & Marble
Re: 20x20 Tile
Hi Norm and Rich,
There is no single correct answer to this. Lots of wrong ones though. With 20" tiles with a standard textured back I would recommend either a 1/4x1/2x1/4, or I might lean towards a 1/2x1/2 trowel, even larger might be needed?
Before you start the installation, can you tell me what the substrate is? If it's a wooden subfloor, have you consulted the framing and subfloor sheet requirements for tile? If it's a slab, are there any cracks or control joints or cuts? In either case that floor had better as flat as your kitchen table.
Specifically what thinset are you planning to use? Get back with answers to my questions above before you do anything.
Jaz
Tile 4 You llc
KERDI Shower
specialist...DITRA Installs...
www.tile4you.com
JazMan is offline
Old 02-08-2008, 11:40 PM   #6
Its all ball bearings
angus242's Avatar
Trade: Tile
Re: 20x20 Tile
I have been taught it's more of the back of the tile that determines notch size. Besides, the bigger the notch size, the more mortar your putting down and there's a real good chance you're gonna have lots of mortar oozing from between the tiles. On ceramic that size, you'll probably need to experiment with back buttering too. I guess it really depends on how level the floor is. But remember the purpose of the mortar is to adhere the ceramic to what's under it, not to act as a floor leveling compound. You can make up some of the leveling with mortar but you shouldn't rely on it.
Start with your 3/8 x 1/4, mix a small batch and test a few pieces. Better to find out then that your trowel is the wrong size than to have a full bucket of mortar and realize it then!
angus242 is online now
Old 02-08-2008, 11:44 PM   #7
Sharp Improvements
Re: 20x20 Tile
Originally Posted by JazMan View Post
Hi Norm and Rich,
Jaz
Thanks for the concern, my mother doesn't even care this much! It will be on a wood floor and I am using hardi backer as the cbu. It has 2x10 underneath at 16 o.c. I already went around and screwed the plywood(nalied previously) down for addition hold. The floor is quite flat and is only about 10 years old. I was going to use a modified thin set by laticrete. It is supposed to be for large format tiles.
where can I get the frmaing and subfloor sheets?
Norman Sharp
Old 02-09-2008, 12:00 AM   #8
angus242's Avatar
Trade: Tile
Re: 20x20 Tile
You can check with the John Bridge Deflectolator to make sure you're good to go.
http://www.johnbridge.com/vbulletin/deflecto.pl
Old 02-09-2008, 12:04 AM   #9
Tile Contractor
Bud Cline's Avatar
Re: 20x20 Tile
Bud Cline is offline
Old 02-09-2008, 12:10 AM   #10
Tom R's Avatar
Re: 20x20 Tile
I've always used a trowel with a tooth-depth that's equal to the thickness of my tile.
http://www.tr-built.com
Tom R is online now
Old 02-09-2008, 12:11 AM   #11
Sharp Improvements
Re: 20x20 Tile
Originally Posted by Bud Cline View Post
Does this mean I'm good to go or are you just happy to see this thread?
Norman Sharp
Old 02-09-2008, 12:14 AM   #12
Sharp Improvements
Re: 20x20 Tile
That was sort of my thought too. I used a 3/8 deep on some saltillo with a dollop a while back and 1/2 seems to thick for ozzing purposes as angus was saying.
Norman Sharp
Old 02-09-2008, 12:31 AM   #13
Tile Contractor
Bud Cline's Avatar
Re: 20x20 Tile
I hate like hell to say anything around here anymore.
The was two-fold because the information given was in my opinion good information and everyone seems to be under control......so...... (Not that my opinion matters.)
Nothing to add.
Well OK OK OK.
Keep a bucket of water and a sponge at your side at all times and if the thinset purges you can clean it up immediately.
Twenty inch tile can be a bummer if the subfloor isn't perfectly plane and they usually aren't. Spread the thinset and use the flat side of the trowel to "key" the thinset into the substrate and THEN comb the thinset in straight lines. THEN if needed you can skim some thinset onto the back of the tile using the flat side again. I have found "back-buttering" is usually required with tile that big.
Old 02-09-2008, 12:45 AM   #14
JazMan's Avatar
Re: 20x20 Tile
As I said there are many variables. You will probably have to try several trowels? Start with whatever you think and set about 2 tiles. Lift then right away to check for thinset transfer, you want at least 85% coverage. If you don't have it, go to the next one. Make sure the thinset is mixed fairly stiff, but workable.
If it was me and I was using a medium-bed mortar, (which one?) as it appears you are, I would not even consider the 1/4x3/8x1/4, that's my standard trowel for 12-13" tiles. I would start with the 1/4x1/2x1/4 but have a 1/2x1/2 standing by. They even make a 3/4" for certain situations. Remember when the tiles are beat-in, you should have a thinset thickness of a minimum 3/32-1/8", even a little thicker would be good with those huge things. Also remember, a trowel with 1/2" deep notches does NOT leave 1/2" tall ridges of thinset.
As for the subfloor system, we also need the unsupported span of the joists, species and grade if you can read that info off the joists and type of subfloor, thickness and number of sheets.
Jaz
Tile 4 You llc
KERDI Shower
www.tile4you.com
JazMan is offline
Old 02-09-2008, 10:52 AM   #15
Knowledge Factory
Floordude's Avatar
Re: 20x20 Tile
20x20.... ½x½x½
13x13 is my limit for 3/8 notches.
http://www.AustinFloorguy.com
Floordude is offline
Old 02-09-2008, 11:01 AM   #16
orson's Avatar
Trade: Kitchen & Bath
Re: 20x20 Tile
According to Taunton Press "Tiling Complete" 18 inch square and larger porcelain and stone tiles, Average 30 SF to 40 SF coverage per 50lb bag thinset,
trowel size: Square Notch: 3/4inch by 9/16 inch
www.rubycon.us
Ruby Construction LLC
Lancaster Kitchen Remodeling
Lancaster Bathroom Remodeling
orson is offline
Old 02-09-2008, 12:54 PM   #17
Tile Contractor
Bud Cline's Avatar
Re: 20x20 Tile
Like they would know!
The size of the tile IS NOT the only consideration.
Old 02-09-2008, 04:13 PM   #18
orson's Avatar
Re: 20x20 Tile
I figured I'd copy it straight out of their book and see what kind of flack I got since you guys are all quoting lower notch sizes. I usually find Taunton books to be pretty good, oh well.
www.rubycon.us
orson is offline
Old 02-09-2008, 04:17 PM   #19
Tile Contractor
Bud Cline's Avatar
Re: 20x20 Tile
"Taunting Books"?
"Pretty Good"?
Is that like "military intelligence"?
So where is it?
Old 02-09-2008, 04:20 PM   #20
orson's Avatar
Re: 20x20 Tile
I must be even denser than usual, I'm not catching your drift....I take it you don't like Tauton Press books?
www.rubycon.us
orson is offline
quarry tile to quarry tile rservices Flooring 8 01-15-2010 12:37 AM
Grouting tile that is pitted... bbravo Kitchens & Baths 11 03-19-2009 10:09 PM
Learning to install Floor and Wall Tile!! TurnkeyConst Flooring 25 01-17-2008 08:01 PM
Got some design ideas for tile wainscoting? Mike Finley Ceramic & Stone Tile 2 05-09-2006 10:05 AM
Cutting Existing Tile. kpikul Remodeling 16 02-05-2006 12:30 AM
