Avalon
Trade: Landscape Lighting Designer/ Contractor
What Kind Of Control Devices Do You Use?
I wanted to see what everyone's thoughts were on which type of control device they use for their lighting systems. I realize it may vary depending on the size of the system and how many transformers you are working with. Are these devices simple or sophisticated--home automation types?
I work mostly with the simple photocell/ timer type of system for smaller jobs and look at using relays or sequencer types of control for larger systems. I've tried the X-10 for many years, but have found it to be a real pain, due to the amount of electronic noise created at ones property now days. I really don't enjoy having to go back to a clients house several times, especially after a year or more, due to the client adding electronics! Anybody find any other types of controls that are "dependable" and somewhat cost effective? Let's say, in the several hundred dollar range? Thanks for any input.
Mark Carlson, CLVLT #0631 Avalon Artistic Landscape Lighting member AOLP |
Lighting Designer
Trade: Landscape Lighting Designer/Installer
Re: What Kind Of Control Devices Do You Use?
Marc, I usually just use the gool ol' digital timer and photo control. I have put in a few remotes and I am currently installing a system that is going to be operated by an in-home automation system that is being installed by a seperate company. They are going to control the outlets that I will plug into. This is a new construction job and I get very few of these.
Paul R Gosselin, CLVLT 0632 NightScenes Corporation www.night-scenes.com President, AOLP www.facebook.com/NightScenes |
Master Illuminator
Trade: Lighting Design/Installation
I think I have used everything out there; Radio RA, X-10, Digital and Mechanical Timers. I guess I have to say I like to try to keep it as simple as possible and use the digis with a quality pc. The X-10 set-up, however, does have its qualities. For instance, you can talk a homeowner through reseting it over the phone. This saves a great deal of time and travel costs. I guess you could also talk a homeowner through reseting a digital, but who wants to send their customers into the bushes with a cordless phone? Not very professional... When installing the X-10, it is imperative that you install the phase coupler/repeater also. This will add another couple of hundred to the job cost, but it is well worth it to both you and the owner. By doing this, you will greatly increase your success with the device, and make yourself look like a real pro to the client.
Chris J, CLO (Chief Luminary Officer) Member AOLP, CLVLT #0638 FL Lic#ES12000428, GA Lic#LVG105244 www.JohnsonLightingInc.com |
Trade: Exterior Lighting
Mark,
If you liked the versatility of X10 but hated the reliability I used to say "learn how to use it properly" but now I say "have you looked into UPB".
Paul Eddleston ILLUMINATA Landscape lighting www.CreativeExteriorLighting.com Tel: 248-207-0894 Fax: 248-282-0851 |
Lighting Designer
I now use UPB quite often. Control Scape seems to be pretty good and I have had very little problems with it.
#6 | |
Trade: Plumbing & Electrical
Re: What Kind Of Control Devices Do You Use?Quote:
I took Paul's advice on ControlScapes stuff. This was on a large project (for me) and I was a little worried just because I was unfamilliar. I have used X10 garbage before and voe never again. Got all my recepts installed, everything else done and it came time to program the unit to the recepts. Nada....zero communication, even with the receptacle located right next to the CS recept (same circuit). Spent about 30-45 min with......Adam I think his name was. Nice guy - we tried everything. He wound up overnighting me a new controller. Plugged it in did my scan and was totally programmed and working flawlessly in about 10 minutes. It's been a few months and not one hicup. My client sometimes unplugs the unit so the lights will stay off for a few days and just simply plugs the controller back in and all the settings are still in tact (non-volital memory). I have since installed another controller for their fountain lights and gated entrance to the property. I have also installed 3 additional systems in other clients homes.....perfect. As paul told me a while ago....it's just like X10 only 100 times better. AND no phase coupler needed with recepts on A and B phase!! It's good stuff
"....And then we all switch places when I ring the bell" -Adrock
Lighting Designer
I do install phase couplers though, on every install, just in case. It's very cheap insurance.
#8 | |
| Solution for VCT cracking @ control joint | puzzledlog | Flooring | 2 | 05-16-2007 08:48 PM |
| Varmint control... | RJC | Roofing | 2 | 05-01-2006 10:11 PM |
| Labors hours control | igorrepublic | Painting & Finish Work | 19 | 03-03-2006 07:27 PM |
| possible problem with the USG with dust control | wolffhomerepair | Drywall | 2 | 02-25-2006 09:35 PM |
