Trade: Home Construction/Reno
Soffit Lighting
I want to add some recessed lighting in my soffits over doors and openings and along my deck in the front. I have 5" or so to work so most cans should fit. Whats a good size wattage for outside shining down on the walls?. Dimmer switch and a photo eye??
woodchuck2
Re: Soffit Lighting
Most of the soffit lighting i ever installed was 65-75watts. Having a dimmer is up to you, with 65 watts and the hight that they will be at you should have fairly soft light coming down anyway. The lighting will vary with the color of the siding too. Seems all the soffit lighting i have done was always on log homes so the stained logs had a nice glow to them. A photo eye is a good idea but be sure to install a manual over ride switch.
I used to think so.......
Re: Soffit Lighting
Is LED an option?
I have no idea about stuff like that...but LED seems to be the way of the future...very little power for very long life and bright light without the heat. Justa-thought |
#4 | |
Re: Soffit LightingQuote:
Re: Soffit Lighting
Thats a great idea to look into. Since soffit lighting usually stays on for the entire night they consume alot of power
Trade: siding
Re: Soffit Lighting
are the light being installed in a vented soffit or
a cantilever overhang?The cantilever will have insulation issues that you will have to deal with |
Re: Soffit Lighting
Vented soffit, no insulation
INTEGRA Works Inc.
Trade: Lighting Systems, Design / Build
Re: Soffit Lighting
Soffit Lighting can be effective if it is not overdone. The vast majority of it is installed by trades that have no knowledge or experience in technical lighting design and as such it is usually too bright, has lots of glare (direct line of sight to the lamp) and there is too much of it.
I would recommend you use MR16 based LV recessed fixtures, and make sure the trims you select are deep regressed and adjustable gimbals so that you can aim the light. Start with 20W BAB (flood) lamps. Brighter is NOT better. See the effect, not the source.
James Solecki INTEGRA Works, JSLDesign, LED Lights Direct www.integralighting.com www.JSLDesign.ca Member: IESNA, AOLP, LO, MBA |
| The Following User Says Thank You to James Solecki For This Useful Post: | algernon (04-27-2010) |
#9 | |
INTEGRA Works Inc.
Re: Soffit Lighting
I don't think it is necessary to use shower trims when installed in a soffit application. Besides, the shower trims will create a lot of glare as the glass lens is located flush to the soffit. You want to use a deep regressed trim that holds the lamp inside the can, out of the line of sight as much as possible.
Regards.
| Vinyl soffit span... what backing OC? | bobaganoosh | Windows, Siding and Doors | 11 | 12-24-2008 12:41 AM |
| Residential General Lighting Circuits | toastermaker | Electrical | 11 | 02-26-2006 01:04 AM |
