The Perfect LV Lighting Cable?
Old 02-09-2008, 09:31 PM   #1
INTEGRA Works Inc.
James Solecki's Avatar
Trade: Lighting Systems, Design / Build
What qualities would you list if you were to think of the perfect low voltage lighting cable?
Very Flexible Jacket, no memory effect and easy to install
Suitable for direct burial
Sunlight resistant
Tin Coated copper strands to eliminate oxidation.
Double jacketed conductors just like Romex
Inner colour coded jacket on conductors
90c rated for use indoors and on structures
Dual coloured outer jacket (Brown and Grey) for excellent hiding in trees.
Available in sizes from 8/2 through to 14/2.
Also available as a 10/3 and 12/3 for applications requiring grounding
unique shape allowing for a watertight connection to hubs and junction boxes - guaranteed.
Never heard of such a cable before have you? Well it is now available from Qtran and is called Qwire. Check it out for yourself.
http://www.q-tran.com/
James Solecki
INTEGRA Works, JSLDesign, LED Lights Direct
www.integralighting.com www.JSLDesign.ca
Member: IESNA, AOLP, LO, MBA
James Solecki is offline
Old 02-15-2008, 07:37 AM   #2
Lighting Designer
NightScenes's Avatar
Trade: Landscape Lighting Designer/Installer
Re: The Perfect LV Lighting Cable?
I'm not a fan of tin coated wire. Increases voltage drop.
Paul R Gosselin, CLVLT 0632
NightScenes Corporation www.night-scenes.com
President, AOLP
www.facebook.com/NightScenes
NightScenes is offline
Old 02-15-2008, 08:10 AM   #3
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
For "quality" jobs we're usually using Cast wire, for "cheep" jobs we're usually grabbing whatever Lowes/HD has, and for LV LED systems, we use whatever seems to be the best "fit" for the environment we're working in...
I know it's not the best answer, but it's all I've got!
~Matt
BreyerConstruct is offline
Old 02-16-2008, 10:17 AM   #4
Lighting Designer
Just a couple of thoughts.
If you talk to the folks at Cast or Qtran they will admit that the only benefits to tin coated wire are the ease of soldering (if you do that) and less corrosion for wire that is exposed (which it should not be anyway). They will also admit to an additional 2% voltage drop on tin coated wire.
If you don't solder (I use Buchanan crimps) and your connections are not exposing the bare wire to the elements (I sure hope not) then the added expense and added voltage drop for tin coated wire do not make it "quality", only expensive.
The wire purchased at the home improvement stores is just so bad that I would not even consider using it on the cheapest of jobs. It costs twice as much as the good stuff that you can get from the distributors where you buy your fixtures.
President, AOLP
Old 02-16-2008, 11:54 AM   #5
Lightscaping Designer
SOUTHERN LITES's Avatar
Trade: OUTDOOR LIGHTING
Paul,
What are Buchanan crimps?
STEVE
ISLANDER LIGHTSCAPING INC
"LIGHTING for LIFE OUTDOORS"
FL. EY12000225
SOUTHERN LITES is offline
Old 02-16-2008, 12:35 PM   #6
Lighting Designer
Steve, the Buchanan crimp is a copper cap (so to speak) that fits over the wire leads that you are connecting. You then use a special tool (C-24) to crimp it onto the leads. This connection is so strong that it won't even allow air to penitrate it. I then place this connection into a DBR grease filled tube and snap it shut.
I am attaching photos of the tool, the connection and the DBR. The DBR that I use is about 3" long though.
President, AOLP
Old 02-18-2008, 02:28 PM   #7
SECO - dry is beautiful
Will Johnson's Avatar
Trade: Landscape Contractor
And I was just about to google "Buchanan crimps" !
Paul - what do you use when you need to join more than 2 - 12g wires? (such as, at the end of a lateral run where you want to connect several fixtures). Seems like 4-5 12g wires would need a pretty large grease-filled tube. Thanks!
Will Johnson is offline
Old 02-18-2008, 02:49 PM   #8
LightYourNight's Avatar
Trade: Landscape Lighting Professional
I have never thought of using these for lv connections. Good call Paul. How many wires max have you put into these crimps? how big do they come?
LightYourNight is offline
Old 02-18-2008, 04:03 PM   #9
IntegrityOutdoorLighting
Billy-Integrity's Avatar
Trade: Lighting design and build firm
Send a message via AIM to Billy-Integrity Send a message via Yahoo to Billy-Integrity
If you talk to the folks at Cast or Qtran they will admit that the only benefits to tin coated wire are the ease of soldering .
I am a solderaholic as you know. When I switched from Cast wire to copper I noticed it still solders up tight with no issues. I do run my solderpot as hot as I can possibly get it. With that said I do use the buchanans in some situations and Ace connectors when I need a low profile inline connection system such as in trees.
You can fit a good amount of wire in a large buchanan crimp. I think I have even put up to 3 strands of 10ga in there if you twist em down tight first. I also use the DBR tubes like Paul but the northstar ones instead that I get from fold. Never a failed connection yet
Billy
www.IntegrityOutdoorLighting.com
Simply Breathtaking....Night after Night
Billy-Integrity is offline
Old 02-18-2008, 06:05 PM   #10
Lighting Designer
I usually get 2-12 and 5-16s in a single large buchanan cap with no problem.
President, AOLP
Old 02-18-2008, 07:30 PM   #11
Where would be a good place to shop for these items?
STEVE
FL. EY12000225
Old 02-18-2008, 11:59 PM   #12
INTEGRA Works Inc.
You can go the the Qtran website and click on "Where to buy" and find a distributor near you.
Or click here: http://www.q-tran.com/buy2.swf
Have a great day.
James Solecki
Old 02-19-2008, 07:31 AM   #13
Lighting Designer
I buy the copper caps at the Home Depot, the DBRs I get from my distributor who is an irrigation supply (Longhorn) and the tool will probably have to be ordered from your local electrical supply house.
President, AOLP
Old 02-19-2008, 09:40 AM   #14
Thanks guy's, I always appreciate the help I get from ya'll!!!!!
STEVE
FL. EY12000225
Old 03-04-2008, 02:48 PM   #15
Paul,
Where can I find the DBR grease tubes? Are the Buchanan crimps and tubes much better than dry-lock wire nuts?
Thanks,
STEVE
FL. EY12000225
Old 03-05-2008, 07:30 PM   #16
Lightbulb
Hey Southern Lites, You can find the DBR kits on my website.
lightyournight.com/item.php?item_id=524
Enter the promo code: DBR @ checkout and it will give you a 40% discount. If you want case quantity 100 tubes+ call or email me and I can hook you up.
I hope this helps
John Paul
The Landscape Lighting Specialist
Old 03-06-2008, 07:51 AM   #17
John Paul,
Thanks for the reply and I will check out your site!!
Thanks,
STEVE
FL. EY12000225
Old 03-23-2008, 10:11 AM   #18
Are these things worth using in any situations?
STEVE
FL. EY12000225
Area lighting for Pipe Guy mdshunk Electrical 5 01-26-2009 02:25 PM
Lighting maintenance services? CNC Electrical 5 11-01-2007 04:48 PM
Cable Calc. sparkengineer21 Electrical 2 02-06-2007 07:01 PM
Residential General Lighting Circuits toastermaker Electrical 11 02-26-2006 01:04 AM
