#21 | |
Trade: Control Systems
Re: Newbie Solder Splice Question?Quote:
I do alot of underground low-voltage splices for control/communication/sound and I use a souldering gun with rosin core, then screw a nut on it and fill with silicone, then wrap with electrical tape. If its a big splice that my butaine iron can't handle then I break out the Triton Clamp Iron, it will do up to two aught. |
#22 | |
Trade: Electrical
I have done quite a bit of low voltage lighting jobs that range from 3k to 40k an what I use is Marine grade Tin Coated wire an hub set up and I use solder pot 150 watt and if you make nice clean joints twisted then dip them in pot it's not cumming apart , then use the blue weather proof wire nuts with the oxide within them tighten down good with linesmen pliers then last thing you could use good electrical rubber tape or heat shrink about a 4 inch long piece to seal the wire nut an part of the wire below the joint,I have never had a call back due to loose or bad connections. |
| Contractor law question for california contractors | saucedo80 | Painting & Finish Work | 7 | 04-18-2009 01:07 PM |
| newbie online | mark_2222 | Introductions | 4 | 11-21-2008 06:06 PM |
| Quick weather question | Just-In-Time | Masonry | 9 | 11-19-2008 06:38 AM |
| Newbie with question on partial lien release clauses | woodpile | Business | 3 | 06-10-2008 05:52 PM |
| Newbie Question | DAK | General Discussion | 21 | 07-26-2006 07:30 PM |
