More Input Needed
Old 03-21-2008, 01:58 PM   #1
Lightscaping Designer
SOUTHERN LITES's Avatar
Trade: OUTDOOR LIGHTING
More Input Needed
Just let me start by saying thank you for the time and effort you put into answering our questions( especially mine ).
Follow me if you will,.....................it's a cold and dreary night...HA HA!!
I have a brick wall that my customer wants to light. The wall is a lite colored brick almost white. On either side of the wall are 2 windows. The wall is 7.5' tall and 6.5' between the windows. The windows themselves are roughly 6' tall. I said all that in an effort to explain the situation, I basically have an area 6.5' x 7.5' to wash with windows on both sides.
I am looking at :
1. VISTA 3250 MR16 LN-35 FMW/60
2. VISTA 5204 MR16 LN-35 FMW/60
3. KICHLER ?
4. UNIQUE ?
I would like to keep with the MR16 if at all possible simply because there are other lights in the system with MR16 lamps.
Thanks,
STEVE
ISLANDER LIGHTSCAPING INC
"LIGHTING for LIFE OUTDOORS"
FL. EY12000225
SOUTHERN LITES is offline
Old 03-21-2008, 05:12 PM   #2
Lighting Designer
NightScenes's Avatar
Trade: Landscape Lighting Designer/Installer
Re: More Input Needed
Personally I would go with either the Kichler 15396 with a 20 watt lamp or the Unique Starburst with the 20 watt lamp and frosted lens. I hate the "V" that you get from the MR16 when trying to wash a wide area. There's nothing saying that you can't use a combination of fixtures, just make it look like you meant to do it. If you must use MR fixtures be sure to use something to spread the beam like a linear lens.
I would also back off of that 35 watt lamp. This light brick will be far too reflective for that bright of a lamp. I would go with 20 watts max.
Paul R Gosselin, CLVLT 0632
NightScenes Corporation www.night-scenes.com
President, AOLP
www.facebook.com/NightScenes
NightScenes is offline
Old 03-21-2008, 05:35 PM   #3
Moonlighting
klkanders's Avatar
Trade: landscape,lighting contractor
I agree with Paul. I have used the Unique Starburst and Stellar for lighting horizontal and square wall areas. I experimented with both type bulbs and quickly found the right choice for the application. It wasnt the MR16.
Good Luck!
klkanders is offline
Old 03-21-2008, 07:07 PM   #4
illuminata's Avatar
Trade: Exterior Lighting
Good Luck!
I agree with Paul to and not just because he is a Paul.
Flood all the way, 2' back, 20W, almost straight up. If there are shrubs where the light wants to be move the shrubs. Actually, don't do that, put the light on a riser in the shrub.
Paul Eddleston
ILLUMINATA Landscape lighting
www.CreativeExteriorLighting.com
Tel: 248-207-0894 Fax: 248-282-0851
illuminata is offline
Old 03-22-2008, 02:25 PM   #5
Thanks for the help fella's. I have alot of respect for the experience passed along on this forum!!!!!!
STEVE
FL. EY12000225
Trailer: Customizing ideas needed. Long Robie Vehicles 195 11-06-2011 11:32 AM
Siding & Windows Sales needed - Chicago area - NO SALES EXPERIENCE Grumpy Help Wanted or Looking For Work 4 05-26-2009 03:51 PM
Expansion material needed or not? davidchomes Concrete & Paving 6 09-08-2007 01:17 AM
SUB-CONTRACTOR needed to build(give estimate) red brick or block(stucco finish) wall( soldz Masonry 18 04-22-2007 09:55 AM
Experienced Metal Roofers needed EcoWise inc. Roofing 0 03-03-2007 06:03 PM
