Trade: Landscape Lighting, Landscape Design, Landscape Maintenance
LED Systems
I am putting in a new system for a customer and want everything to be LED, do I need a different transformer than the traditional 300, 600, 900, 1200 watt? I know it probably depends on how many lights I will be installing but I saw something on Kichler's website about a remote driver. Also, is it best to use the traditional 12-14 GA wire when installing LED lights or is that wire too big for LED's.
This will be my first LED install so if anyone has any suggestions I would like to hear them. |
Handle It!
Re: LED Systems
I think, I may be wrong, that it all depends on the LOAD????? And the VOLTAGE??????
Re: LED Systems
LED's are pretty new and they're still working out many issues.
Available are lights that step down from household current using a transformer, ones that include the transformer as part of the light and some that require a 12-36 VDC transformer. I have yet to see a single company/system that would provide what I would want for most any use. Pricing is another current issue. I recently priced waterproof, 6 unit clusters that were between $800-1,200 ea. Even Al Gore would have second thoughts about those prices!
Lighting Designer
Trade: Landscape Lighting Designer/Installer
Re: LED Systems
Most of the LED landscape lighting that you see out there will operate directly from an ordinary 12v transformer. You would have to use a whole lot of lights to need more than a 300 watt unit. The Kichler mini LEDs which are the ones that are for underwater use or small niche lighting have an external driver that needs to be installed. This is a 40 watt unit which will operate about 10 of those mini lights and it hooks up to the transformer. I think Kichler has the best LED directional fixtures out there because the LEDs are actually built into the fixtures. They have designed the fixture to dissipate the heat from the LEDs which will make sure that they last a very long time.
As for wire, you can use smaller wire if you like (I sure would) because your load will be so much less. You will use the same NEC requirements as to the amount of load you can place on a certain size wire. Your voltage drop will be less of an issue and the LEDs will operate well at voltages ranging from 9-15 volts. Hope this helps and good luck,
Paul R Gosselin, CLVLT 0632 NightScenes Corporation www.night-scenes.com President, AOLP www.facebook.com/NightScenes |
Re: LED Systems
Thank you all for the help.
While I was looking at the kichler led page it seems that they have the remote driver's built into the fixtures themselves. Are you suggesting using the 40W driver as an added precaution? Also would you say that the output on a 4.5W LED is similiar to a 10W-20W traditional 12V system? Would 8.5W LED be similiar to 35W and would 12.4W be similiar to a 50W? Thanks again for your help |
#6 | |
Lighting Designer
Re: LED SystemsQuote:
Master Illuminator
Trade: Lighting Design/Installation
Re: LED Systems
Actually, Kichler is now claiming 8-15 volts for their operating range.
Chris J, CLO (Chief Luminary Officer) Member AOLP, CLVLT #0638 FL Lic#ES12000428, GA Lic#LVG105244 www.JohnsonLightingInc.com |
Re: LED Systems
Does anyone know where I can get a wire gauge chart for LED lighting. I have 7 lights (62.7 W) and was thinking that 12 GA is pretty big for only 63 W. The only chart that I have is for traditional 12V lighting. Any help is appreciated. Thanks
Lighting Designer
Re: LED Systems
That's less than 6 amps so you could go as low as #18 wire if you want to but I don't think I would go less than 14, just in case there are additions to the run.
INTEGRA Works Inc.
Trade: Lighting Systems, Design / Build
Re: LED Systems
There are a number of decent LED lamps on the market that can be dropped into existing, tried and trusted Low Voltage fixtures. Specifically high power / high efficiency LED MR16 Lamps. I prefer this route as I would rather not be pigeon holed into installing complete LED based fixtures (sealed units) that are not field servicable and are generally designed with function over form. Things are moving ahead very rapidly in the world of LED Lamps and the issues of heat dissipation, intensity and colour are no longer a problem in most applications.
I highly recommend the Luxxo line of MR16 LED lamps. They very closely mimmick the light output of a 20W Halogen MR16 lamp and are the best units I have ever come across. So good that I have opened a distribution company that offers them to the trades and public. Visit www.ledlightsdirect.com for more information. There are other similar lamps on the market, but you will find that they each have their drawbacks when compared to the Luxxo. The best thing is, in our application of LV outdoor lighting, you don't have to commit to a single company's line of proprietary fixtures. (many of which are downright unappealing in design and quality) You can keep using the fixtures you know, love and trust and if an issue does develop you simply replace the lamp, not the entire fixture. There is a lot more to know about LED lamps, fixtures and systems... feel free to ask. Regards.
James Solecki INTEGRA Works, JSLDesign, LED Lights Direct www.integralighting.com www.JSLDesign.ca Member: IESNA, AOLP, LO, MBA |
Re: LED Systems
I placed the order and received the lights the other day and was pleasantly surprised when the lights came in. They are much smaller than I thought they were going to be. I will be installing them in trees to serve as down lights to illuminate a deck. These lights have a very good seal on them and I am hoping that I won't have to climb the ladder again after they are installed. Hiding the fixtures is something I pride my company in and these lights will make it much easier to do so.
I used the kichler 15731 series lights if anyone is interested. |
The Deck Guy
Re: LED Systems
Thread drift ahead:
What are you guys using for connectors with LEDs? I've been using regular wirenuts and taping under my deck jobs, but I wonder if there's a better way. The reason I'm using wire nuts is that the LED lights I'm using have three unique leads coming from the fixture (1 per LED), so it's not a 2 wire to 2 wire connection. It's 6 wires to 2 wires.
Trade: electrical contractor; complete remodeling
Re: LED Systems
Use wirenuts approved for underground work. They contain silcone and have a sealed end. Regular wire nuts will allow the wire to corrode over time (not long) and the tape will also quickly deteriorate.
#14 | |
INTEGRA Works Inc.
Sounds to me like you should be doing more work at hiding your connections. I hate seeing wire or connections on structures, decks, or anywhere for that matter. Coring, dado channels, custom trims, etc help to make your installations pro grade. Hope this helps.
| Why Build ICF | monsterconstruc | Green Building | 32 | 09-28-2008 11:48 PM |
| natural stone masonry wall systems | wesmartyn | Masonry | 14 | 03-14-2008 10:41 PM |
| Seperately-derived systems | Mark Twenhafel | NEC Discussion | 3 | 11-11-2007 10:18 AM |
| New Photovoltaic Systems Textbook | Magnettica | Electrical | 0 | 08-19-2007 10:44 AM |
