Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Landscaping > Outdoor Lighting
Old 06-16-2008, 11:45 AM   #1
Trade: Under Deck Rain Diversion Systems
Question LED low voltage down lighting
Has anyone seen or used an LED Low Voltage system made for outdoor use around a deck or patio area that has a 3-4" dia can light? Are they made? I found a small LED system made by Phillips but they are only about 1" (seemed to be used for accent lights on stair risers). I'm looking for a cannister type LED light that can be used outside - needs to be water proof or resistant. Is there such an animal made? Oh, These units that go into water fountains/features are too heavy and too expensive for what we need them for. Should be $30 -$50 range at the most.
Anyone, anyone?
DennisG is offline   Reply With Quote
Old 06-16-2008, 04:31 PM   #2
Lighting Designer
NightScenes's Avatar
Trade: Landscape Lighting Designer/Installer
I'm having a hard time understanding what you are looking for. What are you trying to accomplish?
Paul R Gosselin, CLVLT 0632
NightScenes Corporation
Vice President, AOLP
www.night-scenes.com
NightScenes is offline   Reply With Quote
Old 06-17-2008, 08:21 PM   #3
Question Restate the Question
Perhaps I was not clear on my question. It happens!
I am looking for an LED Low Voltage light that is set in a waterproof/watertight housing. I would like to install such a thing ( if it exists) under an outdoor residential deck. Since water may come through the decking it needs to be water proof.
I'm looking for some sort of unit that I can use for can lighting under the deck. In fact, I may install 4-6 units to provide lighting under the deck for my customer. I found a LED lighting system made by Phillips that is water proof but the lights are only about and inch in diameter - a little too small.
I have seen some indoor led kitchen lights that come in a can and replace the old incandescent spot lights used in the kithchen or for accent lighting- wondering if such an animal is made for outdoor use?? I figured that an LED unit is cooler and lasts longer.
Thanks.
Dennis
Old 06-18-2008, 07:43 PM   #4
Lighting Designer
There are lots of underwater low voltage fixtures available in which you could use and LED MR16 lamp if you wish. That lamp could range from a 20 watt equivalent to a 50 (3-12 watts actually). You could also use an LED underwater light that is manufactured by Kichler but it's only about 1.5" in diameter (like what you had mentioned). This light uses about 3 watts with a 36 degree beam spread. This would look like a 20 watt halogen lamp. If you decide to use the LED MR16 replacement lamps, make sure to spend the money on a good lamp and don't settle for some cheap lamp that has poor color temp and worse heat dissipation.
You're not going to find an indoor fixture that is waterproof or a large LED fixture that is low voltage.
I hope this helps,
Old 06-19-2008, 09:46 AM   #5
Smile Thanks.
Thanks for the info. I'll look at the product and see if it might work.
Dennis
High Voltage vs Low Voltage Lights robertc65 Outdoor Lighting 15 08-26-2009 10:26 AM
W A C low voltage lighting Badoish Electrical 0 11-09-2007 11:43 PM
Can I provide flood lighting via Low Voltage robertc65 Outdoor Lighting 8 11-06-2007 10:42 AM
Low voltage lighting system Dustball Electrical 8 10-28-2007 04:44 PM
Low voltage lighting... wraiths Electrical 2 10-17-2006 08:35 PM
