02-09-2008, 09:28 PM
#1
INTEGRA Works Inc.
Trade:
Lighting Systems, Design / Build
Introducing QScape, by Qtran
I want to introduce you all to a completely new, remarkable and revolutionary new Low Voltage Outdoor Lighting Power Management System.
This series of complimentary components is called Qscape and has been designed, engineered, and built from the ground up by John Tremaine and his team at Qtran.
Every single component of the system has been thought through and refined, working with one of the world's leading outdoor lighting designers, over the past 4 years, cumulating in this completely new and remarkable system.
http://www.q-tran.com/pdf/QSCAPE%20CATALOG.pdf
Everything is new. Every component has been re-engineered to work seemlessly together, from the transformers (Qset & Qhex), to the enclosures both wall mount and direct burial vaults (Qwall & Qvault), to the hub and stake assemblies (Qtrix). Even the cable and waterproof connectors have been re-designed in a most remarkable fashion. (Qclik & Qwire) Quality components and materials are everywhere. Every surface and feature has been thought through and engineered to perform.
Please take a long look at the attached catalog. It is a pretty complex system that takes a bit of time to fully understand. I will be posting more on this in the near future, perhaps a separate thread to discuss each component.
Enjoy.
