Lightscaping Designer
Trade: OUTDOOR LIGHTING
Interior Lighting?
What are the possibilities of low voltage interior lighting? With the demand for less energy consumption wouldn't there be a market?
![]() If there is an obvious reason and I am just not seeing it please let me down easy. ![]() Thanks,
STEVE ISLANDER LIGHTSCAPING INC "LIGHTING for LIFE OUTDOORS" FL. EY12000225 |
Trade: Home Remodeling
Re: Interior Lighting?
Every room I do now always have two switches, one turns on flourescent/neon lights (for day saving), and one turns on small halogens and/or pucker and/or strip, Xeno lights with dimmer, sleep-timer control and/or remote control capabilities (for night savings). Design could be on ceiling, walls, stairs, rails, etc. Let your design imagniations run wild!!
Every room I do now always have two switches, one turns on flourescent/neon lights (white/cool temp for day/heat saving), and one turns on small halogens and/or pucker and/or strip, Xeno lights with dimmer, sleep-timer control and/or remote control capabilities (soft tone for night/warm effects & savings). Design could be on ceiling, walls, stairs, rails, recess, hidden, etc. Let your design imaginations run wild!!
selfcontract,
Are these low voltage systems fed from a low voltage transformer?
#5 | |
INTEGRA Works Inc.
Trade: Lighting Systems, Design / Build
Re: Interior Lighting?Quote:
I have developed a substantial business in designing and installing residential interior lighting systems. Essentially I act on behalf of the owner as their lighting designer. I design, specify, procure, install, project manage the electricians, lamp, trim and aim complete custom interior lighting systems. I will also work with automation companies or provide full dimming systems when required. It is a challenging environment in which to work. You will always be jostling with architects, builders, interior designers and electricians for the work. It can also be very rewarding. By handling all of the interior lighting you generally position yourself very well for doing all of the exterior architectural lighting as well as the landscape/outdoor lighting. Have a great day.
James Solecki INTEGRA Works, JSLDesign, LED Lights Direct www.integralighting.com www.JSLDesign.ca Member: IESNA, AOLP, LO, MBA |
Handle It!
Low Voltage does not always equate into efficiency. Halogens waste massive amounts of energy in heat loss both in the bulb and the transformer.
LED is the only true low-consumption lighting available. The "curly-Q" fluorescent bulbs are pretty darn good as well and will only get better
Trade: electrical contractor
Tcp brand fluoresent curlly type best on market if ya use cheaper brands the kalvens in the light will be consideably less. also cheaper brands will have over 50%lumens depriciation over the life of the lamp.
i agree with Malco on led check out american lighting they have a very wide range of energy saving products |
low votage still runs watts. and a watt is a watt
Handle It!
I have had many experiences with the Curly-Fluros and YES, Brand does matter. In the biggest of ways. The multi-packs available at HD and Lowes are general garbage. Work well at first then rapidly down hill. Pay the extra and get the return.
But LED is the ONLY way. It will become so affordable and so common in the not so distant future that you will have to search for todays conventional types.
#10 | |
woodchuck2
