Installation Processes--How Do You Sequence Your Jobs?
Old 04-16-2006, 01:33 PM   #1
Avalon
avalon's Avatar
Trade: Landscape Lighting Designer/ Contractor
I would like to see how any of you sequence your installation processes. Is there a certain pattern of events that your prefer to follow? For example, do you follow a pattern like this or another: flag your job first, excavate, pull wire, place fixtures, make connections, mount & tie-in transformers, test, bury, and perform adjustments?
Here are a couple of added questions: 1) Do you bury prior to final adjustments? 2) Do you do night adjustments? 3) Do you get the homeowner involved prior to final burying in case of additions to the system? Any other input would be interesting.
Mark Carlson, CLVLT #0631
Avalon Artistic Landscape Lighting
member AOLP
avalon is offline
Old 04-29-2006, 05:04 PM   #2
patferris's Avatar
Re: Installation Processes--How Do You Sequence Your Jobs?
I am new this site but I would like to ask what others do also as well as let you know what I do.
I typically use CAST Lighting fixtures, wire, transformers, and accessories. I would say about 90% of the time. I found that at first although said to be an easier wiring system, took longer to install. After sometime I have my process down.
First - mount and test transformer.
install remote photo cell if needed.
Second - place fixtures around property
install fixtures where necessary
Third - pull wire runs to spider
splice and wire connections at spider
Fourth - splice and wire runs into transformer
test voltage and document
Fith - burry wires
There is more to it but that is the plan I go by. Anybody else?
Pat Ferris
Lighting Design
www.goldenleaf-lighting.com
patferris is offline
Old 04-30-2006, 02:23 PM   #3
Lighting Designer
NightScenes's Avatar
Trade: Landscape Lighting Designer/Installer
Every installation is a little different but here is the rundown (most of the time). 1. Install and check transformer. 2. Place fixtures. 3. Pull wire and make connections. 4. Check voltages on everything and make voltage adjustments. 5. Seal all connections. 6. Cover most of the lines, leaving plenty of room to move fixtures. 7. Make night adjustments. 8. Go home and have a good stiff drink. 9. Come in the next day and finish covering all lines and make the job site beautiful. 10. Collect my hard earned money.
Paul R Gosselin, CLVLT 0632
NightScenes Corporation www.night-scenes.com
President, AOLP
www.facebook.com/NightScenes
NightScenes is offline
Where to bid jobs ButlerDesigns Business 20 07-19-2010 11:51 AM
How do you price jobs? johnny_b01 Business 11 08-05-2007 10:58 PM
Small Jobs linkster01 Business 13 06-30-2006 09:52 AM
Installation costs? dennyc Carpentry 2 06-10-2006 11:09 AM
Getting Service Jobs gravtyklz Electrical 6 03-06-2006 06:11 PM
