Trade: Masonry
Electricians Are NOT Smarter Than Landscapers
Every single time (admittedly only three occasions) that I have witness a low-volt installation that was performed by a proffessional electrician, they went and wired the bloddy thing up incorrectly. Daisy-chain style. Ac and Dc are different This is reminds me of the old snausages commercial "dogs don't know its not Ac".
Sorry for the BS rant, but I just lost a bid and the electrician did it wrong--now there sits a shoddy lighting job, messing up my beautifully installed landscape! Also the other guy (a fairly sizable company actually) used this ****ty black plastic lights, not the dope-assed copper fixtures that I would have gone with. And I doubt money was the reason. I might have underbid the other guy, who knows? Who cares? Asshole electrician ****ed up my landscaped and I am pissed. End rant. Have fun 'scaping y'all. And don't let nonsense mess up your fun
Trade: Electrical
Re: Electricians Are NOT Smarter Than Landscapers
It's highly unlikely the lights were DC
Lighting Designer
Trade: Landscape Lighting Designer/Installer
Hey Rock, you can always go back to that client and offer them your services to replace that stuff. You can then charge em double and make even more money.
Paul R Gosselin, CLVLT 0632 NightScenes Corporation www.night-scenes.com President, AOLP www.facebook.com/NightScenes |
#4 | |
Trade: Licensed Electrician
Re: Electricians Are NOT Smarter Than LandscapersQuote:
Essentially running your fixtures in parallel, thus they each see identically whatever voltage you're using? Sorry, I've never done landscape stuff, and won't be anytime soon, but it never hurts to learn
#5 | |
Trade: Masonry
Walker J--it is a gauranteed fact that the lights are Dc.....
Nightscape, thanks for the suggestion, but the customer will likely not know the difference and will just have to keep calling the electrician back to change bulbs...then again, since he daisey chained up like 9 fixtures in a row, the differences in voltage will certainly be visible. Anyway I'd feel like a jerk informing the customer that their lighting was done wrong. I do not bad mouth the competition. BTW this thread is not intended as incindiary, I mean noone any offence, just needed to bitch for a minute |
So they're connected in series, thus each seeing identical, divided voltage. And this means that line loss is shared between the lamps, instead of being obviously different between the first fixture and the last?
This means you can only use so many fixtures before they drop below the optimum voltage, and that if one goes out, they all do? We are educable you know |
Trade: Plumbing & Electrical
I think I see why he lost the job. ...and they are called lamps...bulbs get planted in the ground.
"....And then we all switch places when I ring the bell" -Adrock
#8 | |
Resistance of wire over such a short run would be so small. OHMS LAW! V=IR solves all of your problems and looks like this using random numbers... They sound to be connected in parallel... ![]() But if series...
woodchuck2
If the lights were hooked up in series then the Installer needs to be educated, not everybody. You would have a drop in voltage regardless if AC or DC when wired in series.
Trade: Kitchen & Bath
Your circuit is not DC unless you are using a converter or rectifier to change the AC supply to DC, or you are running the landscape lighting from batteries. If the lighting is low voltage it is running on a transformer which uses magnetism to covert a voltage to a lower voltage. Transformers do not change AC to DC. Whether or not a circuit is AC or DC has no bearing on voltage drop due to fixtures in a series circuit, nor any bearing on amperage drop due to fixtures in a parallel circuit.
Trade: Masonry
You run one wire straight from the transformer, to a junction point(this main lead is commonly called a "home run"), at which the wire is spliced into individual wires (this junction point is called the "hub"), each going to the individual light fixtures. If run in series or in parallel each lamp will see successively less voltage. Both too much voltage as well as not enough voltage can lead to lamps (or bulbs, if you will) failing.
I could draw a diagram, but it is simple really and most manufacturers of landscape lighting systems have the information regarding proper installation readily available. |
#12 | |
Lighting Designer
It would be foolish to install landscape lighting or just about any kind of lighting in series as this would take out entire sections of lighting if any one lamp burns out.
#13 | |
I've seen some long runs. If you're dealng with low voltage, line loss isn't insiginificant And I imagine it would be a PITA if one lamp went out and they all went out Rockhead, if you simplified your correct circuit, which would it look like? Parallel or series? Last edited by Sportbilly; 03-23-2008 at 12:08 PM. |
Re: Electricians Are NOT Smarter Than Landscapers |
Trade: Masonry
I've already described my wiring configuration, which is industry standard. Maybe I'll draw you a little picture another time. Thanks for the "lol", cute.
I myself am no electrician, I simply know incorrectly laid landscape wiring when I see it. Guess you actually ARE smarter than me. Happy easter, peace. |
Lighting Designer
When running the wiring in parallel you will have a drop in voltage between fixtures. This is why most are going to the "hub" method of wiring to evenly distribute the voltage to each fixture. This however is also flawed to some degree by the wattage of the lamps that are used on the circuit. A 20 watt lamp will have less voltage drop on it's 25' lead wire than a 35 watt lamp. The "T" method or "loop" are also very good at distributing the voltage evenly although not quite as good as the "hub". The daisy chain, which is what I believe Rock Headed is talking about is the worst method, in that the voltage drop continues down the parallel circuit making each lamp a little dimmer.
#17 | |
Thanks, that's what I wanted to know Rock, you almost put it this clearly, but not in enough detail for me to visualise it in my head Learning all the time
#18 |
I'm not 100% sure on all of this so maybe someone can second this or point out if I am wrong but here goes...
Parallel circuits have an amperage drop at each fixture but voltage is constant* Series circuits have a voltage drop at each fixture but amperage is constant *there is a voltage drop at any point in the circuit due to the distance from the transformer(or breaker as the case may be) How to calculate voltage drop Cable length - length of cable used from the transformer to the fixture on which you are measuring the voltage drop (in feet). Total watts - sum the wattages of every lamp along the cable length. Cable constant - indicates the thickness of copper wire; a thicker wire results in less voltage drop. Cable length X Total watts = Voltage DropCable constant ![]() Configuring the circuit as a "T" is done to cut the Cable Length down since you can calculate the drop individually on each side of the "T"(These are also sometimes referred to as "I" layouts) ![]() Configuring a loop system can also cut down on voltage drop, please note this is still a parallel 12V AC system. Both ends of the positive are hooked to the same positive terminal on the transformer and both ends of the negative loop are hooked to the same negative terminal on the transformer. ![]() How voltage drops affect a lamp: Voltage Light Output Lamp Life 12.5 V 170% 80% 12 V 100% 100% 11.5 V 80% 200% 11 V 75% 300% 10.8 V 70% 400% 10.5 V 65% 500% As you can see, a lamp with a design voltage of 12 Volts will deliver 80% of its light output and its life will double by reducing the voltage to 11.5 Volts. The light loss is hardly noticeable to the naked eye while lamp life is generously extended. Therefore, you want to experience a slight voltage drop to all lamps in your low voltage lighting system. The recommended feed to each lamp is between 10.8 Volts and 11.5 Volts. Last edited by orson; 03-23-2008 at 09:32 PM. |
#19 |
Moonlighting
Trade: landscape,lighting contractor
Hey Guys,
I am glad to see Paul got involved with this thread. He is a good guy who really tries to explain things clearly so everyone can understand. What I find amazing is he didnt get offended by the topic but offered up his knowledge to help clarify things anyway. He is an electrician also. Keith |
#20 |
In the above example, Would there be a performance vs. price advantage if the 12ga loop was replaced with a 10ga T or hub lay out? Thanks, Joe
| Residential Electricians Needed In Los Angeles | L. B. Condulet | Help Wanted or Looking For Work | 10 | 05-09-2008 11:28 PM |
| Electrician's Challenge Las Vegas | Bubbles | Electrical | 20 | 10-06-2007 06:38 AM |
| Experienced Electricians Needed- South Florida | recruit4meisner | Help Wanted or Looking For Work | 0 | 04-06-2007 09:39 AM |
| Attention Landscapers: I can deliver sod to you directly at cost! | lib135 | Landscaping | 1 | 01-08-2007 09:37 PM |
| Attn South Florida Electricians!! | recruit4meisner | Help Wanted or Looking For Work | 9 | 05-25-2006 02:16 PM |
