Do It Yourself Fiber-optics
Old 06-08-2007, 04:12 PM   #1
Jacey's Avatar
Trade: Landscape
I have a small waterfall area I would like to illuminate. Does anyone know how involved it would be and expensewise to run fiberoptic strands thru-out the rocks of a 6x15 run disappearing waterfall?
Jacey is offline
Old 06-08-2007, 06:24 PM   #2
mdshunk's Avatar
Re: Do It Yourself Fiber-optics
No big deal. National Specialty Lighting has a great fiber optic product that would work well there.
http://www.nslusa.com/galaxy.html
mdshunk is offline
Old 06-09-2007, 12:58 PM   #3
POOLMANinCT's Avatar
no big deal for such a small job. fibers are basically a "pipe of light" when the runs & end fixtures get more detailed, things get complicated. be sure to "cleanly hot knife" your terminations. illuminator must be well ventilated or you will burn bulbs quickly.
be sure to leave about 18 inches at illuminator terminal, as "hot knife" cuts glaze in time, & need to be recut to restore brilliance.
ray
......Less with the jaw & More with the paw.....
POOLMANinCT is offline
Old 06-09-2007, 01:01 PM   #4
btw, plan your "loops well" fibers can not be spliced if you screw up, also handle radius turns softly or you may crack a strand.
btw a buddy at the phone company splices fibers with a 200k machine via some sort of explosion.
ray
Old 06-10-2007, 12:00 AM   #5
Lighting Designer
NightScenes's Avatar
Trade: Landscape Lighting Designer/Installer
Check IlluminFX. It's very easy to install.
Paul R Gosselin, CLVLT 0632
NightScenes Corporation www.night-scenes.com
President, AOLP
www.facebook.com/NightScenes
NightScenes is offline
Old 06-10-2007, 04:36 PM   #6
Jacey's Avatar
Trade: Landscape
Can I get wholesale pricing, or do I have to be certified or something. I do the waterfalls for a living and most likely will branch out into lighting them as well.
Jacey is offline
Old 06-10-2007, 05:17 PM   #7
mdshunk's Avatar
Beats me. Might want to check out the one Paul recommended as well.
mdshunk is offline
Old 06-11-2007, 05:15 PM   #8
mickeyco's Avatar
Trade: Squirrel Handler
I'd like to add one thing, I'm assuming this would apply to this type of fiber optics but I'm not sure, I'm only familiar with the communications type. Use a face shield or at least safety goggles and some gloves if you're cutting this stuff, it splinters and you can get some real nasty slivers that are really hard to find especially if it's in your eye.
mickeyco is offline
Old 06-11-2007, 09:39 PM   #9
Lighting Designer
No certification needed for this type of lighting. There is no electricity in the water. The light and equipment is located at a distance and the light travels through the fiber optic cables. The illuminFX system plugs in and you just place the ends where you want the light. It's really pretty simple. Check your irrigation supply house or www.terradek.com .
Good luck,
President, AOLP
Old 06-23-2007, 08:44 PM   #10
Jacey's Avatar
Trade: Landscape
Hey Paul~I got IllumninFX to send me their CD..but it is really not very well produced...Powerpoint at its most fundamental..and the instructions to left click the mouse to move it along didn't function on my XP.. And what is at Terredek?..Looked like they handle all kinds of lighting..but what does that have to do with IlluminFX? Do I have to cut and splice and get shards in my face like the last guy mentioned..or is there a precut to the chase so to speak out there?
Jacey is offline
Old 06-23-2007, 10:13 PM   #11
Lighting Designer
Terradek is a lighting distributor who sells the illuminFX. You order the illuminator with either a halogen or metal halide lamp and fiber harness separately. The harness can have up to 16 leads or fiber channels. These can range in size depending on what you need. You tell them what lengths you need and they pre fab them for you.
It takes no time at all to install. It's a "plug and play" type of lighting system. I have installed several of these things and I don't think I've ever taken more than an hour to install one.
President, AOLP
Old 07-11-2007, 11:20 AM   #12
Tomwilllight's Avatar
I've installed fiber several times and had no problems by following directions. It is fun to work with and the reduced electrical/water problems make it a plus for any water feature or pool setting.
My guess is the "shattering" problems were a result of using communications grade glass fibers. I've heard you really need to be careful with the glass - you can easily drive a glass fiber under your skin and break if off. That stuff is not what you need in your waterfalls.
Of course, it is always smart to use eye protection!
The fiber I've used is plastic and easily cut with the hot knife - just follow directions that come with the knife. The suggestion that you leave extra fiber at the illuminator so you can dress the cut again as needed is excellent.
The big problem with fiber is that the light loss from the fiber is very high. The longer the run, the less light ends up where you want it. That's why you may want to "loop" the fiber - bring light in from both ends where it meets in the middle.
I agree with the many good things said on this forum about TeraDek.
Tom Williams
Williams Landscape Lighting Design, CLVLT #0424
www.wlld.us
Tomwilllight is offline
Old 07-12-2007, 11:35 AM   #13
Joey D.
Unique's Avatar
Trade: Low Voltage Lighting Manufacturer
Send a message via Yahoo to Unique
Illumin FX is the way to go especially for a DIY person. It does not get much easier then their system!!!
Unique is offline
Old 09-04-2007, 08:30 PM   #14
Jacey's Avatar
Trade: Landscape
Been awhile..so most of it is rigged up and looks pretty great..except some of the end lights tend to blind when approached from off angles. Is there a way to glance the light off and still give the affect to the subject being lit? This is still the waterfall project...which is 3-D and viewable from all sides.
Jacey is offline
Old 09-04-2007, 08:40 PM   #15
Jacey's Avatar
Trade: Landscape
Jacey is offline
Old 09-04-2007, 08:44 PM   #16
Jacey's Avatar
Trade: Landscape
dang thing duplicated and it won't let me delete...or am I missing somethin
Jacey is offline
Old 09-05-2007, 09:29 AM   #17
Lighting Designer
Jacey, there will always be an angle with glare. The object of aiming is to point the fixture so the glare is only visible from the area that is least traveled. I am still trying to get over there. One of those local murders (Mike Allred) was a close friend and this has put a few more kinks in the works for me. I will get there though.
President, AOLP
Old 09-05-2007, 10:14 PM   #18
to reduce "blinding"
cut terminating points at an 11degree angle, making a "cone."
I installed a few 300 strand lights last week, HOLY COW!!!!!!!!
how are you guys "training" your master & slave illuminators?
ray
Old 09-09-2007, 03:16 PM   #19
Jacey's Avatar
Trade: Landscape
Paul, figgered you were tied up..Man, sorry to hear about your friend. I didn't hear anything about it.
Jacey is offline
Old 09-09-2007, 03:20 PM   #20
Jacey's Avatar
Trade: Landscape
ray
These are precut...kinda on loan for display only til we can muster some business to use them. That's a good suggestion tho.
Do you have pix of your 300 strand lights? Sounds awesome!
What do you mean..How are you guys "training" your master and slave illuminators.. you talking about a lighting process or do you have people chained up in your basement?
Jacey is offline
Fiber Optics in concrete countertops 6stringmason Concrete & Paving 17 03-16-2011 05:49 PM
Fiber Cement almost same cost as Vinyl? MKECONTRACTOR Windows, Siding and Doors 17 12-20-2008 06:34 PM
fiber cement board and plank labor costs ubercontractor Windows, Siding and Doors 10 10-05-2007 09:30 PM
Fiber reinforced slab cost in central NJ gschotland Masonry 0 11-18-2006 02:27 PM
rotten fiber board? gcajnr21 Painting & Finish Work 3 09-12-2006 06:24 PM
