Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Landscaping > Outdoor Lighting
Old 03-23-2008, 02:00 PM   #1
Lightscaping Designer
Trade: EXTERIOR LIGHTING DESIGNER
Connectors
What type of connector and why?
I have read about the Buchanan and Ace connectors and like what I am seeing.
What about the disc style connectors or any other point type connectors?
Does the disc type provide enough protection?
By the way HAPPY EASTER everyone
STEVE
ISLANDER LIGHTSCAPING INC
"LIGHTING for LIFE OUTDOORS"
FL. EY12000225
SOUTHERN LITES is offline   Reply With Quote
Old 03-23-2008, 02:02 PM   #2
mdshunk's Avatar
I have yet to see an insulation piercing connector that will not fail in time.
mdshunk is offline   Reply With Quote
Old 03-23-2008, 02:07 PM   #3
mdshunk,
What's your take on the silicone filled wirenuts?
STEVE
FL. EY12000225
Old 03-23-2008, 02:15 PM   #4
mdshunk's Avatar
Originally Posted by SOUTHERN LITES View Post
mdshunk,
That's my preference. Matter of fact, I normally make my own.
Old 03-23-2008, 03:32 PM   #5
Lighting Designer
NightScenes's Avatar
Trade: Landscape Lighting Designer/Installer
I use the buchanan crimp almost exclusively and seal it in a DBR. I have used the Kichler Quick Disc in the past and still do sometimes in above ground locations.
Paul R Gosselin, CLVLT 0632
NightScenes Corporation
Vice President, AOLP
www.night-scenes.com
NightScenes is offline   Reply With Quote
Old 03-23-2008, 06:48 PM   #6
Paul,
How would they work down here around the gulf?
STEVE
FL. EY12000225
Old 03-23-2008, 09:06 PM   #7
Lighting Designer
I would not use the quick discs in your area at all.
Old 03-24-2008, 12:48 AM   #8
Sharpie
trav007's Avatar
Trade: Renovation contractor
MDshunk, how do you " make yur own" ? Are you talking about those little 3m style connectors or something larger?
Travis
www.customkreations.ca
"The most perfect technique is that which is not noticed at all"
-Pablo Casals
trav007 is offline   Reply With Quote
Old 03-24-2008, 01:28 AM   #9
Handle It!
MALCO.New.York's Avatar
The Major phone companies (48/96v) use Silicone loaded connectors in Sewer run communication lines.
That would be my choice.
Ultimate Wisdom---------
http://www.youtube.com/watch?v=_k1Ug...ture=rec-HM-r2
MALCO.New.York is offline   Reply With Quote
Old 03-24-2008, 06:32 AM   #10
Lighting Designer
I don't think those are rated for the amperages that this lighting can pull.
Old 03-24-2008, 04:46 PM   #11
Paul I sent you a P.M.
STEVE
FL. EY12000225
Old 03-24-2008, 04:50 PM   #12
mdshunk's Avatar
Just squirt a wire nut full of silicone. Never had one fail yet. For the bigger stuff, like #6's and #4's, I split bolt it and put in one of the ScotchCast epoxy baggies.
Old 03-25-2008, 07:02 PM   #13
illuminata's Avatar
Trade: Exterior Lighting
As someone who does a lot of service work I feel I have seen almost every possible method of connecting LV lighting cables and the only one I use below grade is ACE connectors. Quick connectors are quick to install and quick to fail. Silicon filled wire nuts are mechanically weak and pull out if the wire is pulled on anywhere in the run. Other methods are just too slow, too exspensive or too dodgy for me.
Paul Eddleston
ILLUMINATA Landscape lighting
www.CreativeExteriorLighting.com
Tel: 248-207-0894 Fax: 248-282-0851
illuminata is offline   Reply With Quote
Old 03-25-2008, 07:06 PM   #14
mdshunk's Avatar
I would modify that to say "improperly installed wire nuts are...."
I know I could tow a truck with a properly installed wire nut on two sufficiently strong pieces of wire.
Old 03-25-2008, 08:20 PM   #15
illuminata's Avatar
Sure, but I have never seen one here. Then again, I guess I would only get to see the improperly installed ones.
Paul Eddleston
Old 03-30-2008, 05:44 PM   #16
LightYourNight's Avatar
Trade: Landscape Lighting Professional
3m dbr splice kit tube are the way to go.. expensive.... but worth it.
filling a wire nut with silicone doesnt sound like a good idea to me...
John Paul Cambruzzi
Landscape Lighting Specialist, LLC
www.LightYourNight.com
LightYourNight is offline   Reply With Quote
Amp No Junction Box Connectors Bubbles Electrical 25 12-12-2007 11:43 PM
Metal Connectors highlife77 Electrical 10 12-07-2007 06:33 AM
How to Slip poly onto the poly barb connectors robertc65 Plumbing 14 10-11-2007 11:07 PM
Stainless simpson connectors carm Contractor Swap 0 05-29-2007 07:22 PM
Deckorators connectors RobertCDF Landscaping 0 11-26-2005 11:31 PM
