Trade: Floorist
Tree Removal Advice
I will be removing this tree for the church, down to the dirt. Someone else will be doing the stump and root removal. If anyone has suggestions on specific equipment I should consider renting or buying for the job, I would like to hear them. I may never need the tools again so top-of-the-line may not be necessary. My inclination is to use a sawzall (because I already have one of them) to trim away the smaller branches, but what to use for the trunk? Also, Because the tree is not tall enough to land on any structures, would you fell it first, then trim it?
Thanks in advance for your thoughts. Just ask if you have any flooring inquiries.
• • • Greatness is a result of focused, deliberate practice • • • |
Re: Tree Removal Advice
Small gas powered chain saw $120, Trim the branches off first, 10ft stepladder, then drop it. GMOD
| The Following User Says Thank You to genecarp For This Useful Post: | TopFloor (11-11-2009) |
Gloves and safety glasses.
| The Following User Says Thank You to SC sawdaddy For This Useful Post: | TopFloor (11-11-2009) |
#4 | |
Trade: Framing
Re: Tree Removal AdviceQuote:
Fell it, trim out. |
| The Following User Says Thank You to Framer53 For This Useful Post: | TopFloor (11-11-2009) |
Drop that twig onto the ground with a rented or borrowed chain saw.
| The Following User Says Thank You to JonM For This Useful Post: | TopFloor (11-11-2009) |
Trade: Painting - Restoration
Homemade PNAP and 2 gal of gas...JK!
| The Following User Says Thank You to Kuba For This Useful Post: | TopFloor (11-13-2009) |
make your cut high so that it doesnt take out the bench... Make sure you have it tied off and have someone pulling in the fall direction so that it doesnt bust any of those bench bricks... or you paying to replace them
once that is done... take off the 5 ft section and carry it off.. dont take my advice, ask a tree pro... thats just what I would do. |
Trade: custom home building
I would use my Sven folding saw.
| The Following User Says Thank You to cleveman For This Useful Post: | TopFloor (11-13-2009) |
Trade: builder/renovator,Squam Lake NH
My 14 yo son took a tree down that size yesterday with an axe ,no adivice or exspirennce
| The Following User Says Thank You to jeffatsquan For This Useful Post: | TopFloor (11-12-2009) |
Trade: Landscaping
That's what chainsaws are made for, only a few seconds with a sharp one. I guess a sawzall would work though, alot more work than necessary.
Yes, notch it high so when it falls the branches will end up holding the whole deal in the air on it's side so you can delimb it. Why are they taking it out? Looks like a cool little tree. |
Trade: Porch and Deck Builder
Trim off some of the lower limbs. Make sure you notch it properly, (google away), and you should be able to place withing 15 degrees of where you want it. But have some rope just in case.
Otherwise, I'd be tempted to buy a 12" sawzall blase and just have at it.
"Neek...Neek...yoo-a-moronna Neek. Getta-da-fookin-a-jacka-ham!" http://www.vicporch.ca Deck Fence Porch Builder Toronto |
Twisted Cameron
Trade: Concrete, Metal buildings
break out your swiss army knife, use the serrated blade, and the scissors to cut off the branches.
#13 | |
Trade: Floorist
#14 | |
Trade: Floorist
Trade: Floorist
He's going to be a fine lumberjack.
#16 | ||
Trade: Floorist
I figured I might need this 10" pole saw to reach the highest limbs, but I suppose I wouldnt need it if the tree gets cut down first: ![]() This 14" gas-powered (below) looks like it will do the bulk of the work just fine. I know it is not what a pro would use, but I am fairly certain this is the only tree I will ever be cutting down. Hopefully I can get by with it: ![]() Quote:
The roots have begun to make the surrounding brickwork a liability. My guess is someone took a spill and that was the beginning of the end for this tree. I am with you- the tree is really cool.
#17 | |
Trade: Floorist
#18 |
Palisade Point Const.
A small chainsaw will get it done in short order. A sawzall will also get it done, but it will take a bit longer. knock it down, remove the branches, chunk up the trunk. Take a shovel and clear the dirt away from the roots. Use an ax or the sawzall to cut the roots below ground level and remove what's left of the trunk. If it wasn't surrounded by the bricks, I'd say to hook onto the trunk with your truck and give it a tug to break loose the last couple roots, but without power, you are going to have to dig deep and cut everything in order to get rid of everything above ground level.
| The Following User Says Thank You to TempestV For This Useful Post: | TopFloor (11-13-2009) |
#19 |
If you fell it first then delimb, be very careful and know which way that it will roll when you go to cut a limb. Have a clear escape path in case it does not roll the way you expect while delimbing. Also, pay attention to where you start your cut when the tree is down and being held up by the limbs to avoid getting the saw wedged in the cut.
#20 | |
Trade: Floorist
| Tags |
tree trim fell ![]() |
| Need Advice on Decorative Beams Removal | spectrum | Carpentry | 18 | 05-13-2009 01:34 PM |
| large scale tree removal | 72chevy4x4 | Landscaping | 6 | 03-25-2009 10:39 PM |
| Tree trunk removal | trav007 | General Discussion | 15 | 03-02-2009 11:05 PM |
| Tree Stumb Removal | jerome8283 | Landscaping | 22 | 09-22-2007 08:04 AM |
| Land clearing / tree removal | Cherryhill_cons | Excavation & Site Work | 7 | 07-30-2007 04:55 PM |
