Tapping Into Galvanized Water Main
Old 09-05-2008, 01:30 PM   #1
mtbmac's Avatar
Trade: irrigation
Here is my situation. I am installing a automatic sprinkler system in a older home that has a Galvanized Water Main. I will be tapping into the Water Main just outside the home, and T-ing off to the Sprinkler System. My question is, am I better off to cut the Main, then re-thread both ends and install a Union into the mix, or can I get away with using a Compression T and going from there? I have not had much luck using Compression fittings in the past and the Water Main is down about 6 feet. Hence, I really don’t want to have to dig it up, if the T doesn’t hold.
mtbmac is offline
Old 09-06-2008, 07:33 AM   #2
Unforgiven's Avatar
Trade: Superintendent for Commercial GC
Re: Tapping Into Galvanized Water Main
In the fire sprinkler trade they use a "mechanical tee". A diamond shaped "biscuit" is cut from the pipe and a saddle tee place over the hole and held in place with U bolts.
Unforgiven is offline
Old 09-06-2008, 05:44 PM   #3
Moderator
Double-A's Avatar
Double post.
Please read our rules on posting. They are the first post in every forum on the board. Thanks.
New York Times, July 20, 2006
Double-A is offline
Compression T Fitting vs. Re-Threadding Galvanized Water Main mtbmac Plumbing 47 09-14-2008 12:33 AM
Water Main plumberman Plumbing 21 08-17-2008 02:23 PM
Water Main Size Sparky Joe Plumbing 21 07-26-2008 11:23 PM
replacing galvanized water service DAVESOLEAU Plumbing 24 05-31-2008 11:05 PM
instant hot water mowpar Plumbing 6 03-23-2008 10:56 PM
