Stained Fences
Old 01-17-2016, 06:30 AM   #1
Wrenched's Avatar
Rewards Points: 22
Stained Fences
When using stained fences in landscaping, how often do you tell you clients the fences need to be re-stained? My rule of thumb is ever 5 years depending on the location. Is that too often or not often enough?
Wrenched is offline
Old 01-17-2016, 07:04 AM   #2
all else fails dynamite
AccurateCut's Avatar
Trade: Fencing/Landscaping Contractor 2nd Gener Carpenter
Rewards Points: 750
Re: Stained Fences
Number of factors such as weather, sprinklers, stain used, Ive seen some that go 2 years and need some attention others may go longer.
Can we build it
AccurateCut is offline
Old 01-18-2016, 06:39 AM   #3
Wrenched's Avatar
Rewards Points: 22
Re: Stained Fences
Thanks man. I was thinking the same thing. I know that a coastal fence requires attention much sooner because of the sun and heat.
Wrenched is offline
Old 01-18-2016, 03:50 PM   #4
Mod / ArchiBuilder
Cole's Avatar
Trade: Design/Build Pergolas & Pavilions
Rewards Points: 1,486
Re: Stained Fences
We say 2 years. With some darker colors, you can get another 6 months to a year.
Cole is offline
Old 01-20-2016, 03:12 PM   #5
BenTaylor's Avatar
Trade: landscaping
Rewards Points: 66
Re: Stained Fences
Sprinklers make a huge difference. Without regular rainfall and outside the range of sprinklers you can get away with 5 years. With regular exposure to water you really have to stay on top of that stuff though, or you'll end up replacing the whole fence.
I live in Idaho where it's dry and sunny most of the time, and if half a fence is in sprinkler range, you can just see that portion rot away underneath the otherwise pristine wood. It makes a huge difference.
BenTaylor is offline
Old 08-02-2016, 09:59 PM   #6
francodamico1's Avatar
Trade: Landscape Construction
Rewards Points: 201
Re: Stained Fences
2 Years is a safe bet
Damico's Landscaping
www.damicoslandscaping.com
francodamico1 is offline
Old 10-29-2016, 05:23 PM   #7
Chatham PM's Avatar
Trade: Pressure Washing, General Maintenance
Rewards Points: 8
Re: Stained Fences
What ever the stain manufacturer says than I just advise them of the factors that will reduce the life of the stain.
Chatham PM is offline
Old 12-30-2016, 08:16 PM   #8
Learn-Build-Enjoy
ASidhu's Avatar
Trade: Carpentry and Landscaping
Rewards Points: 128
Re: Stained Fences
It depends on the type of stain you are using. Read the instructions and manufacturers recommendations. Typically 5 years max but 2 years is better. Clear stains require more staining. I like oil based stains.
ASidhu is offline
Old 12-31-2016, 12:06 AM   #9
PNW Painter's Avatar
Trade: Painter
Rewards Points: 66
Re: Stained Fences
It's depends on whether its a transparent, semi-transparent, semi-solid or solid stain. The materials and design can also make a difference.
Typically, I'd recommend 1-2 years for transparent oil based stains and about 4-5 for solid waterborne stains.
PNW Painter is offline
Old 12-31-2016, 04:00 AM   #10
Learn-Build-Enjoy
ASidhu's Avatar
Rewards Points: 128
Re: Stained Fences
Pretty much what I wanted to say, but you said it better
ASidhu is offline
Old 01-02-2017, 12:53 PM   #11
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,168
Re: Stained Fences
I use Woodrich stain because it's the only stain I could find that works on wet wood. If it's a fence it's pretty much guarantied to be wet where I am. It's also a tough stain, been using it a long time. I tell them three to five years on a fence.
kenparsonscontracting.com
KennMacMoragh is offline
Made in USA product list J.C. General Discussion 360 06-16-2018 04:52 PM
Upcharge for pet stained carpet removal? jasonmk12 General Discussion 11 10-17-2015 07:04 AM
Painting pipe fences Balzomedic Painting & Finish Work 8 07-21-2012 11:43 PM
Fences jaylord01 Marketing & Sales 5 10-21-2011 02:47 PM
