Slope Under Deck
Old 05-30-2017, 12:26 AM   #1
Rob77's Avatar
Slope Under Deck
Got a heavy slope under a deck I'm building. Owner did a cut and fill to level the yard. We're building deck past the slope. Slope is 4 ft drop over a span of 8 ft. Id say 40 degrees or so. Any recommendations to avoid erosion over time. Weed back and 6 mil plastic are the only things I've come up with at this point, but wondering if that's really enough. Thanks!
Rob77 is offline
Old 05-30-2017, 12:48 AM   #2
GC/carpenter
Californiadecks's Avatar
Rewards Points: 9,218
Re: Slope Under Deck
Retaining wall.
_________
Californiadecks is offline
The Following User Says Thank You to Californiadecks For This Useful Post:
TNTSERVICES (06-02-2017)
Old 05-30-2017, 12:55 AM   #3
Rob77's Avatar
Yea it's too late for that. Posts are set onto footing that were already placed at bottom of slope. Most we can go up with a wall is 16" without covering the 6x6 posts. Can anything be put on the slope instead? Its not going to grow vegetation under there?
Rob77 is offline
Old 05-30-2017, 12:58 AM   #4
GC/carpenter
Plastic isn't recommended. Possibly some burlap cloth or something along that line. Gravel on top that.
_________
Old 05-30-2017, 01:00 AM   #5
GC/carpenter
Something like this. It's used for erosion control.
https://www.amazon.com/dp/B01634ISRS...a-309781384492
_________
Old 05-30-2017, 01:01 AM   #6
GC/carpenter
_________
Old 05-30-2017, 01:02 AM   #7
Rob77's Avatar
Ok, no plastic then. But gravel will definitely not stay on this slope, will tumble right down unfortunately. Landscape staples may be the only thing to hold it down
Rob77 is offline
Old 05-30-2017, 01:04 AM   #8
Rob77's Avatar
Thank you, i did see those burlap sheets but questioned if they were worth it bc I read they were biodegradable.
Rob77 is offline
The Following User Says Thank You to Rob77 For This Useful Post:
Morning Wood (05-31-2017)
Old 05-30-2017, 01:12 AM   #9
GC/carpenter
They are, but so is everything else, including plastic. The stuff at least deteriorates back into the ground vs. other cloth that crumbles and blows black confetti everywhere. Also it's thicker.
_________
The Following 2 Users Say Thank You to Californiadecks For This Useful Post:
Rio (05-31-2017), TNTSERVICES (06-02-2017)
Old 05-30-2017, 01:14 AM   #10
GC/carpenter
There really needed to be a retaining wall built first. At this point you have a slope that will require maintenance.
_________
Old 05-30-2017, 01:15 AM   #11
Rob77's Avatar
Gotcha, thank you very much. Worst case it has to be replaced every season or so, it will at least prevent any movement. Thanks again
Rob77 is offline
Californiadecks (05-30-2017)
Old 05-30-2017, 01:21 AM   #12
Rob77's Avatar
Yea the lack of wall was a major screw up. After the dig the owner didn't want to pay for a 60 ft long retaining wall. He wanted the hill covered as much as possible by a deck and that was that! I'm left figuring it out
Rob77 is offline
Old 05-30-2017, 04:59 AM   #13
General Contractor
greg24k's Avatar
Rewards Points: 7,410
Not sure what your location is, but besides soil erosion with a drop like this... you should also make sure your footings confirm to R403.1.7 Footings on or Adjacent to Slopes to be withing code compliance which specifies the placement of buildings and structures on or adjacent to slopes steeper than one unit vertical in three units horizontal (33.3-percent slope) shall conform to Sections R403.1.7.1 through R403.1.7.4.
greg24k is offline
Old 05-30-2017, 07:03 AM   #14
Rob77's Avatar
Greg this is in Connecticut. Let me review that code and be sure.
Rob77 is offline
Old 05-30-2017, 02:01 PM   #15
Talking Head
EthanB's Avatar
Rewards Points: 96
How deep did you put your footings?
Planer.....
EthanB is online now
Old 05-30-2017, 02:28 PM   #16
Rob77's Avatar
Because it was at bottom of the hill o extended sonotubes. Theres between 52"-55" under gound. 10" footings.
Rob77 is offline
Old 05-30-2017, 10:51 PM   #17
Dirtywhiteboy's Avatar
Rewards Points: 8,094
What is a 10" footing
Dirtywhiteboy is online now
Old 05-30-2017, 11:19 PM   #18
Renaissance Man
superseal's Avatar
Rewards Points: 5,436
Terrace it off with a coventry wall or similar and fill with decorative gravel.
https://www.ephenry.com/products/wal...coventry-wall/
supersealconstruction.com
superseal is online now
The Following 2 Users Say Thank You to superseal For This Useful Post:
Californiadecks (05-30-2017), Rio (05-31-2017)
Old 05-31-2017, 07:49 AM   #19
Rob77's Avatar
Actually that's what one thing we were thinking of doing. Good point. People do these things then I have to go play damage control!
Rob77 is offline
Old 05-31-2017, 07:57 AM   #20
Rob77's Avatar
Lol, 10" diameter. Did you think I went 10" down?
Footings are 60". About 52"-55" below grade.
Rob77 is offline
Recommendation for water proofing of multi level wood deck simeonk Roofing 8 11-28-2012 12:34 PM
Deck 1983 Bunited2 Decks & Fencing 5 11-27-2012 01:40 PM
built in gutter - changing slope zeppyroof Roofing 12 07-17-2012 12:12 PM
Correcting slope on post/beam deck. HDQinKC Decks & Fencing 10 04-27-2010 05:28 PM
Almost Under Deck Roof doublejz Roofing 6 04-18-2010 11:50 AM
