Sealing Pavers
Old 05-17-2009, 11:37 AM   #1
bob14-0's Avatar
Trade: home construction
Sealing Pavers
I'm doing a paver job where the customer has asked for the pavers to be sealed. I've never sealed them so have no idea of which product to use; acrylic, water based, Thompsons?
Any suggestions greatly appreciated as I'm trying to finish this job before Memorial Day.
Bob
I
bob14-0 is offline
Old 05-17-2009, 01:55 PM   #2
concretemasonry's Avatar
Trade: Masonry consultant
Re: Sealing Pavers
A good paving stone supplier will have exactly what you need.
Fendt would have it if you get near Ann Arbor or Farmington.
Dick
concretemasonry is offline
Old 05-17-2009, 03:44 PM   #3
bob14-0's Avatar
Re: Sealing Pavers
Thanks, I'll check that out - you seem to know a lot about s/e michigan.
My biggest concern with sealing is having too much gloss. I'll do a search for something that enriches the color and protects the paver without taking away from the rustic look.
Bob
bob14-0 is offline
Old 05-17-2009, 04:16 PM   #4
Re: Sealing Pavers
There are different coatings that do what you want. Fendt probably carries the.
You could also Google "Pave Tech" and see if there products are carried in your area.
I am a little familiar with Michigan after 7 years in Alpena (Top joint on the little finger when looking at the Michigan "hand map". I have always avoided Detroit except to use the airport as an escape route. The economy was too depressing, so i left about 5 years ago.
Dick
Old 05-17-2009, 05:54 PM   #5
bob14-0's Avatar
Re: Sealing Pavers
Well, at least your winters are milder now!
Thanks for the tip, the paver job will be completed Thursday, now I can go up north, relax, smoke a cigar and not work. I'll seal later when things slow down.
Regards, Bob
bob14-0 is offline
Old 05-17-2009, 06:26 PM   #6
Re: Sealing Pavers
Winters here are not warmer, but not the constant white fluff, moisture and later springs that you get near the Great Lakes. - A lot less snow!!!!
Also not the sloppy winter storms that miss (go south) of us and hit Chicago, Milwaukee and eventually the lower lower and the upper lower of MI. - The U.P. is a different world.
Dick
Old 05-25-2009, 12:59 AM   #7
primetime paint's Avatar
Trade: painting
Re: Sealing Pavers
sw has a 'natural' finish waterborne paver sealer you could check out
primetime paint is offline
Old 05-25-2009, 04:59 PM   #8
bob14-0's Avatar
Re: Sealing Pavers
Thanks for the tip. From what I've learned, sealing enhances the color and protects against stains - like coffee or soda spilled on them.
Bob
bob14-0 is offline
Old 07-27-2009, 05:01 AM   #9
scottwolves's Avatar
Trade: driveway / paving
Re: Sealing Pavers
Hi, To seal the blocks it us a case of pressure washing them very good before applying as the seal shows everything up!
scottwolves is offline
Pavers Over Concrete - My Cousin's Method Tommy C Masonry 67 10-29-2009 10:31 PM
Stamped concrete or real stone pavers in driveway? uridixsento General Discussion 1 04-27-2009 07:15 AM
Pavers around a new pool-slab or no slab? Richie-C Masonry 22 03-17-2009 08:53 AM
Drilling Pavers Joe Wood Masonry 33 09-24-2008 06:47 PM
Help please on sealing new pavers RTred Masonry 3 06-18-2007 09:38 AM
