Saw-Chain Dulling Far Too Soon
Old 12-30-2017, 10:52 AM   #21
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,584
Re: Saw-Chain Dulling Far Too Soon
Originally Posted by hdavis View Post
If that photo shows your normal chain tension, you're running it too loose...How are you filing the gage teeth (sometimes called raker teeth)?
Usually tighter than that, getting ready to pull this one.
Someone sharpens for me...down at the dealer.
artinall is offline
The Following User Says Thank You to artinall For This Useful Post:
hdavis (12-30-2017)
Old 12-30-2017, 11:32 AM   #22
hdavis's Avatar
Rewards Points: 791
I wouldn't worry that the chain may have gotten hot, It's just not an issue. Normally a chain would be shop sharpened periodically, but hand filed for touch up every tank of gas with the chain on the saw. Trees that lay around can dull a chain on less than a tank of gas.
When you take the chain for sharpening, tell the guy you're cutting frozen ash, or what ever you're cutting, and ask him if he can adjust the angles.
hdavis is offline
artinall (12-30-2017)
Old 12-30-2017, 12:36 PM   #23
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,521
Switch to a semi-chisel tooth or a even no chisel tooth chain for dry seasoned hardwoods.
File a slightly less aggressive "rake " angle, cuts a little slower at first, but wears much longer...
More bar oil, it is cheap, turn the oiler up to where it almost runs out with the gas....
Roll the bar every time you sharpen/ change the chain.... file the bar every time square and burr free.....
Use a Peavey to raise the logs out of the dirt.
Fouthgeneration is offline
The Following 2 Users Say Thank You to Fouthgeneration For This Useful Post:
artinall (12-30-2017), fjn (01-14-2018)
Old 12-30-2017, 01:21 PM   #24
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 1,808
Chain saws throw sparks. You are talking metal on metal at fairly high speeds. Occasionally there will be sparks. Not uncommon to start forest fires cutting.
Carefully inspect the bar for damage. Check the trough for gap the entire distance. Manually pull the chain around slowly feeling for any resistance. File any burrs down. Replace the bar if it is heavily worn.
How much oil is left in the tank after the fuel is burned up? Turn the oil up and as suggested switch to a lighter oil in the winter.
What type of a chain are you using? Personally I like the Stihl chains that have the oil holes in them. Either a skip tooth on a large bar, or a semi chisel for 20" and below bars. No stupid safety chains.
Peter_C is offline
The Following 2 Users Say Thank You to Peter_C For This Useful Post:
Fouthgeneration (12-31-2017), jproffer (01-08-2018)
Old 12-30-2017, 01:35 PM   #25
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Builder/GC
Rewards Points: 368
Dry wood will dull a chain far faster than fresh, green wood.
Wood that has been laying on the ground will invariably pick up dirt.
A dull chain, dry wood, hardwood, or rocks and dirt, can all make a chain spark.
The oil should be filled every time you fill the fuel. And as Peter said, safety chains suck.
Delta
I have an Edifice Complex.
fjn (01-14-2018)
Old 12-30-2017, 01:44 PM   #26
hdavis's Avatar
Rewards Points: 791
Seems like an awful lot of barwork to me. I only file the bar if there is a problem.
Rolling or flipping depends a lot on how much I'm using the top of the bar.
hdavis is offline
Old 12-30-2017, 02:08 PM   #27
hdavis's Avatar
Rewards Points: 791
I'm a big proponent of hand filing your own chains. You can adjust angles and depth gages almost real time. On my small saw, I can almost double the hardwood cutting speed by customizing the sharpening. I'm not as aggressive on the big saw, because I can run into saw control issues.
As an aside, you can get a sharpening to last longer if you cut some softwood That's easy to cut before diving into hardwood right after sharpening.
hdavis is offline
fjn (01-14-2018)
Old 12-30-2017, 02:51 PM   #28
artinall's Avatar
We are definitely on the same wavelength - Was planning on hitting up the easier stuff that's already out in the open near the stack, then on to the tougher stuff at the end to prolong the chain.. Once I get my chain back, tues. Lugging the heavier rounds up the slick slope is one physical task (recipient of the free wood will be splitting it, somebody that can definitely use it over the cold months).
[ This is a holiday project many of us can do, with some slack time. There's enough downed-ash or about to be in different parts of the country and disabled and other people with wood stoves and burners can use it for heating inside their homes in the winter mo.'s. While owners need it cleared off. Simply find it and place an ad. They will call. In many parts the price of wood has shot up. Be prepared though some may not have trucks. ]
Shopping a new chain today I noticed the big boxes & local hardware switched out inventory, to generic chains..."Oregon, etc". No more Stihl. Will have to go dealer direct.
artinall is offline
hdavis (12-30-2017)
Old 12-30-2017, 03:26 PM   #29
hdavis's Avatar
Rewards Points: 791
FWIW, Oregon is a decent chain.
hdavis is offline
Old 12-30-2017, 05:21 PM   #30
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,223
Yep, I've used many Oregon chains over the years. No complaints.
While always buying OEM is generally the safest route without doing a boatload of homework, it usually comes with a price penalty.
Tinstaafl is offline
hdavis (12-30-2017)
Old 12-30-2017, 05:34 PM   #31
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,210
that staement is not necessarily true
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 12-31-2017, 07:47 AM   #32
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 13,032
Originally Posted by Tinstaafl View Post
Can't say I've ever gotten a chain hot enough to lose its temper, but I guess it's conceivable. Especially if it's not oiling well.
If you're throwing sparks, it's because of a foreign substance embedded in the wood. Outside of nails or screws, that could be dirt and small stones drawn upward by the trunk as it grows. Not usually a problem more than 2-3' from the ground.
If you did it would have freaking flames coming from the chain oil.
Inner10 is offline
Old 12-31-2017, 09:15 AM   #33
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 1,348
Originally Posted by kirkdc View Post
Wow, I never heard that before. I didn't think Osage was all that hard as I've cut harder woods and never witnessed sparks flying. When Osage burns it'll throw sparks form combustion, terribly, and it burns super hot but I never knew it throws sparks when cutting it.
Dry hedge is far far harder than green hedge. Green hedge cuts similar to oak or other woods. Dry hedge will damn sure dull a chain quickly & very likely throw sparks. I've seen it first hand.
pinwheel is online now
The Following 2 Users Say Thank You to pinwheel For This Useful Post:
artinall (12-31-2017), hdavis (12-31-2017)
Old 12-31-2017, 10:09 AM   #34
artinall's Avatar
Originally Posted by pinwheel View Post
...Dry hedge will damn sure dull a chain quickly & very likely throw sparks. I've seen it first hand.
Which is close to what I previously told my Stihl dealer, who said they've never heard of it with a bit of some implication. Makes me question them.
artinall is offline
hdavis (12-31-2017)
Old 12-31-2017, 10:31 AM   #35
Railman's Avatar
Trade: Railing
Rewards Points: 459
It's one of those "seeing is believing" things. The first time you see it, it's like... "WTF!"
Railman is offline
The Following User Says Thank You to Railman For This Useful Post:
hdavis (12-31-2017)
Old 12-31-2017, 10:39 AM   #36
VinylHanger's Avatar
Rewards Points: 7,826
Anyone who hasn't seen a saw throw sparks hasn't cut much, or only cuts in the bright sun and just hasn't seen it. My Stihl power pruner throws sparks. I usually see sparks in the evening.
This is cutting cedar and Doug Fir.
VinylHanger is online now
The Following 3 Users Say Thank You to VinylHanger For This Useful Post:
fjn (01-14-2018), Fouthgeneration (12-31-2017), hdavis (12-31-2017)
Old 12-31-2017, 11:29 AM   #37
artinall's Avatar
Originally Posted by VinylHanger View Post
...My Stihl power pruner throws sparks. I usually see sparks in the evening.
Taking it out tonight to help celebrate?
artinall is offline
pinwheel (12-31-2017)
Old 01-14-2018, 01:44 PM   #38
fjn's Avatar
Trade: mason
Rewards Points: 9,220
Originally Posted by Railman View Post
http://www.wood-database.com/osage-orange/
It will when it's dried out for a few years, as will locust.
Yup ! So will Hackberry
fjn is offline
hdavis (01-14-2018)
Old 01-14-2018, 01:52 PM   #39
fjn's Avatar
Trade: mason
A loose chain,will tend to lay over,putting excessive wear on the groove in bar. The chain also will not cut properly. If the bar groove is worn,there is a roller tool that can re size it quickly,it squeezes the groove tighter.
fjn is offline
The Following 3 Users Say Thank You to fjn For This Useful Post:
artinall (01-14-2018), hdavis (01-14-2018), pinwheel (01-14-2018)
Old 01-14-2018, 03:39 PM   #40
hdavis's Avatar
Rewards Points: 791
You can also get sparks when the chain lays over.
hdavis is offline
Chain Link Fence Outbid - Pricing on 180 linear feet of chain link fence fencevictoriabc Decks & Fencing 3 11-04-2016 10:38 PM
California Style Chain Link Fence hwfence Decks & Fencing 38 01-29-2015 04:41 PM
Looking to purchase a chain saw chain grinder Grandpa John Contractor Swap 5 09-16-2012 10:04 PM
chain smokers and painting ceilings toolman65 Painting & Finish Work 11 09-15-2012 09:05 PM
Chain Link Fence....top rail....braces? dodge07around Decks & Fencing 6 01-13-2010 12:32 PM
