Saw-Chain Dulling Far Too Soon - Landscaping - Contractor Talk
Old 12-29-2017, 08:55 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 2,256
Out sawing timber, every now and then I've noticed sparks tossing from the chain and from what I've experienced, this is probably due to the kind of wood being hedge. Other than that, have been piecing out downed ash mainly which has been sitting for at least 7 mo's. (unfortunately can't seem to recognize hedge on sight, but I do know how it burns!)
Recently the ground has frozen and with it the wood.
Are my chains losing their edge from frozen wood or the hedge or both?
- If it's the freezing then I might let things warm up a bit.
artinall is online now
Old 12-29-2017, 09:06 PM   #2
kirkdc's Avatar
Trade: Remodeling (mostly kitch/bath)
Rewards Points: 2,796
Re: Saw-Chain Dulling Far Too Soon
Cutting any type of wood (frozen or not) won't throw sparks. If you're cutting logs on the ground mostly likely your chain is hitting rocks, stones, gravel. But even hitting dirt will dull the chit out of your chain in no time. If you have frozen snow stuck onto the wood it may be embedded with gravel as well.
Is your chain going dull quickly? If so you're hitting gravel and dirt.
If your chain is holding a sharp edge it could be sparks coming out the muffler/spark arrestor. dunno.
kirkdc is offline
Old 12-29-2017, 09:16 PM   #3
artinall's Avatar
Originally Posted by kirkdc View Post
Cutting any type if wood (forozen or not) won't throw sparks. If you're cutting logs on the ground mostly likely your chain is hitting rocks, stones, gravel. But even hitting dirt will dull the chit out of your chain in no time. If you have frozen snow stuck onto the wood it may be embedded with gravel as well.
I'm taking precautions not to hit dirt or rocks, etc. There is no gravel where the wood is. Old forest growth.
You've not heard of sparks coming from hedge? It's about the densest wood I've ever cut, anyway.
Sparks are throwing off the bottom of the chain, on exit. There wasn't snow on the wood...
I did come across sparks on wood I knew was hedge (saw the tree before downing it) on another property. Strange, I know. Wonder if it's possible for the densest of wood to cause excessive heat friction/ablate the chain?
Unless the EAB's are that tough when chilled.
Old 12-29-2017, 09:22 PM   #4
kirkdc's Avatar
Isn't hedge Osage wood ? Indians made bows out them. I dunno, I've cut harder exotic woods with my chop saw and never saw sparks.
Is the stuff petrified maybe?
kirkdc is offline
Old 12-29-2017, 09:27 PM   #5
artinall's Avatar
Not that I'm aware.
Old 12-29-2017, 09:44 PM   #6
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 5,397
Chain got to hot and you lost the temper.
Sawdust Follows Me Everywhere
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 12-29-2017, 09:56 PM   #7
artinall's Avatar
So if it is re-sharpened, doesn't matter. Will dull again quick.
Old 12-29-2017, 10:27 PM   #8
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,653
Can't say I've ever gotten a chain hot enough to lose its temper, but I guess it's conceivable. Especially if it's not oiling well.
If you're throwing sparks, it's because of a foreign substance embedded in the wood. Outside of nails or screws, that could be dirt and small stones drawn upward by the trunk as it grows. Not usually a problem more than 2-3' from the ground.
Tinstaafl is online now
kirkdc (12-29-2017)
Old 12-29-2017, 10:41 PM   #9
LRG WoodCrafting
Leo G's Avatar
Yes. Any discoloration of the teeth?
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 12-29-2017, 11:07 PM   #10
Railman's Avatar
Trade: Railing
Rewards Points: 459
Osage Orange will definitely throw sparks.
Railman is offline
Old 12-29-2017, 11:11 PM   #11
kirkdc's Avatar
When a chain gets overheated (which is rare unless the self-oiler isn't working) it will start to visably smoke and most often it will shrink and tighten around the bar and freeze up. And often the bar will show signs of heat scorch before the teeth show blueing.
another think to check...pull off the clutch cover and make sure the chain isn't hitting up against the internal parts where the clutch, weights, drive gear and needle bearings are.
kirkdc is offline
Old 12-29-2017, 11:14 PM   #12
kirkdc's Avatar
Wow, I never heard that before. I didn't think Osage was all that hard as I've cut harder woods and never witnessed sparks flying. When Osage burns it'll throw sparks form combustion, terribly, and it burns super hot but I never knew it throws sparks when cutting it.
kirkdc is offline
Old 12-29-2017, 11:44 PM   #13
Railman's Avatar
Trade: Railing
Rewards Points: 459
http://www.wood-database.com/osage-orange/
It will when it's dried out for a few years, as will locust.
Railman is offline
Old 12-30-2017, 05:59 AM   #14
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 1,798
yup!
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
fjn (01-14-2018)
Old 12-30-2017, 09:06 AM   #15
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,224
oil
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 12-30-2017, 10:18 AM   #16
artinall's Avatar
When a chain gets overheated (which is rare unless the self-oiler isn't working) it will start to visably smoke and most often it will shrink and tighten around the bar and freeze up. And often the bar will show signs of heat scorch before the teeth show blueing...
Teeth look normal. Might be slight amount around bar, have a look. That considered scorch?
Originally Posted by parkers5150 View Post
oil
Been kept loaded with bar oil, careful of that.
Will have to say, that orange cast of osage/hedgewood looks familiar:
http://www.osageorange.com/osage_orange_s.html
Saw-Chain Dulling Far Too Soon-stihl-blade-12.30.17.jpg   Saw-Chain Dulling Far Too Soon-stihl-blade-close-12.30.17.jpg
Old 12-30-2017, 11:02 AM   #17
hdavis's Avatar
Rewards Points: 3,155
Frozen wood will dull chains faster. High mineral content woods will dull a chain faster. Trees that have been laying on the ground for a while build up grit on the surface that will dull a chain faster.
Sharpening angles are different for summer softwood vs frozen hardwood.
Regarding sparks, my first guess is you're running summer weight bar oil in the winter, and you're cutting through grit.
hdavis is online now
Old 12-30-2017, 11:03 AM   #18
hdavis's Avatar
Ash is called ash because It's high mineral content (ash).
Old 12-30-2017, 11:06 AM   #19
hdavis's Avatar
If that photo shows your normal chain tension, you're running it too loose.
fjn (01-14-2018)
Old 12-30-2017, 11:21 AM   #20
hdavis's Avatar
How are you filing the gage teeth (sometimes called raker teeth)?
fjn (01-14-2018)
Chain Link Fence Outbid - Pricing on 180 linear feet of chain link fence fencevictoriabc Decks & Fencing 3 11-04-2016 10:38 PM
California Style Chain Link Fence hwfence Decks & Fencing 38 01-29-2015 05:41 PM
Looking to purchase a chain saw chain grinder Grandpa John Contractor Swap 5 09-16-2012 10:04 PM
chain smokers and painting ceilings toolman65 Painting & Finish Work 11 09-15-2012 09:05 PM
Chain Link Fence....top rail....braces? dodge07around Decks & Fencing 6 01-13-2010 01:32 PM
