?? Retaining Wall Formulas??
Old 06-03-2006, 11:02 AM   #1
happenstance's Avatar
Trade: Framing
I found a formula for calculating on a flat surface.
If you are building up a sloped hill, where the number of rows will decrease...how do you calculate the number of blocks for that?
More specifically, my wall will be 56" high at the bottom. The foundation will be dug down 12" or so, so my total height will only be 4'. The height of the wall will stay level 16' back up the slope. But where there will be 7 rows of 8" high blocks at the bottom, it will gradually decrease to 1 row of 1 block at the top.
And on that note, is there a 8" mortarless SRV that is engineered for that height. The only specs I have found so far were on the Keystone Legacy. They said it is not recommended for over 3' high. So I'm assuming I would need an 8".
happenstance is offline
Old 06-03-2006, 05:54 PM   #2
Tscarborough's Avatar
Re: ?? Retaining Wall Formulas??
Calculate it in terms of face SqFt.
Pavestone makes a wall that will work at that height; several, in fact, that are smaller sized.
Tscarborough is online now
Old 06-05-2006, 10:43 AM   #3
Trade: Framing
Ok thanks. The nearest Pavestone dealer to me happens to be Wal Mart. Suprise, suprise. (Take it EZ my friends, I will shop around)
Regarding the "face sq. ft", How do you get that number on a sloped hill?
Thanks
Old 06-05-2006, 06:13 PM   #4
The top of the wall is level, and one end goes to zero, right? So if you were to take the length times the height of the other, deep end and divide that by 2 it will give the face square feet.
Old 06-05-2006, 07:44 PM   #5
Trade: Framing
Thanks again. Just CMA. On another note, I just met with a couple who had their landscape contractor vanish on them. After he was paid in full of course. Can you please tell me what they intended to do with this...
I attached a photo???
Old 06-05-2006, 08:30 PM   #6
That would be a stub out for a drain behind the wall. If he had finished the job, after final grading, he would have put a drain box in.
Old 06-08-2006, 09:07 PM   #7
whiteslandscape's Avatar
Trade: whitesLandscaping
well if the 4 inch pipe goes to the end of the yard to drain off water then you need optional 6" 12" basin its a box drain connects to the 4" pipe
whiteslandscape is offline
Retaining wall costs? Cherryhill_cons Landscaping 12 11-11-2007 12:29 PM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 11:27 PM
Building Blocks for Retaining Wall robertc65 Landscaping 2 04-25-2007 03:53 PM
Retaining Wall LNG24 Masonry 3 02-17-2007 12:53 PM
Stone Strong Retaining Wall Systems, Anyone ever use?? Little Excavation & Site Work 3 01-25-2007 05:47 PM
