Retaining Wall
Old 04-16-2006, 11:31 AM   #1
Hockeyman
Guest
Hockeyman's Avatar
Posts: n/a
Retaining Wall
I'm Doing A Retaining Wall At My House But I Dont Know How To Figure How Much Block I Need And Also How Many Caps I Will Need Could Some Help Me Out?
Thanks Josh
Old 04-16-2006, 03:09 PM   #2
Custom Builder
Glasshousebltr's Avatar
Re: Retaining Wall
Standard block 8" high X 16" long. Keep your grout joints in check and you can hit the OC marks on your tape.
Ya should have tried the DIY forum for this question.
Bob
Bob
Glasshousebltr is offline
Old 04-16-2006, 07:32 PM   #3
NasConst_land's Avatar
Trade: Landscape
Re: Retaining Wall
Depends on what kind of block you are using, curves, and your wall dimensions. Let us know im sure someone can give u a rough idea of how many block u will need.
NasConst_land is offline
Old 04-17-2006, 01:02 AM   #4
I'm just stirring the:
CGofMP's Avatar
Trade: .
Re: Retaining Wall
Caps = linear feet of wall divided by length of each cap stone (plus a couple for just in case problems)
Wall = length of wall divided by length of each block times (height of wall divided by block height)
If manufacturer wants it toed in (a certain number of courses burried) you'll have to add that as well.
So for instance if you want a 100 foot that is 2 feet high and your blocks are 1 foot long inches long and 6 inches tall youd need 100 blocks per course times 4 courses if it was set directly on the ground.
Plus cap stone.
Read up on the manufacturers sites because anything over a couple feet MAY require engineering or special considerations. ALL require some sort of base be it gravel, cement or other ground prep.
Memorable Places - My little home on the web
Member of the White Knights Of Contractor Talk
CGofMP is offline
Old 04-17-2006, 09:03 AM   #5
LandscapePro's Avatar
Trade: Landscape & Irrigation
Re: Retaining Wall
Josh,
NasC hit the nail on the head. Which manufacturer are you planning on using for block? Pavestone? Keystone?
What you'll need will depend on which block you're going to use.
Which block you'll use will depend on how tall the wall will be.
Give us some details on what you've got in mind and we can go from there.
Mike
La. Landscape Contractor #2576
LandscapePro is offline
Old 05-07-2006, 12:02 PM   #6
lady roofer's Avatar
Trade: Commercial Roofer
Re: Retaining Wall
Thanks Josh
I just saw you post, how did you make out. If this a true retaining wall which means it is holding up ground, call a masonry contractor. Last year me and my husband fixed two retaining walls, he is a stone mason and been at it over 38 years and we have a concrete and brick business on the side and I can tell you what we had to charge and the man hours involved to tear down and redo the walls right was the twice the price it would have been to start with. We actually did these two as favors and hopefully will never do another one.
lady roofer is offline
Old 05-07-2006, 02:27 PM   #7
Custom Builder
Re: Retaining Wall
Hold on a second, your a lady roofer and your hubbies a brick mason, does that mean your always on top?
oh yea...and welcome to the forum.
Bob
Bob
Old 09-21-2006, 12:00 AM   #8
Moderator
Double-A's Avatar
Re: Retaining Wall
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
New York Times, July 20, 2006
Double-A is offline
Retaining wall costs? Cherryhill_cons Landscaping 12 11-11-2007 12:29 PM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 11:27 PM
Retaining Wall LNG24 Masonry 3 02-17-2007 12:53 PM
Stone Strong Retaining Wall Systems, Anyone ever use?? Little Excavation & Site Work 3 01-25-2007 05:47 PM
stone retaining wall sq ft cost? landmark Landscaping 3 03-28-2006 10:38 PM
