Removing Dirt
Old 05-26-2004, 11:53 PM   #1
indy44
Guest
indy44's Avatar
Posts: n/a
Removing Dirt
How do u caculate the amount of dirt to be remove from ahillside if i want to tier it off
Each section will be 70 ft long *3.5 ft high....then it will go back 4ft and start another wall.... Another 4ft an another wall (total 3 walls)
Old 05-27-2004, 08:31 AM   #2
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Re: Removing Dirt
A little math is going to get you close.
The area of a triangle can be found by multiplying the base times the one-half the height.
area = 3.5 feet * (4 feet /2)
area = 7 square feet of area per triangle, and you have 70 linear feet so (7*70) equals 490 square feet or (490/27) = about 18 yards of dirt.
Mike Finley is offline
Old 05-31-2004, 02:44 PM   #3
Rex Mann
Rex Mann's Avatar
Re: Removing Dirt
I'd figure it this way:
70 feet X 3.5 feet X 4 feet = 980 sf
980 x 3 walls = 2940 sf
2940/27 sf (one cubic yard) = 108 cubic yards without swell
I figure you'll be using geogrid to help retain the walls. Therefore, I
figured you have to do use bench cuts for them.
Peace,
Rex Mann
Rex Mann is offline
Old 05-31-2004, 07:11 PM   #4
Chief Toilet Mover
Re: Removing Dirt
I came up with 54 yards total and you came up with 108? Somebody is off.
Getting even more precise don't forget the dirt that will be removed from behind the walls if you install drain tile and gravel also.
Old 05-31-2004, 08:28 PM   #5
Rex Mann
Rex Mann's Avatar
Re: Removing Dirt
Mike,
You figured removing a tringle shpae section of soil. I figured on removing
a rectanular section for the geogrid. That's why I'm twice what you are.
Peace,
Rex Mann
our web site
Rex Mann is offline
Where to get fill dirt robertc65 Excavation & Site Work 24 02-25-2009 10:50 PM
How much dirt can I stockpile in a given area? Help please TurnkeyConst Excavation & Site Work 11 03-12-2007 06:53 AM
News Flash, Dirt Sets A New Record! dougchips Off Topic (Non Trade) 5 02-09-2007 01:18 AM
Plaster on Basement Wall, Dirt! mattleaders Construction 0 10-16-2006 11:22 PM
Removing stain from a french door or replace? Mike F Painting & Finish Work 6 03-22-2004 10:46 PM
