Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Landscaping
Old 05-18-2009, 08:31 PM   #1
Railroad Ties
What is the best way to secure railroad to the ground say for instance along side a stone path? Would burying them 2-3 inches be ok??? On very stable ground? thanbks Chris
ckobesko is offline   Reply With Quote
Old 05-18-2009, 09:05 PM   #2
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
You can drill a hole and drive rebar through about 2 feet or so. I welded a washer on the top and drove them flush for my driveway in the back. They will still move if you run over with a pick up or something, but the kids hit them with the mower and it just beats up the mower.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline   Reply With Quote
The Following 2 Users Say Thank You to dakzaag For This Useful Post:
ckobesko (05-18-2009), mrmike (05-19-2009)
Old 05-18-2009, 09:07 PM   #3
So no need to place them on a concrete base, and I assume rot is minimal.
No one will be walking on these so I assume even with rebar it will be fine.
Old 05-18-2009, 09:22 PM   #4
dakzaag's Avatar
Trade: mason
I tried just digging them in, but I was too hard on them, backing trailers up and stuff I would end up on top of the tie with the front wheel and it always moved I finally broke down and "nailed" them down.
If it is just foot traffic you will probably be ok, just remember the lawn mower can move them also.
I hope you have worked with tie's before. Good ones are over 200 #'s a piece. The cheap crap from big box stores are all dried out and split to no end.
You can usually find some number 2's in a reclaim yard. (1's are new I think) still only cost about 8 bucks a piece maybe more now it has been a few years since I bought some. We have a big yard up in Gary IN that sells them by the bundle.
D K & Sons
The Following User Says Thank You to dakzaag For This Useful Post:
ckobesko (05-19-2009)
cut collar ties - walls bowing pullenpoynt Construction 57 03-07-2009 01:20 PM
ground ties Wallace 49 Electrical 2 11-02-2008 08:22 PM
Masonry ties for stepped footings AZ GRC Masonry 1 08-04-2008 12:31 AM
wall ties on dry stack ledge stone vaneer mikeMSmerit Masonry 1 07-15-2008 02:50 PM
Handle ties on New Afci's Bubbles Electrical 3 01-15-2008 10:11 PM
