Professional Opinions..
Old 05-14-2009, 04:21 PM   #1
Youngster
Cache's Avatar
Trade: Builder / Consultant / Designer
Gonna partner with BIL on landscape business. I'll run administrative side of business and provide capital (up to $50K). He'll handle crew and operations. Will do everything; design, retaining walls, water features, new construction, sprinklers, hardscape, mowing, etc....
He graduated in landscape architecture/horticulture and has worked for a landscape company for 3 years. His experience with various equipment seems limited in that he doesn't have a strong opinion on which brand/type will be the better purchase. I'm looking for your opinions on which equipment is preferred and why. I have the following questions. I understand that you don't know the complete situation, so a cost/benefit analysis is impossible. Just looking for opinions if you were wanting to hit the ground running.
  • Size/type/make/model of mower?
    • Will be handling a lot of residential, so access to smaller areas might be a frequent issue. Also, decent bag capacity is a must. Green waste must be properly disposed of here.
  • Skidsteer or Utility Tractor?
    • Tractors and attachments are cheaper, but does skidsteer versatility justify the extra cost?
  • If skidsteer... tracks, tires or bar tracks?
  • Which attachments for landscaping?
    • Box grader
    • Auger
    • Backhoe vs trencher?
  • Which attachments for snow removal?
    • Snow blower vs. rotary broom vs. blade?
  • Mini-excavator --- buy or rent?
    • rental is $250/day
  • Trimmer size/make/model?
Thanks a lot guys. I really appreciate it.
Cache is offline
Old 05-14-2009, 04:32 PM   #2
Professional Instigator
rbsremodeling's Avatar
Re: Professional Opinions..
I tried to read it twice but failed. I will come back after I have a drink or two.
rbsremodeling is offline
Old 05-14-2009, 04:38 PM   #3
solar guy
naptown CR's Avatar
Trade: solar contracting
Guy posts like I have learned not to
naptown CR is offline
Old 05-14-2009, 04:48 PM   #4
Youngster
Cache's Avatar
Sorry, shortened it up.
Cache is offline
Old 05-14-2009, 06:58 PM   #5
swade's Avatar
Trade: General Contracting, Remodeling
Originally Posted by Cache View Post
  • Size/type/make/model of mower? Xmark-36 for backyards, 48 for fronts. Depending on size of property, jungle wheels for the walk behinds or maybe a smaller zero turn rider
  • Skidsteer or Utility Tractor? For Installs? Skid steer IMO, but again what do you need it to do for you.
  • If skidsteer... tracks, tires or bar tracks? Are you going to be doing mostly new residential or existing homes? Tracked for existing, wheeled for new. Can also use wheeled for snow removal.
  • Which attachments for landscaping? For a bobcat?
    • Box grader... or rock hound
    • Auger....A necessity
    • Backhoe vs trencher? Depends on the type of work you will do..irrigation/drainage, obviously a trencher. Excavating for patios in tight areas, the backhoe.
  • Which attachments for snow removal? Blade or box plow IMO
  • Mini-excavator --- buy or rent? Rent until you can keep it busy 70% of the time.
  • Trimmer size/make/model? Echo.Hand held for landscape crew, backpacks for mow crews. If leaf removal is an issue, a little wonder blower is a time saver
The brands are up to you, just listed mowers that I have used, and have seen take a hell of a lot of abuse. As far as a bobcat goes, its up to your budget and what you need it to do as far as lifting/height...trax vs wheeled. IMO wheeled bobcats give you more options such as for snow removal etc, but if your doing a ton of existing homes a trax model might be better.
Highly recomend enclosed trailers for your mow crews, will save a ton of "unaplied" time in the mornings unloading and loading equipment.
swade is offline
Old 05-14-2009, 07:34 PM   #6
Workin' Hard & Havin' Fun
BreyerConstruct's Avatar
Trade: Deck Designer/Builder
Mower depends on what's available, and on the comfort of the operator. Here's another vote for an Xmark... but I'd go bigger for the front yards.
Oh, yea- you'll need accounts. Consider buying another company's assets and mowing list, or partnering. Start small, don't but a lot of equipment, only to have it sit and rust. Rent until the payments make you buy.
HTH,
~Matt
BreyerConstruct is offline
Old 05-14-2009, 08:28 PM   #7
Nepster
antnepi's Avatar
Trade: general contracting
Hustler Super Z
antnepi is offline
How do you define professionalism? Mike(VA) Business 13 02-09-2010 04:06 PM
Opinions on retaining wall and stucco JDutton Masonry 15 01-03-2009 10:55 PM
Website opinions please Brandon1 Technology 7 12-18-2008 10:13 AM
I need professional plumber opinions tgrib Plumbing 4 08-13-2008 09:19 PM
