Preventing Weeds In Brick Pavers
Old 06-16-2010, 08:54 PM   #1
MEL's Avatar
Trade: Roofing
Rewards Points: 516
I have a customer that wants to know if we are going to do something to prevent weeds from growing in between the bricks in a brick paver sidewalk.
This is for a new paver sidewalk, it's my first paver job.
Do you know of anything that will work?
MEL
MEL is offline
Old 06-17-2010, 04:20 AM   #2
paper hanger,painter
chris n's Avatar
Trade: wallpaper hanger,painter
Rewards Points: 4
Re: Preventing Weeds In Brick Pavers
I assume you must be kidding?
chris n is offline
Old 06-17-2010, 05:55 AM   #3
Dan
ApgarNJ's Avatar
Rewards Points: 2,000
weed killer?
ApgarNJ is offline
The Following User Says Thank You to ApgarNJ For This Useful Post:
pinwheel (06-17-2010)
Old 06-17-2010, 06:52 AM   #4
christoff's Avatar
Trade: home renovations
Rewards Points: 184
you could try using polymeric sand, i think it has an additive to harden it to make it more difficult for the weeds to grow
christoff is offline
The Following User Says Thank You to christoff For This Useful Post:
Big Shoe (09-12-2010)
Old 06-17-2010, 09:26 AM   #5
boman47k's Avatar
Rewards Points: 2,006
I'm going to try a white vinegar and water solution on my crushed limestone drive.
boman47k is offline
Old 06-17-2010, 09:38 AM   #6
The polymeric sand helps.
Give them a gallon of Round-Up
as a lovely parting gift.
neolitic is offline
The Following User Says Thank You to neolitic For This Useful Post:
Kent Whitten (06-17-2010)
Old 06-17-2010, 11:06 AM   #7
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 1,194
Around here (ag country) you can buy generic, concentrate roundup for $16/gallon. That gallon will last them 5 years, spraying 3-4 times/summer. Can't think of anything any cheaper/easier than that.
pinwheel is offline
Old 06-17-2010, 12:30 PM   #8
Anti-wingnut's Avatar
Rewards Points: 3,306
I have seen several garden chemicals etch concrete. I can't remember if Roundup was one of these.
Anti-wingnut is offline
Old 06-17-2010, 02:04 PM   #9
Fire up the BBQ
griz's Avatar
Rewards Points: 1,214
Don't waste your time or money.
Didn't work worth a darn on Calif. weeds.
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
boman47k (06-17-2010), BPWY (07-21-2011)
Old 06-17-2010, 02:26 PM   #10
pinwheel's Avatar
Roundup is an acid, so that could be a possibility.
pinwheel is offline
Old 06-18-2010, 06:29 AM   #11
Crawdad's Avatar
Trade: Lawn Care
Rewards Points: 250
Most states require certification to apply pesticides for a customer. Yes, even for "stuff anyone can buy at Lowe's." Hire someone who is, or leave it alone.
Your profile lists you as a roofer, so I reckon you were unaware of this. That's OK, many landscapers are unaware of it too, and many more ignore it, and apply illegally.
Crawdad is offline
Old 06-18-2010, 07:04 AM   #12
pinwheel's Avatar
pesticides kill bugs, herbicides kill plants. But you sounded like you knew what you were talking about.
pinwheel is offline
The Following User Says Thank You to pinwheel For This Useful Post:
Anti-wingnut (06-18-2010)
Old 06-18-2010, 12:04 PM   #13
playsinmud's Avatar
Trade: hvac
Rewards Points: 25
Most guys around here put down a geotextile fabric first before pavers and base. It does a really good job fighting against weeds.
playsinmud is offline
The Following User Says Thank You to playsinmud For This Useful Post:
moorewarner (05-19-2013)
Old 06-18-2010, 12:12 PM   #14
No one said anything about applying.
The weeds won't show up until
the OP is gone.
Please explain why you would
use pesticide on weeds anyway?
neolitic is offline
The Following 2 Users Say Thank You to neolitic For This Useful Post:
Kent Whitten (06-19-2010), SmallTownGuy (05-22-2013)
Old 06-18-2010, 08:01 PM   #15
Landscaper
DBRhino's Avatar
Trade: Landscaping
along with polmeric sand....together they work like a charm!
DBRhino is offline
Old 06-18-2010, 09:50 PM   #16
Champion Thread Derailer
Jeff G's Avatar
Trade: Home Renovations
Rewards Points: 380
For sure, the combination of polymeric sand and geotextile fabric under the base work well.
Just for future reference when there are grass/weeds that you want to get rid of inexpensively, a mix of boiling water and a good amount of salt works quite well, and very effective for a quite a while. Non-toxic too. I put it on my drive in the springtime and generally don't have to reapply the rest of the year. Doesn't take a whole lot, but just pour enough of it on to "cook" the roots of the plant.
Jeff G is offline
Old 06-18-2010, 10:10 PM   #17
erikm's Avatar
Trade: HVAC
Rewards Points: 75
I was wondering...maybe the weed seeds are landing on top of the pavers and grow from there?
erikm is offline
Old 06-18-2010, 10:15 PM   #18
Jeff G's Avatar
Rewards Points: 380
They sure will if there is suitable material for them to grow in. Some places weeds just thrive more than others, like my garden for instance!
Jeff G is offline
Old 06-19-2010, 04:42 AM   #19
chris n's Avatar
Rewards Points: 4
I must have the other half of them that blew up the coast
chris n is offline
Old 06-19-2010, 11:59 AM   #20
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,904
Air-borne weed seeds are probably the most common problem for an established patio.
The joints are usually lower and seeds collect are washed into them. The surface shedding of water from the concrete pavers also collects in the joints and provides a source of moisture. Weeds can grow anywhere even if there is a "weed barrier" below.
Tress can grow in rock formations and create new cracks/joints, so why do people think that some short lived additive to the joint sand would really have much effect.
Boadleaf weeds are a minor short term problem than can easily be solved by the same "Weed-Be-Gone, etc. that is commonly used on lawns. For grasses, a light application of Round-Up" after germination and sprouting will be absorbed and kill to the roots. I used a squirt bottle once a year or so is usually adequate for patios, walkways and driveways.
For real paving surfaces (10 to 50 acres) polymeric sand is never used because of the cost, life and ineffectiveness over time.
Dick
concretemasonry is online now
The Following User Says Thank You to concretemasonry For This Useful Post:
erikm (06-19-2010)
The Guy who needs fifty brick Tscarborough Masonry 22 06-08-2010 09:19 PM
something for the masonry department dakzaag Masonry 2 05-08-2009 09:23 PM
Adding a Brick Ledge to a Michigan Home bajafx4 Masonry 3 01-23-2009 06:19 PM
ICF brick ledge coupe33 General Discussion 7 11-29-2008 12:45 AM
cement wash or concrete rub a thin layer over brick pavers brownstone89 Masonry 14 08-25-2008 06:14 PM
