Planting Grass For New Construction
Old 10-25-2010, 09:17 AM   #1
trimdoctor's Avatar
Trade: framing
I am finishing up my new home and plan to be in by Thanksgiving. I need help with coming up with a plan for planting new grass after back-filling is complete this week. I have about an acre to plant. I'm in Indiana and I don't know if it is too late in the year for planting seed. I have been told this is the best time to plant, but we haven't had much rain in the last couple months and I'm afraid it would never get started before winter. Also, how much grass seed do I need for 1 acre of grass?
planting grass for new construction-bighole-003.jpg   planting grass for new construction-bighole-001.jpg   planting grass for new construction-bighole-002.jpg
trimdoctor is offline
Old 10-25-2010, 10:11 AM   #2
JohnFRWhipple's Avatar
Trade: Linear shower drain installations & waterproofing
Rewards Points: 2,000
Re: Planting Grass For New Construction
I layed down sod instead of seed. This time of year I might wait until spring anyway.
On a side note is your new roof properly vented? Hard to tell from the pictures but I would double check that...
JW
JohnFRWhipple is offline
Old 10-25-2010, 10:25 AM   #3
trimdoctor's Avatar
Trade: framing
thanks for concern, but there is ridge vent spanning entire roof line. Hard to tell from pics.
Old 10-25-2010, 11:53 AM   #4
A. Spruce's Avatar
Trade: General Contractor - ret.
I would define what is going to be the yard and install sod. Sod is instant green and can be used gently immediately and completely traffic tolerant within a month, whereas seed can take 6 months or more before it starts to fill in and be usable. You're going to want to plan and install your irrigation system before doing anything.
A. Spruce is offline
Old 10-25-2010, 12:08 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 658
Have you guys priced an acre of sod?
Tinstaafl is online now
Old 10-25-2010, 12:17 PM   #6
Working
Cole82's Avatar
Rewards Points: 2,276
Send a message via AIM to Cole82
Just bought 4 pallets of sod for $250 that was 1600sqf you do the math.
Cole
The boss of awesome
Cole82 is offline
Old 10-25-2010, 12:57 PM   #7
A. Spruce's Avatar
Which is why I stated to "define the yard", meaning the area immediately around the house that will be yard as opposed to everything else that can remain scrub grass/pasture/multipurpose space that does not need to manicured lawn space. If the whole space is to be manicured, then seed would be the affordable option.
Old 10-25-2010, 01:20 PM   #8
trimdoctor's Avatar
Trade: framing
I will definitely be planting seed. I will be mowing around 4 1/2 acres, and there is no way I can afford an acre of sod. My question is...is it too late to plant seed this year in Central Indiana? If it doesn't germinate will it still come up in spring? We have to plant seed on Presby septic system because of building code. I don't want to buy $400-$500 worth of seed and then have to replant in spring.
Old 10-26-2010, 10:35 AM   #9
MSLiechty's Avatar
Trade: Bender Of Nails
Rewards Points: 428
sod in quanitity is about $.30/ SF. sure its more expensive than a bag of seed but it instant too.
ML
MSLiechty is offline
Old 10-26-2010, 05:43 PM   #10
natural1's Avatar
Trade: Landscape contractor
Rewards Points: 322
I would go ahead and seed now. Apply about 10lbs per 1000 sq. ft. It is probably a bit too late in your area but some will come up. Here in NC the cut off is about thanksgiving for good results. Put down straw which will help keep the soil warm, reduce erosion and retain moisture.
Ideally you need to water daily but with an acre that will be hard to do. You will probably need to re-seed again in the spring.
If it was me I would concentrate my effort and resources to just around the house for now and then seed the rest in the spring. In the south we seed in the fall. I assume in your climate most seed in the spring.
Mike
http://www.natural-designs.com
natural1 is offline
Old 10-26-2010, 06:04 PM   #11
hurtlocker
nailkiller1's Avatar
Trade: homebuilder remodeler carpenter
Call the pros in your area
Or seed dealers
They will know whats best for your environment
nailkiller1 is offline
Old 10-26-2010, 06:14 PM   #12
Project Superintendent
mudpad's Avatar
I have asked some of the sod growers here in Middle Tennessee what is the secret to getting a good stand of grass. They always say- sow it in late sept/ oct. , definitely not in the spring.
It may be getting a little late in the season, but if you can get it to germinate, it will go dormant and come back in the spring.
If you sow in the spring, it will germinate, and then die the first time it gets hot and dry, because it won't have the root system established.
Steve
mudpad is offline
The Following User Says Thank You to mudpad For This Useful Post:
mikeswoods (11-21-2010)
Old 10-26-2010, 06:52 PM   #13
Jaf's Avatar
Trade: Builder
Rewards Points: 250
I'm in the Northeast.
If I were you I'd seed with annual rye grass. I believe "contractor mix" is pretty much annual rye grass. It's cheap and greens up quick and will get the conservation lady out of the picture.
Problem is it won't hang in there through the winter. In the spring plant whatever grass is recommended for your area. That's when you want to lay out for the "real" seed. Here it would mostly consist of "Kentucky Blue Grass" with a bit of frescu mixed in. Even in the good mixes they mix in some rye grass, just so the customer sees something growing within a week. That stuff dies off and the "real" grass grows in later.
Rye grass looks like wire. "Real" grass has wider, flatter blades. "Real" grass survives the winter, and if maintained will lead to a beautiful lawn. Rye grass, "contractor mix" will die out slowly, it will drive you nuts if you really want a good lawn.
Anyway, that's how its done here. Builder puts down rye. Whoever buys the house overseeds with Kentucky.
Jaf is offline
Old 11-01-2010, 02:12 AM   #14
bryans's Avatar
Trade: Landscape
Rewards Points: 22
I would go ahead and plant the grass seed that you desire. First check with a local expert and see if hulled or unhulled grass seed would be better in your area. In addition to that grass seed I would also plant a premium perennial rye grass seed. I agree with planting 10lbs/ 1000sf of both types of seed.
bryans is offline
Old 11-01-2010, 02:27 AM   #15
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Have you checked in to Hydro seeding?
If not available/practical sow seed. I'd check with a local pro landscape supply house, where you'll be buying the seed anyways for how much. No matter what, plan on buying more seed in the spring.
griz is offline
Old 11-03-2010, 12:27 AM   #16
Crash Test Dummy
ChainsawCharlie's Avatar
Trade: Landscaping
Rewards Points: 1,000
You should check into hydromulch and stolons while your at it. A fraction of the cost of sod, and you get a big head start over seed.
ChainsawCharlie is offline
Old 11-21-2010, 02:09 AM   #17
dksturf's Avatar
Trade: Artificial Grass / Landscaping Design
I am curious is there a need or how is the artificial turf industry in Indiana?
dksturf is offline
Old 11-21-2010, 08:55 AM   #18
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 1,062
If you can get the seed to germinate yet, it will take off in the spring. Here in MO, we could easily have enough warm days left before hard winter to germinate grass seed. Personally, I'd give it a go & try to get it started. You'll have a better stand next spring if you can get it started now, verses starting it in the spring. The grass will be ahead of the competing weed seed & will help keep the weeds from germinating. Fertilizer, straw & plenty of water are the keys to getting a good stand in the fall. Don't skimp on the water. Keep it wet till it drops well below freezing. Fescue & the likes are cool season grasses. They grow strongest in the cooler months of the year.
pinwheel is online now
Top 10 Construction Lien Errors Ed the Roofer Business 7 08-19-2011 11:51 AM
Is this the future of construction in America? HusqyPro General Discussion 10 09-12-2009 08:21 PM
Reed Construction Data Launches SmartLead Grumpy General Discussion 0 12-18-2008 09:40 AM
CCD - and construction image Mike Finley General Discussion 6 08-31-2007 09:37 AM
