Pavers $12 Or $23 Per Sq. Ft. ????????
Old 01-31-2008, 08:59 AM   #1
DRIFTWOOD
Driftwood's Avatar
Trade: GEN CONTR.
My Est .book [ Bay Area ] says $29. Just lost the job to another for $12 S. Ft.
I don't know how They do it? That's OK I've got them for $23 before, I'm not
going to lower My prices. What is Your take please? Thanks in advance
Driftwood is offline
Old 02-02-2008, 12:25 PM   #2
Brickie's Avatar
Trade: One on top of Two
Rewards Points: 570
Re: Pavers $12 Or $23 Per Sq. Ft. ????????
You need to give a lot more info on what your asking. There are so many variables like: What kind of pavers? what size? what brand?, etc.,
Indiana is a Right To Work State. Proud To Be Non-Union
Brickie is offline
Old 02-02-2008, 01:07 PM   #3
AintNoFun's Avatar
Trade: Landscape Contractor
Rewards Points: 75
wow good for you, i know guys fight themselves over here to do pavers for like 8 to 10 a s.q ft.
AintNoFun is offline
Old 02-02-2008, 04:14 PM   #4
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,890
If you do pavers by the sf, without regard to shape (square, curved, etc.) or the total size or what is required for base and compaction, a estimating is only a guide to a "ballpark" estimate.
What happens is that if you are too low, you get a loser of a job and if you are high, you miss a job that could be profitable to the smarter guys that know their costs. - Or you could blame the "illegals".
If you think your "prices" are the only number - good luck!
Look at each job in terms of what you have to do, your labor, material and equipment rental and what you need for profit after adding in your time at your rate.
That will give you some good experience into pricing paver jobs.
Dick
concretemasonry is online now
The Following User Says Thank You to concretemasonry For This Useful Post:
JDavis21835 (05-03-2014)
Old 02-26-2008, 08:40 PM   #5
stephen9528's Avatar
Trade: stone tile,granite countertop,column,carving and fireplace manufacturer
Send a message via ICQ to stephen9528 Send a message via MSN to stephen9528
different paver is different price.It is expensive in USA maybe. In China,the paver is so cheap.
stephen9528 is offline
Old 03-21-2008, 10:14 PM   #6
still learnin'
dutchlegacy's Avatar
Trade: General Contracting
Rewards Points: 150
are you talking installed price? seems about right to me, depending on the complexity of the pattern, depth of the substrate, and whether or not you are using a paver that "self-finishes" an edge or requires a lot cutting. having a flowing curve edge line adds another major time cost. I landscaped for a few years, and putting in pavers the right way takes a lot of time...and a lot of hours on the wet saw.
dutchlegacy is offline
Old 03-22-2008, 09:13 PM   #7
Brickie's Avatar
Rewards Points: 570
I agree
Brickie is offline
Old 03-22-2008, 09:16 PM   #8
genecarp's Avatar
Rewards Points: 2,000
12 to 15 persq ft new york
genecarp is offline
Old 04-04-2008, 10:27 PM   #9
manu's Avatar
Trade: landscape
10-15 sft in Seattle, but it also depends from how big is a patio or driveway, if you say 15sqft for 150 sft patio you gonna lose money os price go higher if you have around 1000 sft price go lower. And as it was sad before pattern, base, cutting
P.S. but to bit illigals here very hard :O(
manu is offline
Old 04-10-2008, 09:36 AM   #10
Alex C's Avatar
12-15 sq ft with mat, without excavation and concrete screenings?
Alex C is offline
Old 01-21-2009, 01:21 PM   #11
wurkn w amish's Avatar
Trade: landscaper
like some others said.....
take your material and labor, equipment, overhead, etc. and figure what it'll be.
divide sqft into that if they want a sqft price.
But.....
make sure they are comparing apples to apples.
same paver
same amount of base material
same edge restraint
same sand setting bed
same sand for joints
same shape of patio.
I can buy pavers for $1.00ft2 or $8.00ft2
I put in more base because of overdigs were taken into acount
I use a better quality edge restraint
I use polysand(bag) in the joints instead of mason sand(ton)
I have alot of cutting, might have to scrap alot.
wurkn w amish is offline
Old 01-21-2009, 02:11 PM   #12
Fentoozler
Celtic's Avatar
Celtic is offline
Old 01-21-2009, 03:55 PM   #13
General Contractor
MCerminaro's Avatar
Trade: General Contractor/ Concrete Contractor
Rewards Points: 25
I use stamped concrete!
Top Notch Home Services
Commercial and Residential Contractor
MCerminaro is offline
Old 01-22-2009, 08:39 PM   #14
qwertyMark's Avatar
Trade: Brick Paving
The first thing you need to do is forget about the price per square foot. You are better off never even thinking about it. To properly estimate a paver project, there are two things to consider: Materials and Man Hours.
Assuming that you already own the necessary equipment and that you have already established an hourly rate that recovers overhead, it is important that you accurately estimate the amount of man hours a project should take and then multiply those man hours by your hourly rate. Seems simple, but contractors screw it up all the time.
You should break down a job into functions:
-Excavating
-Base Install
-Screeding Sand
-Laying Pavers
-Cutting
-Installing Edging
Once you've determined all the functions that your project includes, you should associate a quantity to each. How many sq ft of pavers, how many tons of base, how many linear ft of cutting, etc. Now, if you have previously tracked the rate in which you can do each of these functions, you will be able to determine how many total man hours each will take.
So if you have 200 sq ft and historically you can install 20 sq ft per man hour, then you will spend 10 man hours installing pavers. If you have 100 LF of cuts and historically you can cut 15 LF per man hour, then you will spend 6.75 man hours cutting pavers. Once you have covered every function of the project you will have an educated estimate of just how long the project will take and how much you should charge for labor.
Remember, your first time will be nothing more than an educated guess if you haven't tracked your progress rates on prior projects, but if you start tracking these rates from now on out, you will eventually get a pretty good handle.
Hope this helps...
qwertyMark is offline
Old 04-26-2014, 12:06 PM   #15
eastbaygarden's Avatar
Trade: Landscaping
Rewards Points: 2
In the San Francisco Bay Area we see bids between $18 per sq/ft low end cheaper paver that is sand set to $30 sq/ft for nicer pavers. Those doing for less are often not taking proper grade, drainage, compaction and borders into consideration, or they are not licensed.
eastbaygarden is offline
Old 04-26-2014, 08:39 PM   #16
Brickie's Avatar
Rewards Points: 570
Yes, $30 sounds about right
Brickie is offline
Old 07-23-2014, 05:36 PM   #17
madmax718's Avatar
Trade: General
Rewards Points: 3,206
there is no such thing as a licensed landscaper in NY. Just a landscape architect. but it is not required to do most of these things from what I can recall.
madmax718 is offline
Help please on sealing new pavers RTred Masonry 13 02-17-2013 03:04 PM
What kind of sand for pavers EDENSCAPES@DNET Landscaping 37 10-08-2010 01:00 PM
Pavers Over Concrete - My Cousin's Method Tommy C Masonry 67 10-29-2009 09:31 PM
Sub Base for pavers mcgyverdc Landscaping 20 01-14-2007 01:48 PM
Ants overtaking my pavers maj Landscaping 10 06-30-2006 11:08 AM
