Paver Sealing
Old 10-24-2017, 10:04 PM   #1
Mike50's Avatar
Paver Sealing
Just laid a 400 sq/ft paver patio. I'm wanting to seal the pavers but have seen where some companies recommend waiting up to a year for effloresense to release. I'm looking to use super seal 25 which is said to let the pavers breathe. With this sealer letting it breathe would it be OK to go ahead and seal them? If not should I just go ahead and put in polymeric sand for the winter? Thanks in advance
Mike50 is offline
Old 11-07-2017, 05:17 PM   #2
legendlandscape's Avatar
Trade: Landscapier
Rewards Points: 18
Re: Paver Sealing
Kindof a big risk, I'd just do the sand for the time being.
legendlandscape is offline
Old 02-28-2018, 02:58 AM   #3
ulags's Avatar
Trade: PEBBALIO CONCRETE PRODUCTS
Rewards Points: 4
Re: Paver Sealing
paver sealing is best if done by fine sand of 3mm and below sizes and not have below 100 microns so that water can flow in to make the earth breath
ulags is offline
Old 03-25-2018, 01:16 PM   #4
Genius HardScaper
GC_contractor's Avatar
Trade: Masonry and hardscaping
Rewards Points: 58
Re: Paver Sealing
I prefer fines in my sand since I want to minimize water penetration. A such I don't use bedding sand, I prefer bedding or mason's sand. On steep driveways I will use the larger aggregate (bedding sand).
I know I'm late but you've asked a good question so this is a knowledge base thing useful for anyone asking this question again.
Pavers have already been breathing since being manufactured. Check the date of manufacturing. If this info isn't available, 6 months of time (over winter) is enough time for the pavers to release almost all of the efflorescent salts. I've never waited a full year and I've never had a problem.
Sealants for concrete and concrete products have to be breathable since concrete absorbs and exhales moisture. If the sealant isn't breathable, it isn't for concrete and/or concrete products.
Polymeric should be applied at temps over 70F. Sealing should be done at over 50F.
Sealant should be applied before the polymeric, since the following application of poly will hide the unsealed sides and protect the sensitive edge of the sealant.
GC_contractor is offline
Sealing all sides of hardwood decking DeckPros Decks & Fencing 56 02-16-2013 12:27 PM
Sealing Metal Valley Section artinall Roofing 20 11-07-2012 11:18 AM
Paver sand joint fill red_cedar Masonry 14 05-21-2012 08:17 PM
Interior paver sealing AmeliaP Flooring 1 12-23-2010 08:58 PM
Sealing paver decks JPF Flooring 2 02-16-2007 06:33 PM
