Patio Over Irrigation System
Old 08-30-2016, 02:26 PM   #1
Permaculture Landscaper
jeremyjwatts's Avatar
Trade: Landscaping
Rewards Points: 24
My client wants a DG patio installed on a sloped area with 3/4" pvc irrigation running 6" down. The area is about 18'x24' (black clothed area). My problem is that I'm not sure how to approach the excavation.
First, the client wants me to use a roto-tiller to break up the very compacted ground (to save time over hand-digging). I'm thinking I can go heavy on the bulk of the area and maybe just do a single, quick pass over the spots with irrigation beneath?
Second, I'm thinking that because of the buried pipes I should only excavate to about 4" and and apply a 2" layer of base rock and 2" of DG. I think most people use a thicker layer of base rock.
Finally, is it ridiculous to put this type of patio over an irrigation system to begin with? Might the tamping-down damage the pipes? Or the shallow base rock layer not be enough to mitigate sinking? And does it even make sense to have the patio on a gentle slope. The water would flow away from the house and into the creek bed and off the property, but you wouldn't be sitting flat on the patio furniture.
Thanks.
jeremyjwatts is offline
Old 08-30-2016, 02:54 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 18
Re: Patio Over Irrigation System
Didn't quite read your entire post in depth...
what can help you answer questions like this is:
Would you do it this way for your Mom?
or...
Would you do it this way for yourself?
griz is offline
Old 08-30-2016, 02:58 PM   #3
Trade: Landscaping
Rewards Points: 24
or...
I want to do the best job I can. Just asking for advice.
Old 08-30-2016, 03:18 PM   #4
Dan_Watson's Avatar
Rewards Points: 2,460
Can you elevate it? Add fill or frame it a step or two up.
Dan_Watson is offline
Old 08-30-2016, 04:00 PM   #5
Trade: Landscaping
Rewards Points: 24
I want it to be level with the existing patio for a smooth transition. I could just not excavate and not add base rock, just a two inch layer of DG to bring it up to flush with the patio. I don't know if this is a good idea...anyone?
Old 08-30-2016, 05:28 PM   #6
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 3,168
or...
Griz i love " would you do it this way for your mom ", I have used that to customers",
sunkist is offline
Old 12-30-2016, 09:28 PM   #7
Learn-Build-Enjoy
ASidhu's Avatar
Trade: Carpentry and Landscaping
Rewards Points: 128
or...
I would want the best for my mom and myself so it's pretty much the same question for many
ASidhu is offline
Old 01-17-2017, 11:11 PM   #8
MarisaF's Avatar
Trade: Railings
Rewards Points: 16
I think the deck should be elevated by a small margin rather than kept it leveled
MarisaF is offline
Old 02-02-2017, 05:59 PM   #9
chetgoody's Avatar
Trade: tree service
Rewards Points: 48
Disperse the energy of the tamp down by covering the pipe run with quarter inch plywood about 4 inches in width placed directly under your base layer.
Chet
A Total Tree Service
chetgoody is offline
Old 02-26-2017, 08:23 AM   #10
Chatham PM's Avatar
Trade: Pressure Washing, General Maintenance
Rewards Points: 8
I do not see the irrigation line causing a problem, but if it concerns you have the lines moved to another area.
Chatham PM is offline
dewalt tough system storage solution Rich D. Tools & Equipment 39 08-01-2012 02:11 PM
EP Henry patio bricks over concrete patio with thinset Pheasant89 Masonry 5 07-26-2012 05:48 PM
clemco easy load system and closed circuit blasting system goosesgarage Sandblasting 9 11-23-2010 12:41 AM
Inspector wants fire sprinkler system TLE/RL1911 General Discussion 90 06-04-2010 05:35 PM
Systems Development List Gordo Business 19 01-08-2007 07:28 PM
