Patio Dilemma
Old 03-06-2018, 09:29 PM   #1
jtomm's Avatar
Trade: Handyman
Rewards Points: 16
Patio Dilemma
I have a problem that i need some brainpower for. I have a paltform that im putting a patio with pavers on. There are two foundations. One is the house the other the garage but they are not parallel. Then we built a retaining wall which is stationary and have another small retaining wall that can be moved and modified. So the problem is we cant find a way for the pavers to line up with all four sides. Right now it runs towards the house and is very crooked. PLEASE HELP!
jtomm is offline
Old 03-06-2018, 09:32 PM   #2
Hack
asevereid's Avatar
Rewards Points: 598
Re: Patio Dilemma
Pics? Can't really give any help if we can't see the problem.
Sent from my SM-G530W using Tapatalk
How to figure your pricing:
http://goo.gl/Il8c2
L+M+O+P/ Pricing, Estimating, And Success
Charging tree fiddy per lineal BOB
asevereid is online now
Old 03-06-2018, 10:29 PM   #3
jtomm's Avatar
Trade: Handyman
Rewards Points: 16
Re: Patio Dilemma
Unfortunately I donít have any pics right now of the patio. I drew up this for a rough idea. Maybe itíll give you a start.
jtomm is offline
Old 03-06-2018, 11:32 PM   #4
Hack
asevereid's Avatar
Rewards Points: 598
Re: Patio Dilemma
Well, you can cheat the gaps a little bit, but if the walls are really out of parallel with each other, you'll most likely have to cut your last course before the border to fit.
http://goo.gl/Il8c2
Old 03-06-2018, 11:37 PM   #5
jtomm's Avatar
Trade: Handyman
Rewards Points: 16
Re: Patio Dilemma
Itís a big gab between the house foundation and the blocks by the small wall. Probably 6-8Ē. We donít want to put the last course in and cut them to fit cause it will be so noticeable that they are crooked.
jtomm is offline
Old 03-07-2018, 05:08 AM   #6
Spectre's Avatar
Rewards Points: 30
Re: Patio Dilemma
What about running the pavers at a 45?
Spectre is offline
The Following User Says Thank You to Spectre For This Useful Post:
parkers5150 (03-07-2018)
Old 03-07-2018, 06:20 AM   #7
jtomm's Avatar
Trade: Handyman
Rewards Points: 16
Re: Patio Dilemma
Like running them diagonal to everything?
jtomm is offline
Old 03-07-2018, 08:56 AM   #8
always building
parkers5150's Avatar
Trade: general constructiion
Rewards Points: 2,102
Re: Patio Dilemma
exactly
"Building trust one job at a time."
www.RDPontheWeb.com
San Diego Contractor Deck and Patio Cover Builder
parkers5150 is offline
Old 03-07-2018, 08:58 AM   #9
jtomm's Avatar
Trade: Handyman
Rewards Points: 16
Re: Patio Dilemma
Originally Posted by parkers5150 View Post
exactly
Thought about that but itís a lot of cutting and donít know if Iíll have enough blocks
jtomm is offline
Old 03-07-2018, 09:37 AM   #10
Frank Castle's Avatar
Rewards Points: 1,114
Re: Patio Dilemma
Thought about that but it’s a lot of cutting...
Nobody said it would be easy.
...and don’t know if I’ll have enough blocks
Can't you get more block?
Adapt, Improvise, Overcome.
Frank Castle is online now
The Following 3 Users Say Thank You to Frank Castle For This Useful Post:
asevereid (03-07-2018), Bull Trout (03-07-2018), Rio (03-07-2018)
Old 04-10-2018, 11:09 PM   #11
jtomm's Avatar
Trade: Handyman
Rewards Points: 16
Re: Patio Dilemma
So if I lay the patio at a diagonal where do I start? In the center? A corner? Which one?
jtomm is offline
Old 04-10-2018, 11:35 PM   #12
TheConstruct's Avatar
Rewards Points: 22
Re: Patio Dilemma
You'll need to choose a wall to reference your 45 off of. Is the retaining wall at 90 to either of the buildings? Laying out off of the most visible or longest wall makes sense to me. You aren't going to be able to get things to look symmetrical regardless so it's not worth worrying about.
TheConstruct is offline
Old 04-11-2018, 05:48 AM   #13
90%-er
onmywayup's Avatar
Rewards Points: 1,510
Re: Patio Dilemma
I'd start laying block across the longest diagonal possible for the area, then work my way out from that center line in both directions.
Either that, or move towards a different block pattern (or flagstones) that is more random, so you can't tell the pattern gets cut off oddly.
It's not your fault that the buildings are constructed at odd angles to each other, is it? You can only deal with the actual situation on the ground at this point. If it costs more to the homeowner for extra block, etc, then that's the reality.
onmywayup is online now
The Following 2 Users Say Thank You to onmywayup For This Useful Post:
asevereid (04-11-2018), Frank Castle (04-11-2018)
Old 04-11-2018, 10:13 PM   #14
always building
Re: Patio Dilemma
I think you need to remove this trade from your badge
www.RDPontheWeb.com
The Following 3 Users Say Thank You to parkers5150 For This Useful Post:
asevereid (04-11-2018), Californiadecks (04-22-2018), tgeb (04-15-2018)
Old 04-21-2018, 08:01 PM   #15
AustinBailey41's Avatar
Trade: Electrical
Rewards Points: 8
Re: Patio Dilemma
IF things aren't square you'll need a wet saw to cut the blocks and just cut whatever angle you need. There's really no brick laying technique that will make up for the different angles of the walls. You'll need to cut things to fit.
AustinBailey41 is offline
Old 04-22-2018, 04:02 PM   #16
JBM's Avatar
Trade: Masonry
Rewards Points: 4,502
Re: Patio Dilemma
When your standing there looking at it, make it straight and perpendicular to your visual eye, cut everything to make it fit along the way.
JBM is offline
Faceframe Dilemma Vinson Finish Carpentry 7 04-11-2015 11:43 PM
Grading & base InterCounty Masonry 8 06-11-2013 10:11 PM
Help with ideas, Patio roof kambrooks Carpentry 28 10-09-2012 07:13 PM
24' x 45' Patio with 4 Steel Post Only buddyb1201 Remodeling 11 08-10-2012 12:14 AM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 12:27 AM
