Lime Application Spreader Settings
Old 07-21-2012, 04:13 PM   #1
dale rex's Avatar
Trade: painting and carpentry
Rewards Points: 169
I'm not a landscaper(I am a home improvement contractor),but I need some advice on how to apply lime to my own homes yard. I hope you guys here can help me with the spreader setting. I need to apply it a rate of 25lbs/1,000 sq ft. twice a year. The place I purchased the pelletized lime told to set my Earthway broadcast spreader at 16. So I set it there and ran the first 50 lb bag through. I usually make each pass 6 ft apart accross the yard. It went 6000 sq ft. Since I need to apply 25lbs/1000sq ft.....at the rate I applied it was 25 lbs/3000 sq ft. or approx 8.3 lbs/1000 sq ft if I did the math correctly. I had to go over the yard 3 times completely to get the proper amount down. While this works, its alot of walking( my yard is 16,000 sq ft.) How can I get the spreader setting correct without guesswork? I contacted the business that i purchsed the lime from and he said he was going by his basic settings chart for application rates. He seemed stumped when I told him what happened, so I guess Im on my own to figure it out with some help here hopefully?
dale rex is offline
Application Cutlist WIP Kent Whitten Drafting & CAD Forum 9 07-10-2012 12:41 AM
Scotts Spreader / Sta-Green Weed & Feed John Valdes Landscaping 3 03-11-2012 12:42 PM
CSLB Lisense application thenewbie Contractor Licensing 0 10-27-2011 01:39 PM
Lime & Plaster of Paris over Blue Board? CarrPainting Drywall 4 05-03-2011 01:42 PM
Venetian Plaster Glossary Plaster Ayn Faux Finishes 3 04-27-2011 09:46 AM
