Lawnmower Blade Question
I have a 3 blade 54" deck, I took the blades off to clean the deck, and sharpen the blades. My question is does it matter what position the blades are in when I put them back on?
Re: Lawnmower Blade Question
Not at all. I hope that you balanced them as well.
Lawn&Landscape
yes the first blade should be placed 7 & 1 the second blade 9 & 3 and the third blade 12 & 6....
no it does not matter as soon as the belt slips on the spindles they are in different spot anyways..
www.alwaysgreenerlawn.com |
#4 | |
M. D. Vaden of Oregon
Re: Lawnmower Blade QuestionQuote:
And they sharp edge must face the same direction of travel again. So there is a top of the blade. If you flip it upside down, the blunt edge will hammer grass and obliterate it. |
#5 | |
Trade: Service Contractor
You know your stuff, couldn't have said it better. |
| Tight Space Stucco Question - Undershot between roof sections | CGofMP | Construction | 3 | 03-24-2009 09:10 AM |
| So what diamond blade DO you use? | lukachuki | Masonry | 15 | 01-03-2007 01:24 PM |
| Diamond Blade Question | CLFitchett | Masonry | 10 | 04-03-2006 07:45 PM |
