John Deere JX75 Running Issues - Page 3 - Landscaping - Contractor Talk
Old 07-12-2017, 02:52 PM   #41
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 2,612
Re: John Deere JX75 Running Issues
Just finished cutting...seemed to be okay. Time will tell.
artinall is online now
The Following User Says Thank You to artinall For This Useful Post:
hdavis (07-12-2017)
Old 07-14-2017, 04:09 PM   #42
artinall's Avatar
Thank you everyone who posted.
This help has been great.
Old 07-14-2017, 04:54 PM   #43
hdavis's Avatar
Rewards Points: 3,981
Wait a while before thanking people, but you're welcome!
hdavis is online now
Old 07-14-2017, 06:41 PM   #44
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 2,210
So did you pull the plug afterwards and check it for getting crudded up?
SmallTownGuy is online now
Old 07-15-2017, 12:56 PM   #45
artinall's Avatar
Thanx for asking. I did.
And it looks just like it should now...
hdavis (07-15-2017)
Old 07-16-2017, 09:57 PM   #46
hdavis's Avatar
Just to recap, you did an easy clean on the carb and fuel system with MIB, and cleaned up some of the linkages with carb cleaner, and put a new plug in.
Anything else?
Old 09-16-2017, 08:48 PM   #47
artinall's Avatar
Anything else?
Not at the time
But since then, I've noticed that whenever it barely starts, or runs far under par, that this valve is stuck in forward position. When I push it back toward the rear, it seems to run okay. That second pic is there for a spring loaded set screw, which rotates as the connected arm moves...that I don't see how it regulates anything...
John Deere JX75 Running Issues-jx75-carb-valve.jpg   John Deere JX75 Running Issues-jx75-carb-set-screw.jpg
Old 09-16-2017, 09:44 PM   #48
hdavis's Avatar
Looks like it could use another clean and lube there.
Some carbs have automatic chokes - if that's what it is, it needs to move freely.
Also, quite a few lawn mower engines are set up with RPM control. There are normally at least 2 wire linkages that are involved, and there is an adjustment screw that goes along with it.
Find a diagram of your carb, and it should give you the details of what you're looking at.
Trailer issues parkside Tools & Equipment 22 01-28-2015 11:09 AM
Running wires in 2x3 walls Horseonaboat NEC Discussion 12 04-22-2014 06:13 PM
I need some help trying to understand and overcome some issues Gary L Construction 26 02-20-2014 10:23 PM
Metal Building Condensation Issues waringabbott General Discussion 8 12-16-2011 01:43 PM
