Irrigation Pump Pressure Switch
I was servicing a failed irrigation pump today, which was mounted in a pump house. The pressure switch was the type with the manual cut-in lever. Is this type absolutely necessary on an irrigation pump that is mounted essentially outdoors? I thought that these manual cut-in levers were to keep a house from flooding if a pipe burst indoors and the pressure suddenly droppped.
DGFVT
Trade: Electrical
Re: Irrigation Pump Pressure Switch
MD
The manual cut-lever is there to prevent motor damage if the well runs dry due to some kind of leak/brake in the water line somewhere. I have seen a stuck toilet fill drain fail and drained the a well of all the water plus burnt out the pump motor. The manual cut out is a very good thing to have. Last edited by CE1; 10-30-2006 at 06:55 PM. |
This pump is in a sippy hole of a very large creek. No chance of it pumping dry. I never acutally knew that the manual cut-in lever was to protect the pump, but it makes perfect sense.
I just googled and found a maintained manual cut-out and a momentary manual cut in. Could one of you guys explain how it would work and what i might need. I have a piston pump for watering the lawn. I've been concerned about flooding the basement and burning the piston leathers. I've been hitting the disconnect after each use which can occasionally cause the pump to loose prime. Sounds like one of these switches will save me some trouble and allow me to go to a timer. Thanks.
DGFVT
Trade: Electrical
There are some more sophisticated switches for commercial and industrial purposes. I real common one is an inline flow switch which is connected to the pumping control circuit. So if there is no flow do to some reason another pump comes on and all kinds of alarms, lights, e-mails, pages, etc, alert people that there is a problem. There are some really very expensive pumps out there that you absolutely do not want to run dry and these “Run-Dry” prevention switches help avoid expensive repairs. This also applies to critical pumping applications that require a constant flow and pressure.
With the momentary manual cut-in, the pressure switch has an additional lever on the side. If the pressure in the line or tank drops much below the automatic cut-in, the pump will shut down. You have to manually hold the momentary manual cut-in lever down until the pressure builds back up on the gauge so that automatic operation will resume. If pressure doesn't build back up, then you can investigate what is causing the low pressure issue. Empty well/cistern? Pipe break? Failed pump? etc.
So I guess what i would need is an auto cut-out that responds to no flow or zero pressure. Is there something on the "reasonable price" market that can do this??
#8 | |
DGFVT
Trade: Electrical
Re: Irrigation Pump Pressure SwitchQuote:
Square D makes both types of these pump controls and the one with the manual lockout is well worth the little extra money. |
#9 | |
DGFVT
Trade: Electrical
check this out: http://www.amazon.com/Square-FSG2J24...5?ie=UTF8&s=hi Last edited by CE1; 10-30-2006 at 08:22 PM. |
Re: Irrigation Pump Pressure Switch |
#11 | |
Always a chance of loosing prime, vibrations (causing influent side air-leak) , power outages, damage by to infuent line by fencers/ landscaper etc, the list goes on. |
| Replacement pump for pressure washer | T bone | Pressure Washing | 5 | 08-01-2008 12:56 PM |
| Increasing pump pressure | Teetorbilt | Plumbing | 2 | 02-24-2007 10:40 PM |
| Lennox Pressure Switch Trouble? | Glock23 | HVAC | 1 | 01-03-2007 10:25 PM |
| Draft inducer vs. pressure switch vs.? | arctic trooper | HVAC | 3 | 03-15-2005 08:29 AM |
