Interlocking Patio Tiles Over Pea Gravel?
Old 06-21-2016, 12:08 AM   #1
antimatter's Avatar
Trade: landscape
Rewards Points: 2
Trying to add a temporary 15x15 ft extension to an existing patio.* Simplest option would be to pour a concrete pad, but HO is planning a major reno in a couple of years and doesn't want anything difficult to remove or too expensive.* Suggested laying out the area with pea gravel, but HO is concerned about the loose fill moving around, particularly while moving patio chairs around.* There is a slight slope, about 6-8 in lower on the far edge, so some kind of fill would be needed in any case.
Does anyone have experience with using interlocking tiles (e.g. blocktile) in such an application? The brands I've looked at seem to require a harder substrate, like concrete or an existing deck/patio.* I can easily imagine the strain on the tile joints from a concentrated weight (like under a chair leg) being a problem if there's not enough support.* Is anyone familiar with any brands durable enough for this, but not too expensive?* Would a different fill material be preferable?
antimatter is offline
Old 06-21-2016, 07:32 PM   #2
slowsol's Avatar
Rewards Points: 2,192
Re: Interlocking Patio Tiles Over Pea Gravel?
Why not just put in pavers?
-John
slowsol is offline
The Following User Says Thank You to slowsol For This Useful Post:
MarkJames (06-21-2016)
Old 06-21-2016, 09:32 PM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 10,693
Forget they ever mentioned temporary. There's no guarantee of that. Just give an affordable, properly-done solution (especially since they want to put chairs on it).
What's their idea of inexpensive, anyway?
MarkJames is online now
Old 06-21-2016, 10:43 PM   #4
antimatter's Avatar
Trade: landscape
Rewards Points: 2
thanks for your reply...He balked at the price of pavers, which is mostly labor. Somehow he got the idea that $1.50 pavers from HD were going to be cheap to install so I'm trying to find a simpler option.
Old 06-22-2016, 09:44 AM   #5
VinylHanger's Avatar
Rewards Points: 6,932
Sounds like this is one to walk away from. If pavers are too expensive, what is he expecting?
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
JDavis21835 (06-24-2016)
Old 06-22-2016, 11:58 AM   #6
antimatter's Avatar
Trade: landscape
Rewards Points: 2
They want to spend about $500-$800 to cover the gravel with interlocking composite tiles or a connecting plastic mat vs the labor of installing pavers which they vow they will remove next year...maybe it is a pass, but I'll see what they come up in a few days or if they reconsider..they problem is that they agreed to the cost of two other jobs, so i'do hate to lose the client.
Old 06-22-2016, 01:01 PM   #7
MarkJames's Avatar
Tell them that they still need a base, which is why it costs what it costs. It's about safety, etc.
Cost this up: frame it (perimeter) with timbers, fill with gravel and sand, set 12 x 12's into it. I saw a dIY job done that way with brick pavers and it held up great. I don't even think it was compacted.
Old 06-22-2016, 07:56 PM   #8
SouthonBeach's Avatar
Rewards Points: 923
Why not put crushed concrete under it -3/8" fines aka paver base around here.
Pack that down with a little bit of moisture and it'll be as hard as you'd want something temporary in a week or so of time.
SouthonBeach is online now
Old 06-23-2016, 10:59 AM   #9
antimatter's Avatar
Trade: landscape
Rewards Points: 2
Yeah, I'm thinking the same way, thst a compacted qp base might hold up in this application. thanks SB!
Sent from my SM-G935V using Tapatalk
Old 09-13-2016, 02:03 PM   #10
EcoMindedSD's Avatar
Trade: Landscaping & Remodeling
Rewards Points: 128
We love using different types of hardscapes and rock materials. Take a look and see if it'll help you figure it out.
Award-winning landscape and home designs in San Diego, showcasing our innovative techniques for sustainable luxury. Watch us at work: http://bit.ly/2bfBRPI
EcoMindedSD is offline
Old 12-30-2016, 09:11 PM   #11
Learn-Build-Enjoy
ASidhu's Avatar
Trade: Carpentry and Landscaping
Rewards Points: 128
Just use some 3/4 clear gravel, or road crush and compact it well with a machine. You can always reuse this gravel after for anything that requires a nice good draining base. Pea gravel is not good for much other than looks. I never use that stuff. You can never compact it, it always moves around.
ASidhu is offline
Dry Pack for laying porcelain tile on exterior patio Kyong Tiling 8 09-06-2015 11:11 PM
Patio interlocking tile ? j_sims Flooring 7 11-08-2014 05:57 PM
Grading & base InterCounty Masonry 8 06-11-2013 11:11 PM
24' x 45' Patio with 4 Steel Post Only buddyb1201 Remodeling 11 08-10-2012 01:14 AM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
