Gravely ZT Decision
Old 04-01-2017, 07:01 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,214
Gravely ZT Decision
After looking at other mowers, and ruling out snapper, cub cadet, john deere and ariens, I am settling on the Gravely ZT 42 inch. This three blader with a decent gauge fabricated deck and the Kohler 22 HP 7000 engine.
Lubrication on the wheels are permanently sealed (would rather have zerk) and there is nothing to lube
Will be mowing about a 3/4 to 1 acre lot.
Anyone by chance have one of these? I think this model isn't the one(s) associated with the trouble starting blade and possible choke issues....
Is there another mower in its class that might be better for up to $2800?
A note on exmark - asking a local dealer who makes the exmark engine he said that they make their own. He also told me that they will be no longer supplying their engines in the future, likely using Kohler...
artinall is offline
Old 04-01-2017, 07:05 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 1,166
Re: Gravely ZT Decision
Have you looked into the Grass Hoppers?
griz is online now
Old 04-01-2017, 07:16 PM   #3
artinall's Avatar
nice but out of price range
artinall is offline
Old 04-01-2017, 08:51 PM   #4
The Sheriff
Jaws's Avatar
Rewards Points: 5,272
Gravely and Ariens are the same basically.
I have a 60" Gravely, heavy use on some acreage, in and out of the shop. Probably go Kubota next time because I have Kubota equipment and I like their service folks locally.
If it was just 3/4 acre I would probably just get a regular mower.
"The sound of the saftey clicking off is the only warning your gonna get......., so cover your ears" Northeast Wyoming 2016
John
Jaws is online now
Old 04-02-2017, 12:27 AM   #5
GC/carpenter
Californiadecks's Avatar
Rewards Points: 6,980
I have Gustavo.
Californiadecks is online now
The Following 2 Users Say Thank You to Californiadecks For This Useful Post:
hdavis (08-01-2017), Jaws (04-02-2017)
Old 07-31-2017, 03:27 PM   #6
artinall's Avatar
Nice mower the ZTR but went to change the oil and it has the cheapest looking drain plug assembly w/cap that I've ever seen on any engine, wobbles. Female piece looks like cheap plastic too. 24 hp kohler 7000 series.
A little seeping, but the mower is almost brand new. What a place to cut costs...
artinall is offline
Old 08-01-2017, 11:08 AM   #7
hdavis's Avatar
Rewards Points: 8,021
Crappy drains are pretty common. You can spend $10K on a whole house generator, and the $2 drain setup will leak oil all over the place when you change oil.
hdavis is offline
Old 10-26-2017, 11:01 PM   #8
Kumpel's Avatar
Rewards Points: 28
Ferris
Kumpel is offline
Old 01-24-2018, 10:48 AM   #9
Restoman's Avatar
Trade: General Contractor - Residential
Rewards Points: 14
I have a Dixie Chopper Zee2 5423. 54" cut 23 hp Kohler. It's my first but its been great. Newer models come with Kawasaki or Briggs. Kohler sorted out their issues but I think people were steering clear of the Kohler and it was hurting Dixie's sales. No complaints. Biggest suggestion I hear people give when people ask "what ZT brand should I buy", everyone responds: buy based on the dealer. It will go in for service and you better like dealing with them and the service they provide. I like my Dixie Chopper but not the dealer so much. Xmark is popular here because of Tubb's Hardware. Love the shop and people but not the mowers.
Restoman is offline
Old 01-24-2018, 01:26 PM   #10
artinall's Avatar
Originally Posted by Kumpel View Post
Ferris
Those are nice, shock absorbers on them too. Dealer down the street carries. They're not cheap either.
artinall is offline
Old 04-19-2018, 08:29 AM   #11
sidemouse's Avatar
Trade: Landscaping
Rewards Points: 106
There is a big difference between residential and commercial grade zero turn mowers, I am thinking in your price range the Gravely is a residential grade which I find odd since it is usually the Ariens that produces that grade mower but if Gravely has a non-commercial Zero then so it is.
Whether I would use a $3000 unit for a 3/4 to 1-acre lot is another story, but with a 42" deck it will likely take you between 1 to 2 hours (1 hour being full stick) as I get an acre mowed with a 60" 25hp in about 30-45 minutes and you might get it done in as little as 45 as well, hard to say.
They're not as easy to operate as it looks, it does take practice. Of importance are the turns, you need to remember to make either 3-point turns (by far the easiest) or to be sure that both wheels are turning (one forward, one reverse) otherwise your inside tire will divot and tear up a spot of turf down to the dirt.
Zeros are best on flat, open terrain. If your yard has steep hills I would opt for something I can walk behind so that if the mower gets away from me I can just step back or aside and let it go. There are few things that allow one's life to flash before the eyes, being on top of a zero turn as it heads for a culvert uncontrolled is one of them. NEVER point a zero down slope, your 'power' wheels are in the back and pointing it down slope shifts the weight to the front and you will have little to no stopping power. ALWAYS point a zero UP slope, sideways may work but it can be tricky as well.
As a closing statement you can get around the oil change issues by doing some research, then running to HD / Lowe's and picking up some short steel pipe extensions in their plumbing department (even with plugs) all for under $10 (picture is of one of my Toros with a 15hp Kohler with just such an extension, these greatly facilitate the dreaded oil change).
p.s.: I believe they are 1/2" extensions but it's been some time since I've done one, they come in various sizes and lengths (and they're not called extensions either, they are "galvanized steel nipples" yes I'm serious).
sidemouse is offline
Old 04-19-2018, 10:32 AM   #12
The Sheriff
Jaws's Avatar
Looking at this ome right now to replace the Gravely. They have good service here and its pretty much an all welded frame, far fewer bolts than the gravely.
My new place has a lot of trees so i am thing of going down to a 54" to get it skinnier. Only 500 more for 60"
Anyone have experiemce with Kubota mowers? I love my 4701
Sent from my SM-N920V using Tapatalk
John
Jaws is online now
What was your best decision? Hoquester Flooring 18 04-29-2012 05:51 PM
Slow decision makers AJAX Business 6 05-07-2011 01:30 PM
Your Follow Up Reason, Besides, I am Just Seeing If You Made A Decision Yet..... Ed the Roofer General Discussion 17 05-08-2009 10:33 PM
Need some imput to make a decision MAC2PAINTING Wallpaper 11 04-01-2009 09:14 PM
Key Business Decision That Propelled You to the Next Level buildpinnacle Business 47 03-30-2009 09:33 PM
