Drip Irrigation Systems
Old 06-16-2008, 10:57 PM   #1
Tscarborough's Avatar
I have a 2 week vacation coming up and need to keep the beds alive. Are the Home Cheapo drip irrigation systems by DIG worth the (very small amount) of money? Will it keep my gardens alive for 2 weeks or is there a better way?
Tscarborough is online now
Old 06-17-2008, 12:29 AM   #2
Crash Test Dummy
ChainsawCharlie's Avatar
Trade: Landscaping
Re: Drip Irrigation Systems
They should work well enough providing they don't clog. I use them in some of my garden beds, but I'm able to monitor daily.
Got reliable neighbor, family or friend?
For temp systems, I run pvc with pop-ups or shrub sprayers. I can supply tou some pics of a simple setup if you like. I use plug in type timers and irrigation valves but a hose end should suffice.
How much are are you needing to cover?
ChainsawCharlie is offline
Old 06-17-2008, 12:32 AM   #3
Crash Test Dummy
Trade: Landscaping
Is it possible to run soaker hoses? Put those on a hose end timer.
Old 06-17-2008, 02:54 AM   #4
genecarp's Avatar
http://www.dripworksusa.com/ check it out
genecarp is offline
Old 06-17-2008, 08:07 AM   #5
RCPainting's Avatar
Trade: Painting in Utah
Soaker hose with timer sounds good. I have used the drip line with different sprayers, misters, etc. Takes daily monitoring, like Charlie says. I ended up going to soakers because I am on a well and the sand kept clogging the lines. Do put a filter on the hose.
RCPainting is offline
Old 06-17-2008, 11:45 AM   #6
That dripworks is the same as HD. The problem is that I have beds, planters and pots, and they are scattered all over the place. The pots I will move, and probably run soakers on the far beds. I can do the whole thing for less than 100 bucks, which is less than I would have to pay a nieghborhood kid to ruin my beds.
Old 06-17-2008, 07:47 PM   #7
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
I've used drip irrigation like what you are talking about for at least 15 years or so. We aren't on well water so sand isn't an issue. The stuff isn't bullet proof, but it does work and is ridiculously easy to work with. Usually every spring you have to fool around with it, replacing a couple of broken heads or sprayers, maybe plug back in a line or too, but then that's about it till next year.
Mike Finley is offline
Old 06-21-2008, 12:10 PM   #8
It is easy to work with. I got all the mainlines and half the feeders placed on one section in about three hours (I ran it up in the beams of my pergola with drops at the columns). I am going to finish it this afternoon and crank it up, and if it works well, I will add another system on the other side of the yard.
Thanks for the help!
Why Build ICF monsterconstruc Green Building 32 09-28-2008 11:48 PM
Seperately-derived systems Mark Twenhafel NEC Discussion 3 11-11-2007 10:18 AM
New Photovoltaic Systems Textbook Magnettica Electrical 0 08-19-2007 10:44 AM
