Draining Water Between Two Buildings - Landscaping - Contractor Talk
Old 05-09-2017, 08:07 AM   #1
madmax718's Avatar
Trade: General
Rewards Points: 3,252
I have a very interesting problem where the water is pooling between two buildings. The off set of the building is very close (4 feet), and there isnt much of a good grade for run off in the right direction.
Is it a bad idea to install some channel drain that leads to a small drywell with a sump?
madmax718 is offline
Old 05-09-2017, 08:14 AM   #2
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 962
Re: Draining Water Between Two Buildings
I've never used a pump, but yeah, there have been issues resolved using bleeder pipe and a crock with slotted lid on the end of the run.
Depends on grades & soils etc.
SmallTownGuy is online now
Old 05-10-2017, 09:53 AM   #3
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 6,671
Maybe a boring machine installed gravity drain tile to the between buildings intake?
Fix the gutter drops (sloped roofs?) to evacuate the water from the low spot?
What happens when the pump fails?
Fouthgeneration is offline
Bagged premixed lime mortar for tuckpointing wazez Masonry 158 10-28-2012 07:02 PM
Stucco on wallpaper... The best solution for residential buildings. aulona Wallpaper 10 07-23-2012 02:30 PM
Supplying hot water to 4 apartments joesauers Plumbing Picture Post 8 03-30-2009 07:18 AM
Could water heater be overheating and overflowing? bob_cntrctr Plumbing 18 03-17-2009 07:39 PM
